230V light bulb power drain at 115V??
  • Behemot
    • 4845
    • CZ
    I got two lamps 230V/100 W together for loading UPSes after battery swap. The thing is, I got arround 7 UPSes for american power grid (115V), but only one 230/115 transformer. So I will renew only one of them. (I can use them for powering Cisco Catalysts, they eat 115 V as well)
    But the problem is, I do not know what to load it with. I do not want to use any ordinary PSU because of power factor, light bulb is ideal for me. They will work at 115 V, sure, but what would be their power drain from at 115 V? I need the most exact number if possible to determine battery capacity (whether it +- correspond with new bats capacity).
    Re: 230V light bulb power drain at 115V??
    What is the make and model number of the US UPS?
    • Behemot
      • 4845
      • CZ
      It is some Manhattan. And yes, I had a look, it is only able to work from 110-120 V/50-60 Hz grid, no greater range. Thats written directly on it.
        Usually the model number will indicate the VA rating, for example APC-850 is 850VA (550W).
        • Behemot
          • 4845
          • CZ
          Its 1200 VA. I don't really see how is this helpfull? I need to know what power a 230V lightbulb (60+40 W) will drain on 115 V (UPS's output). Than I will let it run on batteries and from the runtime calculate battery capacity. Than I will compare it with nominal capacity and see whether it corresponds somehow, or I will have to do some calibration.
          I do that with 230V UPSes just fine…here is the problem that I obviously do not have 115V bulbs, you see
            1200VA UPS will have 790Watts Rating this will tell you how much your batteries will have to at least supply the power to the load, so the the run time will depend on your batteries AH rating. You have True RMS DMM with AC amp function right? Just put the meter in series with your lamps to take current readings and another True RMS meter to read the voltage then calculate the Wattage. Now do you see why the VA that I ask does matter? You can still use your 230V lamps as the load, all you care is how much power your lamps are drawing from the UPS. I use heat element for testing ou UPS products.
            http://www.engineersedge.com/battery...ry_ratings.htm
            http://gbindustrialbattery.com/Batte...H_Ratings.html
            http://www.dcbattery.com/faq.html
            • Behemot
              • 4845
              • CZ
              Been thinking about that, yeah. Because on ohmic load you can just multimply current and voltage to get power drain even on AC, right, as there is no power factor
              I know what batteries I will use very well - highest capacity what could be squeezed inside every UPS In this particular case they are the same as original - 2x17 Ah 12 V. Thats 408 Wh nominal.
                "Been thinking about that, yeah. Because on ohmic load you can just multimply current and voltage to get power drain even on AC, right, as there is no power factor" That is correct, that is why the resistive load is used since PFC will be = 1.
                • Behemot
                  • 4845
                  • CZ
                  Yep, that is why I have chosen that, cause of knowledge it will drain current corresponding to those 100 W and nothing more.
                  Just have to be carrefoul, U know, messing with 115V cables arround is not too safe, not mentioning my multimeter can handle currents over 200 mA only for some short time…
                    Your meter cannot do 10A AC? I deal with with voltage at 6000V 3000A for surge testing everyday.
                    • Behemot
                      • 4845
                      • CZ
                      Yep, 10 A for a few seconds only…but I am not sure whether it even is for AC, have to have a look.
                        master hoarder
                        • May 2008
                        • 12175
                        If it's a cheap 830 variant, it's only for DC. I *think* you may be able to use a diode to rectify it in order to measure it.
                        • Behemot
                          • 4845
                          • CZ
                          Yep, its DC only. Wouldn't rectifying increase voltage?
                          • joshnz
                            • Feb 2011
                            • 969
                            • New Zealand
                            The 2 lamps in parallel will use around 100 Watts at 115 volts.
