What can I replace SK and SL caps with?
  • Mad_Professor
    A Mech Warrior
    • Feb 2011
    • 1587
    Jamicon SK
    Su'scon SL
    So what do I replace them with?
  • mockingbird
    • Dec 2008
    • 5484
    Re: What can I replace SK and SL caps with?
    Those are both general purpose caps.
    • Mad_Professor
      A Mech Warrior
      • Feb 2011
      • 1587
      Can I replace them with low esr caps like FR, FM, HM, HE? Since I already have these on hand.
      • mockingbird
        • Dec 2008
        • 5484
        What are you using them for?
        • Mad_Professor
          A Mech Warrior
          • Feb 2011
          • 1587
          Psu/lcd
          • mockingbird
            • Dec 2008
            • 5484
            Be more specific... What part of the PSU? If it's around a VRM, then no, I would not recommend mixing caps with varying ESR.
            FR, FM, HM, HE
            ESR, lowest to highest: HM, FM/FR, HE
            • Mad_Professor
              A Mech Warrior
              • Feb 2011
              • 1587
              https://www.badcaps.net/forum/showthread.php?t=18654
              • PCBONEZ
                Grumpy Old Fart
                • Aug 2005
                • 10661
                They used GP caps in THAT!!!!!!!
                ~ What Fuckers!
                Considering the original are GP - something like LXZ, FC, PW are good enough.
                With that many caps I'd just do an order and save the better caps.
                Will what you have on-hand at least work?
                ~probably~
                There is such a thing as too little ESR but I haven't seen issues with a screen yet.
                Mann-Made Global Warming.
                - Dr Seuss
                • Mad_Professor
                  A Mech Warrior
                  • Feb 2011
                  • 1587
                  I'm going to recap the inverter while I'm at it.
                  But I have 470uf 100v SK on the input near the power cable coming from the PSU and 2x 220uf 100v SL on the outbound before the CCFL transformers.
                  Should I replace them?
                  • PeteS in CA
                    • Aug 2005
                    • 3581
                    • USA, Unsure of Planet
                    IIRC, Nichicon CA, CS and CY series are high quality, long life in inverter use.
                    PeteS in CA
                    • ben7
                      Capaholic
                      • Jan 2011
                      • 4059
                      Always use low ESR caps in PSUs, even if they were not low ESR to begin with.
                      -Ben
                      Muh-soggy-knee
                        by momaka
                        03-12-2025, 03:42 PM
                      • Paxman_Swede
                        by Paxman_Swede
                        Hello!
                        01-14-2025, 09:51 AM
                      • edith
                        Caps and how to find one to replace
                        by edith
                        Hello everyone I have a question. I have a laptop and his schematic. Can anyone tell me how to measure or any way to understand specific of caps so i can buy new one?
                        Also in case how can I understand if some caps of some dead Mobo i have, are ok to be replaced in my new motherboard which im trying to fix?
                        Thank you!
                        06-11-2023, 05:00 PM
                      • Mattz_GT
                        Which caps to replace: ECS P4M800Pro-M V1.0A
                        by Mattz_GT
                        It's feeling like this board has a case of badcaps, instability and reboots - and not wanting to necro a a very old thread, it seems the 680uF 4V are highly suspect.
                        I don't really want to blanket recap everything, but maybe the others around that area could do with being changed?
                        Equipment: I have a temperature controlled soldering station, read the bit where it says set to 400F, don't think I would have gone that high without reading that.
                        Spring plunger solder sucker, and some desolder braid... and a bit of good old leaded 60/40.
                        PS. Additional diagnostic,...
                        01-22-2025, 12:12 PM
                      • rewease
                        Replacement for the Siemens Bakelite caps in an early 1980s SMPS
                        by rewease
                        There actually was a time when early SMPS and late bakelite housed electrolytic caps coexisted in high end industrial gear. A friend of mine just got himself a CNC milling machine form that time with its first set of now 41 year old caps still installed in the PSU... and it's malfunctioning.
                        Two of the caps have already leaked slightly onto the board. I have not desoldered or measured any so far but they should qualify for replacement.
                        Now I'm wondering what to put in there as a replacement. First idea was state of the art low-ESR Nippon KY,...
                        09-17-2023, 12:53 AM
