Is it possible to determine flux type?
  • Agent24
    I see dead caps
    • Oct 2007
    • 5039
    • New Zealand
    A while ago I bought a Kester flux pen from Sparkfun electronics. Turned out I didn't read the datasheet properly and it's actually Organic ACID flux. Wondered why when I didn't clean it, bad things happened...
    Was tipped-off by something someone said on here, actually.
    Since I still wanted a liquid flux, I looked online and found that Kester also do #186 which is a liquid but rosin based flux - no acid - sounds much better!
    I looked on Sparkfun but they didn't sell it, then I looked on eBay and bought some there.
    I got it today and I think it's fake. I don't care so much, because I have bought some cheap Chinese paste flux and it works just fine, so if this works too, so what?
    But then I got thinking, what if this is also some kind of acid flux, even though they claim it's Rosin-based?
    I don't want to use it in that case, because I'd be afraid to get problems again.
    Does anyone know if there is there some way I could test the flux and find out what type it really is?
    -David VanHorn
  • cmj21973
    • 267
    Re: Is it possible to determine flux type?
    Look up your purchase history on ebay.
    Is seller rating in the high 90's?
    Under "Other item info" click on History (XXX) number of sold units.
    If alot of people have bought it and left good feedback, I wouldn't woory.
    With that said, fake flux on ebay does exist. Real way to tell is order same from Digikey, Mouser, or what in your part of the world and compare them side by side.
    http://www.bing.com/search?q=fake+so...=0-0&sp=-1&sk=
    • PCBONEZ
      Grumpy Old Fart
      • Aug 2005
      • 10661
      Rosin is an Organic Acid Flux.
      http://www.finishing.com/Library/flux.html
      http://en.wikipedia.org/wiki/Abietic_acid
      When they say 'Acid Flux' they are talking about inorganic acids that are much stronger.
      ~ Yeah, slightly confusing.
      Mann-Made Global Warming.
      - Dr Seuss
      • Agent24
        I see dead caps
        • Oct 2007
        • 5039
        • New Zealand
        I didn't know that, but this is why I thought #186 was a good one:
        The liquid flux I already had is the Kester 2331-ZX which is described as "Organic acid water-soluble flux" and in the datasheet it says "Flux residues after soldering must be removed as they are conductive and corrosive."
        The one I just bought is Kester 186 (or a knockoff of it) which says in the datasheet:
        "Although the fluxing ability approaches that of Type RA flux, residues after soldering are non-corrosive and non-conductive.... The use of a minimum of ionic activating agents and the inactive nature of the residue permits leaving the residue on circuit board assemblies for many applications."
        Thing is... if this flux I got is a knockoff, who knows what is in it? Is it safe to leave on (I am wanting to use it mainly for SMD parts which are hard or impossible to clean underneath of)
        Suppose I should really just buy another one from a known reputable store, shouldn't I?
        -David VanHorn
        • cellphonebooster
          Banned
          • Feb 2012
          • 5
          • india
          wat the hell.............confusing !!
          • PCBONEZ
            Grumpy Old Fart
            • Aug 2005
            • 10661
            There's concerns of acid.
            There's concerns of conductivity.
            They are related but not the same.
            No matter what kind it is it has to be somewhat acidic to remove oxygen from the solder pool.
            Those that say you can leave them assume everything reacts and it achieves an electrically non-conductive state.
            I don't believe everything works to 'ideal conditions' on every joint like they seem to think so I just clean everything no matter what the ads say.
            If you look at my first link up above there are three basic kinds of "Rosin Core" now, so just saying "Rosin Core" isn't enough to know what they are talking about anymore.
            - Dr Seuss
            • PCBONEZ
              Grumpy Old Fart
              • Aug 2005
              • 10661
              There didn't used to be this many different kinds of solder.
              As best I can remember when I was a kid there were three options:
              "electrical solder"[aka Rosin core back then] or "plumbing solder"[aka Acid core back then] or solid core [no flux core].
              I wasn't actually into electronics back then so if there was something else around I wasn't aware of it.
              Since then they've come up with wave soldering, SMD, lead free, and several other things all of which work better with 'adjusted' solder and flux chemistry.
              There's got to be over 100 different kinds of solder now.
              - Very hard to keep up with it all.
              - Dr Seuss
              • Agent24
                I see dead caps
                • Oct 2007
                • 5039
                • New Zealand
                Yeah, I try to do this now too, but like they said in the datasheet, how do you clean under a SMD IC which is against the board?
                Especially if there are traces under the IC and board is DIY and has no coating...
                -David VanHorn
                • PCBONEZ
                  Grumpy Old Fart
                  • Aug 2005
                  • 10661
                  Coat it and then glue/silicon the part down so flux doesn't get under there in the first place.
                  - Just a thought...
                  - Dr Seuss
                  • chth96
                    Is it good to use chemistronic flux off es835b for flux remover?
                    by chth96
                    I want to purchase any good flux remover But "chemistronic flux off es835b" is the most common flux remover in my nation..
                    Or I have to purchase "3m novec flux remover" which is quite expensive in my nation?
                    11-17-2023, 07:25 AM
                    Multifix 425-01 and 450-01 Rework Flux Datasheet
                    REWORK FLUXES Multifix 425-01 and 450-01 are tacky fluxes designed for use in a wide range of electronics assembly and rework processes. They represent a range of activities and residue levels to meet different customer requirements.
                    - No Clean Formulations
                    - Low residue
                    - Range of activity to deal with different component solderability
                    - Halide free
                    - Suitable for dispensing
                    - Compatible with solder coatings and/or No Clean flux cored solder wire product range
                    Both products are supplied in syringes or cartridges for application by dispensing....
                    10-07-2024, 06:02 AM
                  • evilkitty
                    Flux causing high resistance short?
                    by evilkitty
                    Now that my de-soldering gun is working i was able to remove this panel i made about a week before i noticed a issue the F segment of digits 2 and 3 would go out, digit 2 would go before digit 3, but would come back after the humidity got down from running the ac (note the weather outside is 30.5 / 74%; panel data is from a BME280)
                    Temp is on the left humidity is on the right
                    i noticed when the humidity got up one or 2 of the center digits on the right panel would loose a segment
                    The pin out looking down from the top is (note this is common cathode)...
                    07-17-2024, 09:38 AM
                  • chth96
                    How can I remove flux with the smallest rubbing?
                    by chth96
                    I have tried to bridging tiny broken trace which is shown in the below link,and I found that it is impossible to remove any flux after soldering task.
                    Is it possible bridging tiny broken trace - Badcaps - Capacitor Search Engine​​
                    Because the 0.02 mm copper wire is very very fragile,So It broke itself very easily whenever I tried to rub excess flux with cotton bud.
                    Is there any way to remove flux with the smallest rubbing or without any rubbing?
                    Any reply would be appreciated.
                    11-24-2023, 05:22 PM
                  • tony359
                    Non darkening Flux?
                    by tony359
                    I was watching a video from NorthWest Repair (The guy there is just doing such incredible repairs) and while he was fixing a bunch of pads on a GPU PCB, I saw this
                    I've been trying to fix some broken traces on a PS3 CPU for a while but one major issue I'm seeing with my AMTECH flux is that it gets tacky and dark very quickly and then it's a pain to remove and replace.
                    In the video Tony (I think it's his name) seems to suggest that I am just using the wrong flux?
                    Any thoughts or ideas?
                    Full video is here: https://w...
                    02-03-2024, 08:25 AM
