Attaching SMA connectors to RG178 cable
  • mathog
    • Mar 2010
    • 2655
    Anybody have some pointers for attaching SMA crimp connectors to a piece of RG178 coax? I have built SMA on RG58 cables a couple of times, and it was not particularly difficult. However, when I test stripped one end of the RG178 I found the thing was so tiny that I had to borrow a stereo dissecting microscope in order to see what I was doing Admittedly my eyes are not what they once were, but it was a lost cause even with my "near" reading glasses, which were good enough for the RG58 cables.
    Is it just me, or do most people have to use magnification when working with this type of micro-coax?
  • rhomanski
    nowhere man
    • 5157
    • U S of A
    Re: Attaching SMA connectors to RG178 cable
    I had to buy one of those round magnifiers with the circular fluorescent bulb and the articulating arm to work on anything. I even use it for reading if the print is small enough.
    sigpicThe Sky Is Falling
    • mathog
      • Mar 2010
      • 2655
      Originally posted by mathog
      However, when I test stripped one end of the RG178 I found the thing was so tiny that I had to borrow a stereo dissecting microscope in order to see what I was doing.
      Built that cable today -what a PITA. Besides everything being so small I needed the microscope to see them, some parts were super light. The center pin weighed about as much as an eyelash and holding it in place to put solder on the tiny hole was damn near impossible. The surface tension on the little ball of solder was enough to pull the pin off the center conductor. Then once a tiny amount of solder had stuck to the pin gravity took over and the pin kept rotating on the central conductor until the solder coated part faced down. Finally got it under control by gently "clamping" the pin between a nickel and a dime. Rotating the dime (on top) rotated the pin so that the hole was up, and there was just enough pressure to hold it but not scratch it, and just enough friction for it not to move when it was soldered.
      I hope this cable lasts, because I don't want to have to do that again any time soon!
      • fuzzy4
        Identify Cable connectors
        by fuzzy4
        Can someone identify the connectors on this cable and what it's used for?
        I recognise the BNC and what looks like power.
        The middle connector, is a BNC adaptor.
        Thanks...
        09-08-2024, 02:37 AM
      • howardc64
        by howardc64
        Problem
        08-04-2024, 10:36 PM
      • Patch2
        Cable Repair
        by Patch2
        I have a broken connector (believe it's a 6 pin mini-DIN) on a cable. The metal shroud and all but one of the pins are separated from the cable, and just stuck together for the photo. The other end is an unknown rectangular connector. The cable is for the foot pedals on an Italian made electronic piano, and the company is out of business. Looking for ideas on how to fix it. I have a soldering iron, but I'm not very skilled at soldering, so getting a retrofit for the broken end may be beyond my ability. The other end would be easier to replace, if I could get a mini-DIN cable with the same number...
        01-02-2025, 06:04 PM
      • Tr0ll
        by Tr0ll
        Original T-con:
        First replacement T-con:
        10-07-2023, 07:48 PM
      • conghuyms
        I need datasheet cable eDP LCD 30 pin slim pls help me!
        by conghuyms
        My 30-pin eDP cable from the mainboard to the LCD screen got cut and damaged at the screen connector side. I found another cable and took the screen-side connector from it, but the wire colors are different. So I really need the wiring diagram for both ends of the eDP cable to solder it back properly. If anyone has the diagram, please kindly help me out. Thanks a lot...
        08-22-2025, 11:16 AM
