Parallel Battery Configurations for mobile phone battery
  • alick
    • May 2011
    • 31
    hey guys i got a question about Parallel Battery Configurations?
    this is what I want to do!
    take two of these batteries http://www.ebay.ca/itm/New-Battery-L...#ht_500wt_1396
    take em apart and rebuild it with then both in parallel so i can get double the mAh out of it! it 3600mAh each so I would get 7000mAh battery.
    I am wondering if this is possibly at all?
    would it be as easy as taking them apart and just putting them together or would there be some advance configuration I would have to do so it would stay at 3.7volt??
    would it be safe or should I just get two batteries and use one at a time?
    is there any downside to any of the above setup?
    or should I just find a battery that has the same voltage and enough mAh that i would want and just change the terminal to fit the phone??
    I try to look on the google and have not found anything useful pertaining to what i want to do.
    any Advice would be greatly appreciated
    Thanks in advance.
  • kikkoman
    • Jul 2007
    • 691
    Re: Parallel Battery Configurations for mobile phone battery
    It can be done.
    It is done a lot with large R/C LiPo battery packs. But mind you, these tend to blow up a lot more often than consumer stuff. And they're usually soft-shell LiPos that first puff when they go bad; LiIon cells have steel cases that contain the pressure until they burst.
    Those R/C cells, at least the better ones, are matched cells that ideally have identical internal resistance in order to prevent bad things.
    not to mention that cell phone battery capacities, especially the cheap ones, are exaggerated most of the time. I doubt this one has 3.5Ah.
    If you really need the capacity, go with something like this:
    http://www.hobbyking.com/hobbyking/s...gle_Cell_.html
    Also make sure you've got a reliable charging setup.
    "Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin slitting throats." - H.L. Mencken
    • sdtv
      These have tabs and are about the best out there.
      http://www.ebay.ca/itm/PANASONIC-186...item5ae7abe218
      • 999999999
        • Sep 2006
        • 774
        Your phone has enough empty space to put twice as big a battery in it as it already had? If not, that would seem to be a significant downside.
        • alick
          • May 2011
          • 31
          Thanks for the info
          O that battery from ebay does work and has 3500mah I have one now and it last 2.5 times on her then the stock 1500mah I did some charge and usage time comparison and it's good but I want something more I just worry it may go boom if I run it in parallel.
          I will check that link out later when I get home. I thanks for all the info keep Em coming!
          • Bowline
            by Bowline
            06-11-2025, 10:13 AM
          • mkdj
            ASUS X571 no power : battery issue?
            by mkdj
            Mark and model: ASUS X571
            Symptoms: not turning on. There is only the LED battery indicator working. The owner of the laptop told me this problem arrived one week after having changed the battery. He then managed to power on the laptop only once, and then it never powered on again.
            Tests already made:
            - Battery is charging when laptop is plugged in. The LED battery indicator turns white after a couple of hours of charge, indicating that battery is fully charged. However, laptop won't turn on anyway, with or without AC plug.
            - I have removed...
            07-14-2025, 09:16 AM
            Brother “P-Touch” PT-2040SC modified with metal hydrate AAA 700 milliampere hour battery pack originally for cell phone
            by sam_sam_sam
            I have gotten so tired of battery cells leaking and it happen to this device and it is not very old I had bought these battery packs from The Electronic Goldmine for $1.00 a pack when they had a sale and I am putting 3 packs to good use so I do have to deal with leaking battery cells I am over it
            I bought the label maker at Sam Club a while back for $29.99 it come with 4 cartridges and they had them on sale again for $29.99 again so I bought another one because I was not sure if I was going to able to get it to work on the battery cells that I had planned on using for this particular...
            05-26-2024, 10:44 AM
          • techfreak9356
            Vostro 3400 (LA-K033P) won't charge battery, everything else ok
            by techfreak9356
            I bought a Vostro 3400 motherboard (LA-K033P) to upgrade over my damaged Inspiron 5593 (LA-J091P) board. Everything else is ok except for the battery. This battery I am using now is already a replacement one since I disposed of the bloated original one. Back in the Inspiron 5593 motherboard, the battery charges fine and is identified just fine. However, with the upgraded motherboard, suddenly the replacement battery is labeled as "Not a dell battery". When I borrow a similar battery from my colleague (which did not have replacements yet), it is identified and charges just fine.
            09-14-2023, 11:10 PM
          • ferah831208
            Strange battery present behaviour in Lenovo Legion 5-15ARH05 mb model nm-d041
            by ferah831208
            Hello guys, i need help with this problem, I have a NM-D041 mobo, it came with low impedance in 3v linear regulator rail, the cause was a damaged EC controller ITE8227e-192. I ordered a new one and replaced it. This laptop have a different chip for keyboard management and it8227e pins for programming ITE chips are not accesible through keyboard interface, I flashed it using i2c interface pins with vertyanov programmer because laptop was dead and SPI flash didn't have power (only 3v EC) so it couldn't access firmware stored in SPI memory. I read SPI and extracted it8227 firmware from original BIOS...
            03-18-2025, 01:18 AM
