Transformer identification
  • DJduck
    • Dec 2012
    • 229
    • Estonia
    I got this old transformer from a friend, its from a JVC stereo. One or two of the connections was broken off, so i had to solder two new wires on. I think that both of the wires may have been connected together. The problem is that there is no information on it, only a model number FMTP1100-01EA and some other code M 9605. I know this might be a stupid question, but does anybody know any specs or how to hook it up? Pic of the trans: the two wires are soldered to one wire each, the ones that were broken off.
    I can put text here?!
  • Toasty
    • Jul 2007
    • 4171
    Re: Transformer identification
    Get the model number of the stereo it was in and work from there. Since it's a component part, that's the only way to get info about it.
    Specs aren't typically published about these as manufacturers have them built special for the device they are part of.
    Once you have the schematic, you'll have the hook up info you need. As far as current /power ratings, that won't be available either.
    T
    PS: Failing to find any info, you can still use it to hold a door open...
    veritas odium parit
    • DJduck
      • Dec 2012
      • 229
      • Estonia
      Alright, i will try to contact my friend and see if he still has the case, there should be a model number.
      • goontron
        5000!
        • Dec 2011
        • 4108
        • US
        or just short it till it burns! I WANT FLAMES
        Follow the white rabbit.
        • tw2005
          • Oct 2011
          • 6458
          Jvc ca-d4t, 230/240vac
          • Toasty
            • Jul 2007
            • 4171
            Nice piece of reverse lookup there tw2005!
            Now the tasty bits...
            Pages 58, 85, 88
            T
            PS: FMTP1100-01EA - the parts page lists Area as: A, EF, EN, G, GI, VX, BS. Match your area to the chart on p85 for wiring.
            veritas odium parit
            • DJduck
              • Dec 2012
              • 229
              • Estonia
              Wow, how the hell did you find it?? Thanks tw2005 and toasty! I will look at the PDF and then see if it works! And i did see some of the front panel pieces at his place, it is the same stereo, with the CD changer and everything...
              Ok so am i blind or what, but i can not find the outputs of it in the manual. I got it wired up, going to plug it in.
              plugged in and..... no explosion! Wired blue to 2 and brown to 5. In Estoina, it doesn't actually matter if you wire blue to 5 and brown to 2, you can put the plug in the wall outlet both ways (two prongs).
              • learnmore
                Help choosing replacement transformer for Levoit 600S SMPS
                by learnmore
                Hello Community,
                I'm attempting to repair the SMPS on a Levoit 600S air purifier. The transformer is likely open. It has six pins. 2 pairs on the primary side (one pair tested open) and 1pair of legs on the secondary side. Legs on the secondary side are spread wide apart (end-to-end). I've circled them in blue. Dimentons of the transformer are 22x23mm. Marking on the transformer are EE16 1.9mH-B. Fuse for the powerboard is fuse 250V 3.15A. I've been unable to find an exact match and I'm hoping for some help here to find a suitable replacment.
                Peace
                LM...
                11-04-2025, 09:35 AM
              • ohren
                Original Xbox 1.0 PSU: Foxlink FTPS-0002 Rev. B. — 12 V low, 5 V high — transformer?
                by ohren
                Hello!
                I'm looking at an original Xbox PSU: Foxlink ftps-0002 rev. B. The 12 V output is too low, and the 5 V output is too (?) high. Unfortunately I don't have an oscilloscope but only a DMM for diagnosis.
                Measured voltages with no load:
                After rectifier diodes
                12V: 6.17 V
                5V: 5.67 V
                Secondary transformer pins AC measurement (really don't know if this says anything)
                12V: 2-2.5 V
                5V: 1.04 V
                I also have another (working) Xbox psu from Delta. The same measures there, in order, being: 10.79,...
                03-18-2023, 10:33 AM
              • Alucio1970
                Help identifying PCB FS-750-2025 with TEA2025 – unbranded multimedia speakers
                by Alucio1970
                I'm trying to identify the origin of a circuit board inside a pair of unbranded stereo active speakers. No logo, no model number—just generic "MULTIMEDIA SPEAKER SYSTEM" printed on the front.
                Main details:
                • PCB marked FS-750-2025 with a logo that looks like a stylized sail inside concentric circles
                • Audio chip: UTC TEA2025, stereo configuration
                • Potentiometers: B50K (Volume, Tone, Power)
                • Capacitors: 470µF 25V and 1000µF 25V
                • Transformer: 230V~ → 19V AC 350mA, thermal fuse rated 115°C
                • Speaker: 5W driver with magnet labeled “JY ม5w” (Thai
                10-15-2025, 02:46 AM
              • mikey5791
                Is it possible for transformer substitution?
                by mikey5791
                Got this local made DC power supply (12/14V) given free as the transformer has melted. There is no marking or indication to identify what type or rating of transformer used.
                Fyi,. I had a busted autogate mainboard with transformer with marking 13-0-13 . Is this the 13v dc type transformer?
                My questions are
                1. How do i test to see if the transformer is in good working condition?
                2. Can this transformer (marking 13-0-13) be used to replace the melted transformer on the DC power supply?
                Hope you guys understand what i was asking. My intention is...
                11-03-2022, 02:11 AM
              • dennis_elx33
                3PHASE STEP-DOWN Transformer in Check
                by dennis_elx33
                Hello All,
                i would like to post an interesting topic regarding 3-phase stepdown transformer which we suspect to cause an overcurrent (138A) which resulted to power tripped off of the HV power supply (80KV output).
                Problem statement: Power tripped Off
                Initial Problem: Found 2 IGBT and 2 rectifier diodes shorted (burnt).
                Action Done:
                1) Replaced the faulty parts with good spare.
                2) Measured impedance of the 3phase input lines and found that L2 to L3 has 23.3ohm while other pairs are 51Kohm. This pins will...
                12-02-2024, 06:52 AM
