Dummy load for testing laptop chargers
  • JonathanAnon
    • Jul 2012
    • 457
    • Ireland
    Hi guys, I'm sure I'm missing something obvious here, but I've gone through quite a few videos on testing laptop chargers But none seem to suggest an accessible dummy load to test them... like the way that they normally suggest you use car bulbs to test 12V rails.
    They all seem happy enough just to connect the red to the inner pin and the black to the outer pin, and take that as the result, without testing under load. Anything about the house I could use as a dummy load for ~19V 4.24A charger?
  • b700029
    Banned
    • Sep 2010
    • 640
    Re: Dummy load for testing laptop chargers
    2 12V lamps in series, of the appropriate wattage.
    • mariushm
      • May 2011
      • 3799
      You could try to build yourself a few of these :
      http://www.sleepyrobot.com/?p=136
      Schematics and everything under the image. Each should do about 1-1.2 A of load as far as I can tell from the forum posts on eevblog.
      It's based on this video : http://www.youtube.com/watch?v=8xX2SVcItOA
      another dummy load here: http://forums.adafruit.com/viewtopic.php?f=44&t=28487
        You need 5 Ohms 80 Watts resistor to about full load. So if you do not have any resistor like that in your house, you can use two 100 watts home light bulbs in parallel, resistance will go up a bit when the filaments heat up, you just have to monitor the voltage and current draw to see if your power supply can handle it, just add more lamps as needed. I use this setup for dummy load. The lamp resistance can rise as much as 10~15 times the cold resistance when lamp is at full voltage.
        • JonathanAnon
          • Jul 2012
          • 457
          • Ireland
          Yeah, I was thinking about the two 12v in series, just thought there might be something easier.. I soldered the two bulbs together in series and it did the job alright. I'll use it in future. Appreciate the other suggestions guys..
          • JonathanAnon
            • Jul 2012
            • 457
            • Ireland
            Was down at the electrical wholesalers today for RJ45 ends, and I asked the guy did he have any bulbs that were 25V... He gave me a 25V / 60W bulb for a couple of euros, so I have my 25V source which will pull 2.4A ..... I'm gonna buy one of these to house it (instead of having to solder wires to the bulb itself..
            Then I just need to work out some way of attaching the different jack sizes, as the different laptop adapters have different size DC coax ends.
            • JonathanAnon
              • Jul 2012
              • 457
              • Ireland
              Okay guys here's what I've got so far:
              I've drilled two 4mm holes in the 5A connector so that you can safely check the voltage from the adapter.
              The idea is that you grip the outer connector of the dc coax connection (usually the ground), and fix the brown wire to the centre pin (usually hot). Another alternative would be to buy the different coax cords and connect the appropriate one for your particular laptop to the 5A connector box.
                Did you check the cold resistance of that 25V (odd voltage rating) 60WATTS bulb?
                • JonathanAnon
                  • Jul 2012
                  • 457
                  • Ireland
                  Why would that be important Bud?... It's 25V and 60 Watt so I would assume
                  that it draws 2.4amps and the resistance is ~10 Ohms..
                  It's a special bulb.. I asked them in the electrical wholesaler if they had a 20V bulb and that was the closest they had..
                    Just want to make sure it is not someting like 1 Ohms when cold which can cause the power supply to go into over current shutdown. Its resistance when fully hot 25v at 60 Watts is about 10 Ohms, but when cold it can be 10 time LESS. Just check it with your Ohm meter, light bulb has positive resistance characteristic.
                    • JonathanAnon
                      • Jul 2012
                      • 457
                      • Ireland
                      hmm, The resistance IS 1 Ohms when cold... But I havent had a charger that did not work with it... Is it possible that the thermistor in the SMPS is counteracting the possibility of overcurrent?
                        That is what I thought, the cold to hot can be 10 times.
                        It can be that some power supply is better design with lots of head room, or bad designed with slow response to over current without going into current limited mode.
                        • AJ847.63e
                          Testing ATX PSUs under load - Does loading the ATX 24 pin also load EPS & PCIE?
                          by AJ847.63e
                          Hi Folks,
                          Just wanted to clear up a misunderstanding of mine (or what I expect is one). Isn't the 12V rail from the 24 pin, EPS and PCIE separated? IE if I put a power resistor on the ATX 12V pin that is not going to load, thus tell me if the EPS or PCIE rails are fine?
                          I was recently watching ArIs from Hardware Busters video on how to properly test ATX PSUs without using 5 figure Croma substations.
                          The PCB adapter he used breaks out the 12, 5 and 3.3V pins from the 24 pin and gives you banana plugs to connect to. That is a bit useless is it not? Aren't...
                          05-06-2025, 10:37 PM
                          Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook Specification for Upgrade or Repair
                          This specification for the Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum boardview and Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from...
                          09-06-2024, 09:30 PM
                          Microsoft Surface Laptop Surface Laptop 2 Notebook 2 Specification for Upgrade or Repair
                          This specification for the Microsoft Surface Laptop Surface Laptop 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 2 boardview and Surface Laptop 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                          09-06-2024, 08:47 AM
                        • RdeveLabs
                          MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
                          by RdeveLabs
                          To all the members here...
                          Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
                          So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
                          05-05-2025, 04:59 AM
                          Microsoft Surface Laptop Surface Laptop 4 Notebook 4 Specification for Upgrade or Repair
                          This specification for the Microsoft Surface Laptop Surface Laptop 4 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 4 boardview and Surface Laptop 4 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                          09-07-2024, 06:11 AM
