Building an LVDS cable
  • spleenharvester
    • Mar 2010
    • 913
    Hey all.
    As in a few other question threads I'm wanting to try build an All-in-one PC using a laptop motherboard and an Acer X223HQ.
    Problem is, the Acer X223HQ, while a decent bit of kit, only has a crappy VGA input.
    Anyone know of a laptop screen 40-pin to full-size 40-pin adapter, or if it's possible to build a cable to connect directly to the LCD's connection?
    That would eliminate the need for a control board and give me a lot more space to work with.
    This is the panel in the Acer: https://cdn.badcaps-static.com/pdfs/...f487676a01.pdf
    Anyone reckon this is possible?
    EDIT: Just realised it's a 30-pin panel :/ bugger
    Dell E7450 | i5-5300U | 16GB DDR3 | 256GB SSD
  • spleenharvester
    • Mar 2010
    • 913
    Re: Building an LVDS cable
    Bump
    • ResoluteHawk
      Connecting an LVDS/eDP cable into a live motherboard
      by ResoluteHawk
      Could anyone explain the reasoning behind why connecting an LVDS or eDP cable into a laptop motherboard, with the battery still connected, kills the CPU/PCH/SuperIO/GPU?
      Today I had a customer with a Lenovo Legion 5 that I diagnosed as a dead iGPU inside their Ryzen 5900HX. They told me that they connected their screen to the motherboard without first disconnecting the battery.
      I want to understand the nitty gritty behind why it kills components if power is not disconnected first.
      08-04-2025, 04:39 PM
    • alfredomfr1
      HP M32f FDH Monitor: 12v missing after connect the LVDS ribbon cable to the LCD circuit
      by alfredomfr1
      12v pin is shorted to ground in the LCD board (1st picture) if the LVDS cable is disconnected, 12v are OK in the Main Board (2nd Picture)
      06-04-2025, 10:23 AM
    • mon2
      A1466 Macbook Air (Liquid damage repair)
      by mon2
      Hi. Recently serviced a damaged A1466 Macbook Air. Thought to post the issues and resolution for each.
      Macbook AIR Model A1466 Diagnostic 09-01-2021
      Issue: Liquid damaged (beer spill) Macbook AIR will not power up.
      Problems & Resolutions
      1) Attached Apple magsafe power adapter. No green / no orange light. This confirms the absence of the PP3V42_G3H voltage rail. The PP3V42_G3H rail is the primary voltage rail necessary to communicate with the magsafe power adapter to report the green or orange light status to the end user....
      09-01-2021, 09:31 AM
    • Patch2
      Cable Repair
      by Patch2
      I have a broken connector (believe it's a 6 pin mini-DIN) on a cable. The metal shroud and all but one of the pins are separated from the cable, and just stuck together for the photo. The other end is an unknown rectangular connector. The cable is for the foot pedals on an Italian made electronic piano, and the company is out of business. Looking for ideas on how to fix it. I have a soldering iron, but I'm not very skilled at soldering, so getting a retrofit for the broken end may be beyond my ability. The other end would be easier to replace, if I could get a mini-DIN cable with the same number...
      01-02-2025, 06:04 PM
    • NolesFan
      Samsung un82ru88000f - Boot loop sort of but can correct with taping of LVDS ribbon
      by NolesFan
      Hello all... TV started boot looping. Opened the back panel and tried to isolate the problem. Just PSB no boot loop. PSB and MB no boot loop. Plug in the LVDS from panel to MB and boot looping starts up. It doesnt matter of order that I plug the LVDS ribbons back in, only 1 and no boot loop but as soon as 2nd one plugs in boot looping. I then noticed a flicker on the screen when I was closing the clip on the harness to the LVDS. Shut the lights off so I can see better, and I noticed as i slowly close it, I will get a picture, but as soon as it clips in, I lose picture and booting happens. So I...
      10-24-2024, 06:36 PM
