Hello, I was just wondering about your thoughts on getting resistors from Ebay?Is this a bad idea or are they a pretty safe component to get from anywhere? Thanks!
Resistors ok from Ebay?
Tags: None
Re: Resistors ok from Ebay?
I never had any trouble getting resistors off of E-bay. I bought some nice little blue ones (I think 1/8 watt). They look beautiful and work just fine. I believe they're a bit newer though. I have taken resistors off of electronics that were made 10-20 years ago and they tested and worked fine.Last edited by Spork Schivago; 09-24-2012, 07:49 PM. Reason: Worded some sentences a bit different like-- Law of Expanding Memory: Applications Will Also Expand Until RAM Is FullComment
It's not worth it for me to buy from eBay - I don't have the patience to wait 2-4 weeks for them to come from China and pay 2$ in bus tickets and waste 2-3 hours of my life to go all the way to the other side of town at the customs office to pick the package
I can get a 50 pack of those 1/8w resistors for 1$ on Farnell, and to my country the shipping's only about 5-6$ and the guy comes with the package at my door in 3-5 days.
Already have a large selection of the most common resistors, simply used to add a few types of resistors to order for other parts so they added up.
I'm probably going to buy smd resistors in the future for my own hobby projects and prototypes, 805 sized resistors are not that hard to solder, not to mention it saves me from drilling holes into pcbs.
And they're super cheap, somewhere around 17-30$ for a roll of 5000 resistors.
With smaller quantities it's just a bit more expensive, about 1.5$ for 100 pcs.Comment
I think there is a possibility that 1% (or lower) resistors might be actually 5% units from some bad sellers.My first choice in quality Japanese electrolytics is Nippon Chemi-Con, which has been in business since 1931... the quality of electronics is dependent on the quality of the electrolytics.Comment
Ok thanks for the input Guy's. Does anyone know if digikey has like a assorted lot of resistors or Leftovers from when they are discontinued lots?Comment
Not really. Though they do discounts with larger quantities. Just click on sort by quantity, enter an approximate quantity you want and you get the reduced prices.
They do have "Chip Outpost" which is a sort of "overstock" or repository for inventory of older chips, no longer manufactured or old :
http://www.digikey.com/chipoutpost/en
You can't find many resistors, but it's a good place to get diodes, bridge rectifiers, various ics (shifters, opamps) ..
For example, where can you pick 10k 1N4148 for 50$ : http://www.digikey.com/product-detai...13-CHP/2287241
If you want new, the cheapest would be about 80$ at 10k quantity.Comment
by TinkerTronHey everyone,
I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
Instead, here's what's been bugging me so far:
The schematic...3 Photos-
by DXseekerMOHello everyone!
Recently I've noticed that some ShopJimmy backlight strips don't have double-sided tape installed upon them when an application calls for it, and I must purchase the tape separately. In a recent chat conversation with a customer service agent I told them if this tape wasn't applied when it was called for I would begin to consider ordering my backlight strips elsewhere. It looks like this time may have come.
I recently got a TCL 65S4 with bad backlights. After looking at the SJ listing here: https://www.shopjimmy.com/tcl-jl-d65...365as-m-led-ba...Yes0%1All backlight strips are the same quality0%1No0%0 -
by brightest_zHi All - I'm in the midst or reprogramming the bios on my gen1 Surface Laptop Studio and I accidentally blew away 2 resistors nearby the bios. I don't have another board to measure values of the missing resistors and schematics aren't available, bbut the bios is a 6x5mm Winbond WSON8, W25R256JWPQ model. The traces are conductive to Pins 3 and 7 (IO2 & IO3 respectively) so I have reason to believe they are 10k pull up resistors since IO2&3 pins are used for Quad SPI instructions.
Does anyone with more knowledge, and experience than I, know if this is the case?
by jinu_jHi Folks
This has to do with a LED light driver rated for Output - DC36-65V 300mA. This is used to drive a 15W LED panel light.
Now this does not work so opened up and found 2 resistors burnt to crisp. Sensing a learning moment, i looked around the circuit to figure out that it is built around the OB2538 chip. The circuit to a large extent follows the sample application circuit mentioned in the data sheet. I have traced the actual circuit and the same is also attached for reference.
But i have some queries on this circuit
1. The resistors that burnt to crisp... -
by repair-itI am trying to determine why these two resistors are the colors that they are. This is a Pioneer amp. The ones I am concerned about are the RED & GREEN colored resistors. I need to replace them and want to be sure to use the properly rated component....
- Loading...
