Super solder sucker vacuum pump
  • xboxhaxorz
    • Jan 2011
    • 196
    I am interested in some sort of solder sucker that is basically a vacuum ie; i turn it on and it will suck the liquified solder
    The solder suckers that are sold for a few bucks are not the type i am looking for. When i remove a BGA chip i clean the solder balls with a Hakko FX which works well, however i am always looking for new ways and new things. I figured a sort of touchless cleaning would work much better.
    After the BGA is removed i would use a air wand to keep the site hot while moving the vacuum over the pads sucking the solder. That is the idea i want to accomplish.
    I would appreciate any suggestions in creating such a device or modifying some other devices for this
  • t.j.
    • Apr 2010
    • 383
    • canada
    Re: Super solder sucker vacuum pump
    like a egg sucker works(used in making easter eggs)! except with air to drive it! so as to no be gummen up a suction system!
    • MORETTIGIAN
      Capacitor detached from PCB – RTX 2070 Super Founders Edition
      by MORETTIGIAN
      Title:
      Description:
      During maintenance on an RTX 2070 SUPER Founders Edition, I found a capacitor lying on my desk after reassembly.
      I did not notice it detaching, so I am unsure of its original location on the PCB.
      Procedure performed:
      - Removed backplate
      - Cleaned heatsink and PCB with isopropyl alcohol + soft ESD brush
      - Reapplied thermal compound
      - Reassembled card
      Observed behavior after reassembly:
      - GPU powers on and operates normally under...
      09-18-2025, 12:14 PM
      ZD-915 vacuum pump motor mount service alert
      by sam_sam_sam
      If you have this Desoldering Gun Station there is something you should be aware of the two screws that hold the motor to mounting for pump can come loose and make raddling noise
      One note this unit has been repaired already once because of switching power supply regulator ic chip failure
      Now this with the vacuum motor mounting issue yes I give this Desoldering station a very hard work out and use about every weekend to do some type of project
      The fix is taking the vacuum pump assembly out and take the metal cover off and you will see the two screws on it
      09-19-2021, 02:15 AM
    • corrize
      Best way to solder LVDS connector for beginner (and qfn) ?
      by corrize
      Hello, I'm a beginner for micro soldering. Right now I have some difficult to solder a qfn 20, I guess I put too much solder on the thermal-ground pad, the result is a corner of chip wich don't touch the board (last try).
      I use a wire solder with hot air, I tin the board and chip before with iron and I use good flux.
      I will have to solder a LVDS connector (40 pins, laptop pc), I saw a solder paste in seringe, good quality (it does not scatter).
      See the test :
      https://youtu.be/bNAzC-EvqHs?t=1767
      With hot air from bellow the board, that's...
      03-09-2023, 02:57 AM
    • Destroyer-Br
      [HELP] Acer AN515-55 (LA-J871P Rev: 1B) – Board won't power on after GPU investigation – Suspecting Super I/O or PCH
      by Destroyer-Br
      I'm working on an Acer Nitro 5 unit with the following specs:
      • Motherboard: LA-J871P Rev: 1B
      • Model: Acer AN515-55-59MT
      • S/N: NHQ7JAL00403906A973400
      • SNID: 03902728734
      Initial Issue
      The laptop initially presented graphic issues and driver failure (Code 43) for the GPU.
      After preventive maintenance (cleaning, thermal paste, etc.), it powered on normally. We disassembled it again to inspect the GPU, reassembled...
      04-17-2025, 08:18 PM
    • flat-earther
      Hoover FM216LI cordless vacuum refuses to charge
      by flat-earther
      I have a Hoover FM216LI cordless vacuum which isn't charging its internal battery.
      I opened up the unit, and it has 6x Samsung ICR18650-22P cells connected in series.
      5 cells were at about 3.3-3.1V. one was at 2.4V, so I assumed this cell was bad that's why the vacuum wasn't charging so I replaced it with another 18650, but after that the problem still persists, the vacuum turns on a bit and then cuts out since the batteries are empty.
      So I think the over discharged battery wasn't the culprit, it was a symptom of the unit not being able to charge its batteries....
      06-06-2025, 03:14 AM
