Seeking "Ripple Current Confusion" paper by Kemet
  • Junkrepair
    • 40
    Hey everybody.
    Trying to understand the meaning of ripple-current specs for capacitors, I've seen references to a paper apparently entitled "Ripple Current Confusion", by Kemet. I've found that the links to the paper are broken, and that it doesn't seem to be on Kemet's site.
    Can you post that paper or a good link to it?
    Thanks.
  • redwire
    • Dec 2010
    • 3912
    Re: Seeking "Ripple Current Confusion" paper by Kemet
    url works for me
    Ripple current is mainly about heat and the cap dissipating it while also having a long life. Cornell Dubilier has some better tech papers I recall.
    • Junkrepair
      • 40
      Yeah, hmm, that works for me now. Thank you.
      • Junkrepair
        • 40
        https://cdn.badcaps-static.com/pdfs/...fbffc7abcd.pdf
        Cornell Dubilier Aluminum Electrolytic Capacitor Application Guide
          HP ProDesk 400 G2 Mini + 2x Pro Slate 8 Paper Folio ProDesk 400 i5-6500 Specification for Upgrade or Repair
          This specification for the HP ProDesk 400 G2 Mini + 2x Pro Slate 8 Paper Folio can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 400 G2 Mini + 2x Pro Slate 8 Paper Folio boardview and ProDesk 400 G2 Mini + 2x Pro Slate 8 Paper Folio schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
          09-12-2024, 03:28 PM
        • CapSnap123
          Sensor on Aurora AS1018CD paper shredder doesn't work
          by CapSnap123
          I'm getting frustrated troubleshooting a paper shredder. The way the shredder normally works is when you turn the power on, nothing happens until you insert a piece of paper. There is an IR shredder in the shredder and inserting the paper breaks the beam and starts the shredder motor. But now the motor runs constantly, even when no paper is inserted. I've replaced the photodiode and the IR emitter. Also the relay makes a nice clicking sound so I assume it is working too. I don't know what else to check. Here's a photo of the circuit board. The red and black wires marked IR - go to the...
          04-20-2024, 03:57 PM
        • chth96
          Is it no harm to replace with capacitor without ripple current rating?
          by chth96
          When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
          Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
          But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
          Rubycon YK DataSheet (b...
          04-19-2024, 05:19 AM
        • Antonynl
          What are typical ripple voltages on a laptop motherboard?
          by Antonynl
          I have here a HP pavilion hp 15-cs2975nd with a 1.095v power supply that is driven by a FDMF3035. I do see about 80mV of ripple on my scope. I searched through the datasheet to find possible values of the ripple but I don't understand the datasheet well enough.
          So I have two questions:
          1) what is the typical ripple voltages of gpu/cpu on a laptop or pc mobo?
          2) what would be the max ripple of a FDMF3035 that drives an output of 1.095V?
          Would be nice to have a rule of thumb of say a percentage of the supply voltage to be an acceptable ripple voltage....
          12-09-2022, 06:51 AM
        • peterwang
          Samsung NP750QGK-KG3US BIOS program error seeking help
          by peterwang
          PCB:BA41-03025A BA92-25486B
          I opened the Modular Flash Image Tool-v16.50.00.1120 software and encountered the following error message. I am seeking help.
          08-14-2025, 08:15 PM
