When you're building something, read the datasheet 100 times.
+ More Options
Posts
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    I made a PCB for my little 3842-based flyback PSU which uses a 5vsb transformer from an ATX PSU. It didn't work. The 3842 didn't output Vref, so the oscillator wouldn't start, hence no drive to the MOSFET -> no output.
    I checked the PCB a dozen times and found nothing suspicious. I spent over 3 hours trying all the 3842s i had, i think i went thru 8 or 10 of them. Note to self: sockets.
    Then, before going to sleep, i thought i'd look at the UC3842 datasheet another time. UVLO threshold for the UC3842 is 16v, and i had a 15v zener on the 3842's Vcc pin. Son of a... Sure enough, i disconnected the zener and the supply fired right up. Now, i don't recall why in the world did i put a 15 volt zener there, but i did. It says so on my schematic too.
    So... when your circuit won't start, read the datasheet one more time. You might just catch that brain fart you had when building the thing.
    A working TV? How boring!
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    Re: When you're building something, read the datasheet 100 times.
    Yea it's often very difficult to catch your own mistakes, it's just the way our brains work...
    For this reason at my work the guy making a CAD drawing for a machine may never be the same guy to measure the part after it has been produced, he will just make the same mistake when measuring as when drawing... (Been there, done that)
    So if it's possible for you to get a second opinion from someone else that's usually the best bet
    • ben7
      Capaholic
      • Jan 2011
      • 4059
      At least you didn't blow up the UC3842, like I did the other day!
      Muh-soggy-knee
      • Th3_uN1Qu3
        Believe in
        • Jul 2010
        • 6031
        We have progress! Circuit is nice and stable with a 1A load on the output (quick n dirty compensation too, haven't even tweaked it yet, will try other loads too as it should do 3A), and i've arrived to the final values for the RCD clamp on the primary.
        Now the last thing i need to do is a RC snubber for the diode as well, and we'll have a really clean PSU. Ripple is already very very low, as a matter of fact, the only thing i see on the output, after the pi filter, is the spike from the diode.
        • PeteS in CA
          • Aug 2005
          • 3578
          • USA, Unsure of Planet
          One general way you can check stability and transient response would be to create a dynamic load with a load resistor in series with a MOSFET driven by a 555 timer free running at somewhere around 100Hz-1KHz. That assumes you have access to an oscilloscope. Looking at the O/P voltage in AC coupling, if you see oscillation, ringing or a large overshoot in both directions, you probably have marginal stability or the circuit is not stable. On the other hand, if you see undershoot (when the MOSFET turns on) and overshoot (when the MOSFET turns off) your bandwidth is too low (i.e. the regulator is too slow). It's not as definitive as doing stability plots, but it's easier and quicker if you want a general idea.
          PeteS in CA
          • Th3_uN1Qu3
            Believe in
            • Jul 2010
            • 6031
            I know about that. I just drive the MOSFET connecting the load from my computer with audio generator software.
            • caspian
              What Zener Diodes on a Linear Power Supply
              by caspian
              Dear members,
              I have a linear variable power supply with unknown brand name that I used for voltage injection.
              Then it failed. I discovered that its transistors (Q1 and Q2) are shorted.
              In addition, I discovered that its zener diodes are defective.
              I can replace the burned transistors.
              But I do not know the model of the zener diodes. the model number is not marked on the zener diodes.
              Therefore, I cannot replace the zener diodes.
              I do not want to test the zener diodes in a test circuit to discover their model or value.
              no schematics are available...
              05-26-2025, 12:38 PM
            • nev1001
              What zener diode might fix the sound on Maestro Mayhem gaming chair?
              by nev1001
              Hi, I'm looking for a bit of help trying to fix the audio unit from a Maestro Mayhem 4.1 gaming chair please.
              The chair has a few speakers and vibration motors. All was well, for a while, but now the sound is gone.
              It may be significant that I discovered my son was powering it with a 19V laptop charger when it should run on 12V - it did fully work, for bit.
              I think an issue could be a zener diode (or capacitor) which has shorted out.
              The board's bluetooth input still works, the vibration motors are working, so is the line out socket but not the...
              04-17-2025, 05:09 PM
            • Msb1xr
              Have to turn on 77” LG C1 multiple times to get to come on
              by Msb1xr
              Have to turn C1 on and off multiple times for it to fully come on
              Have to run LG C1 on multiple times for it to fully work
              If I have it off for a while I have to turn the TV on and off and handful of times for it actually display what it's suppose. The times it doesn't nothing comes up like the input or dobly vision logo. Once it's on I can turn it off and back on fine and the picture looks perfect.
              Unhooked everything except antenna. Reset tv to factory settings. Let it sit and when I tried 2hrs later turned TV on and sound comes through but no picture....
              10-13-2023, 04:09 PM
              NTE Electronics “NTE5251K” Zener Diode 9.1V @ 50W Do-5.5% Want to build a 9.1 output from a 9.6 lipo4 battery pack
              I have bought this Zener Diode for this project what size and wattage resistor value do I need to use to get near 50 watt output
              I bought this from an eBay seller but unfortunately they only had one
              I bought three from Vetco Electronics these are Sylvania ECG5185A 9.1@10w A to Stud what size and watt resistor do I need to use to get near 10 watt output
              I bought three of from them to also make battery packs with this output power limit in mind
              I want to use this battery pack and turn it into a 9.1 output battery pack output to eliminate using 9 volt battery...
              04-23-2025, 05:50 AM
            • unimatrix93
              TV backlight zener diode
              by unimatrix93
              Hello everyone, I'm repairing an LG TV backlight and I noticed some strange behavior when I touching the backlight strip with a missing Zener diode.
              So I replaced the leds on the strips and they seemingly working fine, but soon as I touch the strip which has a missing Zener diode the whole backlight turns off for a few seconds and then turns back on.
              Is this caused by the missing diode? If so what kind of zener diode should I use to replace it?.
              The led strips has 9 6V leds.
              02-10-2025, 12:13 PM
