Why would an ultrasonic cleaner KILL a board
  • xboxhaxorz
    • Jan 2011
    • 196
    I had a mainboard that worked and booted no problem but was filthy to increase the life of the board i tossed it in my UC and upon taking it out it would not boot
    I have revived water damaged boards in my UC before, so for it to be a life saver and a killer puzzles me
    Thoughts??
    Re: Why would an ultrasonic cleaner KILL a board
    May be the MLCC (Multi Layer Ceramic Capacitor) cracked and shorted out?
    • 999999999
      • Sep 2006
      • 774
      What exactly does it do when you attempt to power it on? Where in the boot process does it fail?
      Does it beep? Does it keep fans spinning and PSU running? Does it post at all?
      Have you tried it out on a desk with only bare minimum components installed that are needed to make it boot?
      Have you checked that the battery has enough voltage and tried clearing CMOS?
      If all the above look ok, I would suspect either a cracked solder joint or ESD damage, possibly only corrupting the bios (EPROM) contents if you're lucky and have a way to reflash it.
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
      • m1ch43lzm
        by m1ch43lzm
        05-12-2025, 08:37 PM
      • howardc64
        by howardc64
        07-24-2025, 05:17 PM
      • Hakuu
        by Hakuu
        Hi There,
        More Details
        TV Model - LG OLED77G1PUA
        07-12-2023, 02:37 PM
      • jb_Bak
        by jb_Bak
        CN6401
        Pin 01 NC
        Pin 02 NC
        Pin 03 "BL_ON": 0V
        Pin 04 "N/C"
        Pin 05 "STBY 3.3V": 3.5V
        Pin 06 "GND": N/C
        Pin 07 "AC_OFF"...
        09-27-2021, 04:52 PM
