Differential Mode Filter Design
  • iamakda
    • Mar 2012
    • 46
    • Denmark
    Dear All,
    I have a question regarding the selection of value of X-Capacitors that are used in Differential Mode Filters (EMI Filters).
    I have an Isolated Full Bridge DC DC Boost Converter of 3KW for which I have do design a input Differential Mode Filter. The inductor just after the dc source has a dc current of 100A over which a 40A (peak-to-peak) inductor ac current is superimposed which means that triangular current waveform of 40A (pk-to-pk). Vi=30 V.
    I have determined the corner frequency of LC Low pass filter as 90KHz.
    My first question is how can I calculate the Peak to Peak ripple voltage(out of the above defined current waveform of inductor) which a X-Capacitor must withstand?
    Second question is what value of X-capacitor shall I choose that can withstand the amount of ripple voltage that has been calculated in the first question I asked above?
    Your suggestions and help will be highly appreciated. I have also attached a picture for your convenience.
    Thanks.
  • PeteS in CA
    • Aug 2005
    • 3578
    • USA, Unsure of Planet
    Re: Differential Mode Filter Design
    iamakda, your question is definitely well over my head. I'm thinking that the capacitor ripple current capability might be critical as well.
    PeteS in CA
    • iamakda
      • Mar 2012
      • 46
      • Denmark
      ok if we think in terms of capacitor's ripple current, then what would be the ripple current which will pass through this x-capacitor? how i can calculate this ripple current and then what value of x-capacitor should I use?
      • iamakda
        • Mar 2012
        • 46
        • Denmark
        Dear PeteS,
        Please advice how can I calculate the value of X-Capacitor from scratch in order to design a Differential Mode Filter? Just to remind you I have found the cutoff freq. of filter is as 90KHz.
        Kindly help me out as I do not have any idea about it. Guide me please.
        I hope to hear from you.
        Thanks,
        Ishtiyaq
        • J_T
          Operating frequency for motherboard common mode inductor/filter
          by J_T
          I have a question - I have replaced the PSU on my own iMac Pro. However, when removing the motherboard I knocked of a 120 OHM 30% 0.3A small surface mount common mode inductor/filter (~0602 size) in the ethernet circuit near the female RJ45 port.
          The closest match I can find on Mouser is 120 OHM common mode inductor at 100MHz - my question is this frequency correct for a motherboard? The schematic for the motherboard only provides '120 OHM 30% 0.3A' and the TDK part number does not return anything in google.
          Sorry, I am not experienced hence a basic question.
          01-04-2025, 05:54 AM
          Corsair CX750M [Model 75-002019] - burned output toroid inductor
          by momaka
          Looks like I may need a little help from the PSU experts (or anyone really! ) I have a Corsair CX750M (Model 75-002019) that I picked up for free about 4 years ago. This is the PSU:
          So here’s what’s strange about this one: it appears to work normally (normal output voltages) and any PC is stable with it. However, after a while (typically 10-20 minutes, but time can vary depending on the load), there is a sweetish smell of burned magnet wire insulation emanating from the PSU. Upon opening the PSU after this happened (many times), I was able to confirm...
          09-19-2021, 08:44 PM
        • Crystaleyes
          Filter Cap AC Ripple Questions
          by Crystaleyes
          Hi all.
          Is there any other other cause of AC ripple other than a failing cap?
          I say this as I have a new 18000uF 15v cap which is showing about 1.5v of ripple when measured on a scope.
          Is it ever the case that a failing bridge rectifier causes ripple?
          05-20-2022, 08:13 AM
        • Bartoloni
          Lenovo S145 -15iwl vcore inductor warm.. looking with oscilloscope there is a spike.
          by Bartoloni
          Hi, i have a Lenovo S145 that after 20 seconds shutdown and restart (it's working correctly on thse 20 seconds)
          everything seems ok, but on Vcore inductor ( this is an i3 with just 1 switching power supply for CPU)
          there is an output to teh CPU with a spike.. seems that inductor can't handle the input...
          replaced the capacitor (330) and the inductor (R15) without any change
          any idea? very thank you!
          input of the inductor seems as usual... only strange thing is that the upper/lower voltages seems to be 21V (main power line is 19.3) ... but not sure this...
          12-09-2024, 12:42 PM
        • badcap111
          How to read inductor specs?
          by badcap111
          I have a broken samsung galaxy s10 with missing inductor. I want to replace the missing inductor and I have found some vendors. But I don't understand how to read the specifications of the inductor. The specs are:
          INDUCTOR-SMD;470NH,20%,2520,T0.8,0.029OH
          I understand that the inductor is 470 nH with 20% margin, and the size is 2520 or 1008 (imperial measure), but what do T0.8,0.0290OH mean? I can't find any explanation on the web.
          09-12-2023, 01:25 PM
