Nichicon FW 10,000uf 50V - Fake?
  • LosNir
    • 3
    I've bought the following capacitors from eBay:
    http://www.ebay.com/itm/JAPAN-1PCS-N...item20bd6614a8
    The top looks like this:
    I have a suspicion that they are fake - I tried to disassemble one capacitor and all I found inside was the capacitor itself (dielectric & gel):
    However it wasn't neatly packed like the picture above - there was about 20% free space.
    Any comments?
    Thanks.
  • mariushm
    • May 2011
    • 3799
    Re: Nichicon FW 10,000uf 50V - Fake?
    It's dubious. The datasheet shows them with the bottom made like all the other Nichicons... not perfectly flat like in the ebay picture.
    The Digikey picture is also with a nicer gold shade but that may just be the flash or the guy's camera.
    http://media.digikey.com/photos/Nich...FW2A470MPD.JPG
    http://media.digikey.com/photos/Nich...222MHD_sml.jpg
    http://media.digikey.com/photos/Nich...FW2A102MHD.JPG
    but the eBay price is adequate, they're about 5$ on digikey (the 10k uF ones)
    • 999999999
      • Sep 2006
      • 774
      I would guess fake, the seller claims production date of 2010 but Nichicon hasn't made any with a phenolic disc at the bottom for many years, have they?
      • mockingbird
        • Dec 2008
        • 5486
        I say real. Date looks ok, 0518 - week 18 of 2005, dimension matches the datasheet (25x50mm), and looking at the sellers other listings, I think he only sells legit stuff. New old stock. It's not unusual for the weird color and material on some Nichicon series... I have some Nichicon caps from way way back that have white bunges with a hard, acryllic-like bunge.
        • PeteS in CA
          • Aug 2005
          • 3583
          • USA, Unsure of Planet
          The bottom looks like epoxy seal rather than a rubber bung. If I understand the online catalog info, it looks like epoxy end seal is standard for diameters larger than 18mm.
          PeteS in CA
          • LosNir
            • 3
            Thanks guys. I've took some pictures so it may be easier to identify the capacitor as fake / real.
            The bottom is some kind of a thick rubber ring with wood on the end.
            • mockingbird
              • Dec 2008
              • 5486
              2009 Week 22... So it's been sitting in storage for about 3 years and it hasn't bulged and the innards are still moist with electrolyte... Looks good to me. I'll have to remember to order one of those from a trusted Nichicon supplier to dissect and compare.
              • Th3_uN1Qu3
                Believe in
                • Jul 2010
                • 6031
                • Romania
                Looks real to me. That white font the date of manufacture is printed in - it always looks dodgy on the fakes (or it's not even there to begin with). Compare it with a Nichicon from a motherboard and you'll see it's the same font on yours.
                A working TV? How boring!
                • Uranium-235
                  Comrade Glimmer
                  • Aug 2007
                  • 5045
                  • US
                  um, how is there supposed to be an indication its bad? its supposed to bloat when bad, right? but it looks like all the gas would leak out where the leads go out
                  • Scenic
                    o.O
                    • Sep 2007
                    • 2642
                    ^ The larger diameter Nichicons have a rubber bung at the bottom and on top of that sits a disk (disc?) of some sort of PCB material, probably as a kind of reinforcement or something.
                    I've seen that quite a few times before.
                    When they go bad, they always pop their top vent, as the disk at the bottom is pretty solid. I think it's to prevent the rubber bung from getting pushed out (sending the can flying) instead of the top vent bulging and eventually popping open.
                    • PeteS in CA
                      • Aug 2005
                      • 3583
                      That disc is probably phenolic, which is used for PCBs. FR4 is much better. IMO.
                      PeteS in CA
                      • ben7
                        Capaholic
                        • Jan 2011
                        • 4059
                        These are real, I also have some similar to these, if anyone wants to see them, i can take pics.
                        -Ben
                        Muh-soggy-knee
                        • miepa
                          • Oct 2012
                          • Austria
                          Hi Guys,
                          i got exact same looking Nichicon FW 2200uF / 100V caps by a friend of mine
                          as they are shown here in post #6
                          https://www.badcaps.net/forum/showthread.php?t=20587
                          i`m also a little bit confused/worried about the disc on the ground of the Nichicon FW.
                          do you really think these are original Nichicon Caps?
                          @PeteS: could you tell me where you found that info "The bottom looks like epoxy seal rather than a rubber bung. If I understand the online catalog info, it looks like epoxy end seal is standard for diameters larger than 18mm. "
                          thanks,
                          michael
                          • ben7
                            Capaholic
                            • Jan 2011
                            • 4059
                            Originally posted by miepa
                            Hi Guys,
                            thanks,
                            michael
                            They are real.
