lg-55ld520
  • splitcrete
    • Dec 2012
    • 387
    • usa
    lg-55ld520
    Hi everyone. I have a question ,that I know you guys can answer.
    I picked up a lg-55ld502 No picture or sound.
    Took off the back and seen the jumper between the two master inverters was burnt beyond repair,looks like a small fire was on the board.
    My question is,what would make the 14 wire jumper burn ?
    It also looks like the slave jumper is ready to burn too.
  • ttmi100x
    HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
    by ttmi100x
    Greetings everyone,
    I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
    The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
    Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
    Upon closer inspection...
    07-31-2024, 06:36 PM
  • howardc64
    Insignia NS-43D420NA20 backlight on no display - LCD panel burn failure
    by howardc64
    Eventually discovered a burn mark near lower corner of LCD. Here is a summary
    • Backlight on, no image
    • Disconnect right buffer board (view from front), left side display comes on
    • Masked off pin 7+8 (both ~12,5v on both left and right buffer board) from t-con to right buffer board (view from front) display works but have some lines
    • Buffer board is pretty simple
    Removed the front bezel to examine edge of the glass. Found burn mark on lower right (view from front). Plastic bezel covering the burn mark region shows heat signature on the inside surface facing the LCD panel. Last 2 pics. Bright...
    07-11-2025, 04:04 PM
  • MMH3
    Dell Optiplex 5050 SFF - strange behavior and service_mode jumper not working anymore
    by MMH3
    i have many 5050sff. all of them, and how i experienced over many years for all about 250 DELLs goin through my hands, are fully flashable and can be serviced in any way when the service_mode jumper is set.
    Never ever i experienced problems with that.
    Now i have one 5050sff machine, where this jumper isnt working at all.
    I do not get the normal messge that the jumper is set when booting and a short test with FPT just confirms this. Everything is locked -->> EVEN for reading !?
    The history of the machine is that i used it in my office...
    03-23-2025, 09:28 PM
  • blankdisplay
    HP EliteDesk 805 G8 "PSWD" Jumper
    by blankdisplay
    Apologies, I broke a rule and hijacked a thread, so I deleted that post.
    I am curious if anyone here owns the G8 or has good quality board shots?
    I've done some googling and curious if the 805 G8 series has some kind of jumper?!
    The 800, G3 series, much older, the maintenance and service guide, clearly talks about a PSWD jumper
    https://cdn.badcaps-static.com/pdfs/...cc246ac326.pdf
    I also believe it's just visible in this shot:
    https://www.servethehome.com/wp-cont...-EliteDesk-800...
    10-22-2023, 02:43 AM
    Design of CCFL Backlight Inverters with Frame & Bar Cores
    Summary
    Portable devices, such as notebook computers and personal digital assistants are developed rapidly nowadays, which places an increasing demand on display technology. The LCD with cold cathode fluorescent back lighting satisfies the requirements on display performance, size and efficiency.
    The backlight inverter plays a crucial role in supplying the power to the lamps of these flat-panel displays.
    The frame and bar ferrite cores, described in this brochure, are especially designed...
    10-07-2024, 04:26 AM