                            My pc
                            CPU : AMD PHENOM II x4 @ 3.5Ghz
                            MB : ASUS M4A89TD PRO USB3
                            RAM : Kingston ValueRAM 16gb DDR3
                            PSU : Cooler Master 850W Silent Pro
                            GPU : ATI Radeon HD 6850
                              master hoarder
                              • May 2008
                              • 12175
                              No.
                              AC line voltage is measured as RMS, but the actual peak of the AC wave (the amplitude) is near sqrt(2)*line voltage... so ~311 V peak for 220 VAC RMS and 325 V peak for 230 VAC RMS.
                              • Behemot
                                • 4845
                                • CZ
                                Yes, but RMS multiplied by current equals to power for resistive load. Not sure whether the power will stay the same after rectyfing for higher voltage (means also higher current than, even though not linearly due to the temperature).
                                  "The RMS value of an alternating current is also known as its heating value, as it is a voltage which is equivalent to the direct current value that would be required to get the same heating effect. For example, if we applied 120 V AC RMS to a resistive heating element it would heat up by exactly the same amount as if we had applied 120V DC."
                                  So for the generator to produce the same power as 120VDC, the generator will have to put out 338.4V Peak-to-Peak or 120VRMS.
                                  So "The 2 lamps in parallel will use around 100 Watts at 115 volts." is correct. I used resistors/lamps for loading every day when I work on AC voltage regulators for both US and Euro products. Our biggest AC regulator is rated at 230VAC 30A, weights about 100lbs.
                                  http://en.wikipedia.org/wiki/True_RMS_converter
                                  • Behemot
                                    • 4845
                                    • CZ
                                    Well, I am just not sure whether it works on light bulbs 100 %. Their power drain is heavily dependent on temperature…
                                      That is why you let the resistors or lamp reach its temperature in the control room that maintain ambient temperature, beside you will used calibrated AC amp meter and AC RMS volt meter both with graph outputs to monitor the load to make the calculation.
                                      • Behemot
                                        • 4845
                                        • CZ
                                        I mean temperature of the wire inside bulb. It increases its resistance with great margin cause of temperature over 1000 °C.
                                        • repair-it
                                          TOSHIBA DLP 52HM95 How to reset timer module on bulb
                                          by repair-it
                                          I replaced the bulb only on my Toshiba DLP The bulb is a TB-25. This is the first time I've done a bulb only replacement. Supposedly there is a timer module that needs to be re-calibrated or reset. I don't know where the module is located. I see some vendors selling the bulb with the housing stating module included which leads me to think the module is located inside the enclosure the bulb mounts in, but I didn't see it. Maybe it's inside the plug attached to the bulb?
                                          Anyway - I am seeking information on how to reset this so called module so that the lamp will operate. Apparently...
                                          10-11-2023, 07:18 PM
                                          LG Gram Ultra-light Weight Notebook Specification for Upgrade or Repair
                                          This specification for the LG Gram Ultra-light Weight Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-light Weight boardview and Ultra-light Weight schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-07-2024, 03:40 AM
                                          LG Gram Ultra-Light Laptop Notebook Specification for Upgrade or Repair
                                          This specification for the LG Gram Ultra-Light Laptop Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-Light Laptop boardview and Ultra-Light Laptop schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-06-2024, 09:10 PM
                                          09-06-2024, 08:40 PM
                                        • serious_electron
                                          Strange! Acer laptop not powering on but charging the battery (orange light on when charger and battery plugged in).
                                          by serious_electron
                                          Hello Everyone!
                                          I have an Acer Aspire A315-42 laptop. I generally leave it on for long time by closing down its lid (so it enters the sleep mode). Recently, it rained quite heavily in out area. And the humidity and moisture seem to be high. So one late evening, after I opened the lid and turned on the laptop, it did power on as the blue light turned on but after it booted to the desktop screen, just 5-10 seconds after both the screen and blue light went out and laptop shut down (the blue power light turned orange). And after 2-4 seconds that orange light went off and the laptop died.
                                          06-28-2025, 02:57 PM
