When you look for a NON-POLARIZED elevtrolytic cap of the same size and value (capacitance in mF for instance) as the "usual" one, you'll always find it much lower in voltage and vice-versa. Why is that? Try to to get for example a 47mF/50V non- polarized cap and compare it to the polarised one. Also: why are they rare and expensive in the market? Example:a 1000mF/160V non-polarized capacitor is not easily found, if it exists in the first place.
In search of non-polarized caps
Re: In search of non-polarized caps
47/50V Bi-Polar http://www.digikey.com/product-detai...1283-ND/228294
1000uf non-polar (AC) CAP
http://www.amazon.com/Amico-Metalliz.../dp/B009ISC4T0Never stop learning
by eryjusHello,
by Paxman_SwedeHello!
I have studied the board and...-
by captain150I'm trying to repair two old VCRs, they both have bad caps. One has leaky ones, the other would barely run until I subbed in some caps from another power supply I had laying around (though they are the wrong values). This vcr works for an hour or two, but then the power supply starts whining and the picture gets lines in it. I didn't replace all the secondary caps, so another voltage might still be problematic, or the values I used are too far off.
I've been on mouser and digikey but the options are a bit overwhelming. I just need some new ones that will work. They don't need to be top quality,...-
by FoetussGood evening
I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
But I was also suprised about the bigger boys, which are 330µF 25V.
Could it be they used 25V caps because they were cheaper / available at that time?...-
by black6hostGood day!
I have a Samson Resolv studio monitor that has no sound output. I've opened it up and found two caps that are bulging on what I believe to be the power supply section of the amplifier board. The board is marked Resolv 65A AMP V1.2. The caps in question are YUSCON, 2200uF, 35V, 85C temp and have markings of RA(P) and are 16mm x 25.5mm tall. I've attached the schematic and the caps in question are C5 and C6. I'm assuming they are low esr caps. I've tested both caps and they test low uF, nowhere near 2200uF.
I'm going to replace the caps and I'll be the first...-
- Loading...