                            The disc is to give the rubber bung some extra strength.
                            Muh-soggy-knee
                            • miepa
                              • Oct 2012
                              • Austria
                              Hi Ben7,
                              where did you find that info that nichicon uses that "disc"
                              is there any official statement of nichicon anywhere?
                              • ben7
                                Capaholic
                                • Jan 2011
                                • 4059
                                Hi Ben7,
                                No, I havent seen anything about them saying that. But I have seen plenty of large nichicon caps - old and new - with the reinforcing disc. I have seen some Marcon caps like this too.
                                Muh-soggy-knee
                                • Heihachi_73
                                  • 713
                                  I have a Nichicon SE 330uF 50V cap which also has a PCB disc over the bung. The dimensions are 13x20mm, which could hardly be called a large cap! This cap also has an interesting 8-section pie chart style design on the top instead of the usual X shape vent, and over the top is an extension of the plastic sleeve, which is a translucent blue (this cap is most likely not vented). The date code is H8130, making it over 30 years old (this was salvaged from a smashed 12V portable Philips TV set found on the road, and unfortunately the cap has two dents on the side).
                                  • abhi.1981
                                    Fake Nichicon 100uF 450v GN (M)
                                    by abhi.1981
                                    Just opened a fake Nichicon cap. Checked the technical data, and nothing matches. The capacitance and ESR are okay though. Interestingly, the legs are made of brass ...
                                    08-26-2023, 11:01 AM
                                  • DrewPhillips
                                    Capacitor Diarrhea - Nichicon PL Series
                                    by DrewPhillips
                                    Hello All, I have on the bench a couple of PSU's which have some failed Nichicon PL series caps. They didn't "puke" their guts through the top, but instead "diarrhea'ed" corrosive brown electrolyte through the bottom, down the legs and onto the board. On one cap, the electrolyte rotted the cap right off the board leaving 2 little stubs, and also corroded a trace on the foil side.
                                    The PSU's are Power-One MAP series and are ringing-choke topology. The semiconductors have date codes in 1993. The PSU's were used in a commercial application, fan-cooled. They had failed...
                                    03-02-2025, 10:18 PM
                                  • shovenose
                                    Fake GPUs on eBay and elsewhere
                                    by shovenose
                                    Was searching for GPUs. All such a ripoff right now. But just seeing if I happened to find a good deal. Personally I'm fine w/ the (legit) GTX1050 in my main PC. Good enough for the 10 mins of gaming I do every month. But we're trying to build a gaming PC for the BF on a budget and for now I lent him a little Optiplex I stuffed a 1030 in but was just hoping for something better.
                                    Anyway, found this crap: https://www.ebay.com/itm/194206843675
                                    Obviously fake since it has a VGA port. Reported it as well as another one I found from a different seller. I know it's really...
                                    06-19-2021, 08:56 AM
                                  • nick3092
                                    Mid/late 80's Nichicon Yellow Caps
                                    by nick3092
                                    I recently acquired a set of Bose Roomate speakers from the mid to late 80's. Basically the right speaker cabinet is completely passive, and the left one has the power transformer and amplifier circuit in it. Out of curiosity, I opened it up to see what the circuit looked like. Looks like they used all Nichicon VX (2x 4700uF/16v for smoothing off the bridge rectifier), a couple random Nichicon SE series sprinkled on the board, and what really caught my eye - 2 yellow sleeved Nichicon caps (both 1uF/50v with no real series marking. Below are pictures of the caps. The only thing not shown in these...
                                    08-28-2022, 03:56 PM
                                  • DXseekerMO
                                    Backlight strip quality, Amazon vs Ebay vs ShopJimmy. Is there really a difference?
                                    by DXseekerMO
                                    Hello everyone!
                                    Recently I've noticed that some ShopJimmy backlight strips don't have double-sided tape installed upon them when an application calls for it, and I must purchase the tape separately. In a recent chat conversation with a customer service agent I told them if this tape wasn't applied when it was called for I would begin to consider ordering my backlight strips elsewhere. It looks like this time may have come.
                                    I recently got a TCL 65S4 with bad backlights. After looking at the SJ listing here: https://www.shopjimmy.com/tcl-jl-d65...365as-m-led-ba...
                                    Yes
                                    0%
                                    1
                                    All backlight strips are the same quality
                                    0%
                                    1
                                    No
                                    0%
                                    0
                                    12-16-2021, 03:58 PM
