Help with equivalent regulator.
  • bilux
    uP0109: 2A Ultra Low Dropout Linear Regulator equivalent substitute
    by bilux
    I want to find a replacement for uP0109 8pins, and i found this parts:
    uP0109 is "2A Ultra Low Dropout Linear Regulator"
    RT9199 is "Cost-Effective, 2A Peak Sink/Source Bus Termination Regulator"
    FP6137C is "2A BUS TERMINATION REGULATOR"
    can replace uP0109​ by RT9199 or FP6137C ?
    11-01-2024, 12:00 PM
  • valente222
    help SG2701B01-7 panel chinese, would this integrated circuit be equivalent? Chinese IC CS601C regulator.
    by valente222
    Hi, I'm repairing this Chinese SG2701B01-7 panel. There isn't much information about it. The original part for the panel is a CSOT CS601C regulator. I can't find anything commercial on Aliexpress; there's only the CS601 without the final 'C'. They claim it's a variant. But will it be compatible? Well, my diagnosis on this screen is a video problem; the image is practically black, although there is HDMI communication. The LED light is on (backlight), but there is no VGL, no 3.3V, and no VSS. It seems that this IC is the one controlling these voltages. The monitor worked correctly for a moment and...
    05-12-2025, 03:42 PM
  • piernov
    NVidia bumpgate
    by piernov
    Just archiving everything related to bumpgate since most stuff has disappeared from Google. Maybe people will finally take the time to read some of it and stop shouting "reflow gpu" at every occasion but rather try to understand what the real issue is…
    Interesting parts about the failure analysis are "Why Nvidia's chips are defective" and "Why Nvidia's duff chips are due to shoddy engineering"
    May complete this post at a later date with more details.
    Basically issue is a combination of thermal dissipation of the chip with hotspot,...
    03-27-2021, 10:34 AM
  • playit
    diy - voltage injection possiblity with voltage and ampere regulator - possiblity ?
    by playit
    hello ,for diy voltage injector for short killer/finder -- is it possible to use something like this - LM317 DC Linear Regulator, DC-DC 4.5~40V Turn 1.2~37V, Step Down Power Module, Adjustable
    and ampere controller along (to make it zero amps ) with some addons(transistors diodes etc.) for it -- and use some 5v adaptor or 3.3v volt rail of my smps power supply as input and finally get 1v and zero amps for injecting voltage to find out short circuit component ? ..
    for source input -- can we use 3.3 -4 volt 18550 battery ?( i have some of those ) and then adding ampere regulator...
    02-26-2025, 05:39 AM
    ISL95831HRTZ ISL95831HRTZ-T ISL95831IRTZ ISL95831IRTZ-T Voltage Regulator Datasheet
    3+1 Voltage Regulator for IMVP-7/VR12 CPUs
    Compliant with IMVP-7/VR12, the ISL95831 provides a complete solution for microprocessor and graphic processor
    core power supply. It provides two Voltage Regulators (VRs) with three integrated gate drivers. The first VR can be
    configured as 3-, 2- or 1-phase VR while the second output is 1- phase VR, providing maximum flexibility. The two VRs share the
    serial control bus to communicate with the CPU and achieve lower cost and smaller board area compared with the two chip approach.
    Based on Intersil's Robust Ripple Regulator...
    11-05-2024, 03:24 PM
