FET - Replace with same part?
  • kids
    • Oct 2005
    • 13
    I have shorted FET (76139S), but I dont kno to replace which other (same part/similar part)
    Please choose for me! Thank
    ____________________________________
    Printer Services: http://www.printerservices.info
  • PeteS in CA
    • Aug 2005
    • 3578
    • USA, Unsure of Planet
    Re: FET - Replace with same part?
    Looks like that's an obsolete MOSFET. The modern replacement looks to be a Fairchild FDB8896.
    PeteS in CA
    • re-atari
      Anycubic Photon 5.5 3D printer 25Q32 flashrom dump needed
      by re-atari
      Hello all, as the title says, I'm very much in need of a valid firmware dump of a Anycubic Photon 5.5 3D resin printer. It's stored in a Winbond 25Q32, so it's 4Mbyte.
      Here's a little background for my request. A few weeks ago I bought this 3D printer from a guy who had moved on to a PLA printer. I got it at a vey reasonable price, as it was in a defective state. The seller told me that he had experienced a power failure during a firmware upgrade, after which the printer appeared to be dead. He thought the firmware was corrupted in such a way that the printer was now bricked. As he...
      02-03-2025, 06:49 PM
    • G-Sting
      iPad Pro A1876 SHORT Part Identify Help Needed
      by G-Sting
      So My iPad was not charging and booting up . i went to a local technician and he checked with thermal and this Part marked in 1st Photo is Short.
      So then i went on to boardview and downloaded the schematics and identified this part in 2nd Photo. Now i am confused what exactly is the part called ? where should i get this from ?
      i contacted my technician and he sent me his BoardVIew screenshot in 3rd Photo. In his Boardview the part is called X2826.... Something
      SO My main concern is what part should i order what should i search the name for ?
      on Ipad...
      05-15-2025, 09:30 AM
    • Curious808
      Brother HL-2140 laser printer: printer error (solved)
      by Curious808
      SOLVED. I removed the printer in settings, replugged and let it reinstall and it worked this time.
      Windows 10
      Attempt to print and immediately get a Windows pop-up saying "Error printing". The document appears in the printer queue window with Status "Error-printing".
      Turned off printer. Unplugged, waited, replugged. Ran the Windows troubleshooter. Removed and reinserted toner cartridge. Checked for paper jam. No printer error lights. Reinstalled driver. Restarted the Spooler service. Rebooted...
      06-22-2023, 11:11 PM
    • Artefil
      HP officeJet 8012e ... A printer update will be installed to fix this problem
      by Artefil
      One of the partner I'm mostly working with, brought his Officejet 8012e, facing a problem I'm failing finding a solution.
      On the Officejet 8012e, there's only one USB connector on the back, for connecting the printer to a computer.
      The screen displays the following message :
      "a problem has occured with one of the printer's critical system files. A printer update will be installed to fix this problem"
      But even if the printer is connected through wifi to the network, nothings happen, and the printer stays idle for days.
      Have you ever...
      09-28-2023, 05:11 PM
    • jordanaudio1
      Samsung TV UN60KU6270F power supply
      by jordanaudio1
      Trying to learn electronics repair as a hobby. I have no formal training in electronics, circuits, etc. Everything I know, which isn't much, has been learned from watching youtube videos, reading books, forums, etc. This means, sometimes I have a hard time understanding and interpreting what's important when I look at datasheets, and such.
      My brother has a TV that I'm working on now. He said he was watching it, he heard a loud pop and it went off. I used my DMM to check the fuse, it was blown. From watching lots of hours of electronics repairs on youtube, I figured that was just a...
      07-07-2025, 07:38 PM
