How to Read the value of my capacitor!?
  • bobx
    • Apr 2012
    • IRAN
    Hello.I have some tantalum capacitors with thses numbers on them;
    1. 100
    2. 220
    Would you please tell me what are their capacitances[ case 1 & case 2 ]?
    Thanks,
  • selldoor
    Slow Learner
    • Dec 2010
    • 7870
    Re: How to Read the value of my capacitor!?
    There does not appear to be an internationally recognised marking code for these.
    It would be impossible to say without a picture and then it would probably only be a guess.
    As example this page http://alasir.com/reference/kemet_tantalum_capacitors/ might suggest that they are 100*10^0 picofarads and 220*10^0 picofarads.
    • b700029
      Banned
      • Sep 2010
      • 640
      Tantalum might be 10uF and 22uF.
      The only way to be sure is to use a capacitance meter.
      • MORETTIGIAN
        by MORETTIGIAN
        Title:
        Description:
        Procedure performed:
        - Removed backplate
        - Reapplied thermal compound
        - Reassembled card
        09-18-2025, 12:14 PM
      • Prolog
        by Prolog
        12-01-2024, 08:27 PM
      • Agent24
        Dick Smith Q-1760 linear power supply filter capacitor question
        by Agent24
        I have acquired a used Dick Smith Q-1760 power supply - although the OEM is Manson Industrial
        It has at least one problem.
        The voltage control potentiometer VR2, 50K is faulty - going high resistance / open circuit in the CCW end and leading to the output voltage jumping around.
        I have already ordered a replacement potentiometer, so that's not an issue.
        Now, I want to replace all three electrolytics on the PCB as they are CapXon and I don't trust them so much, I will replace them with something better while I've got the thing apart anyway.
        All are CapXon...
        10-21-2025, 05:39 PM
      • chth96
        by chth96
        12-22-2023, 04:34 AM
      • chth96
        by chth96
        06-02-2024, 07:31 PM
