Testing MB104 bridge rectifier
+ More Options
Posts
  • cmj21973
    • 267
    I'm need to know if this bridge rectifier is still good to use.
    The outer casing broke apart while removing it from the PCB. I can super glue it back together but, it has a small heat sink that attaches to it.
    DMM diode test:
    probe probe
    1) + - OL
    2) - + .986
    3) AC1 AC2 OL
    4) AC2 AC1 OL
    5) + AC1 OL
    6) + AC2 OL
    7) AC1 + .525
    8) AC2 + .528
    9) AC1 - OL
    10) AC2 - OL
    11) - AC1 .540
    12) - AC2 .527
    I'm thinking to replace it since I have to glue the outer case back together and bolt a heatsink back on it.
    Also because of the #11 reading.
  • Jack Crow
    It's a CLASOB!
    • May 2008
    • 823
    Re: Testing MB104 bridge rectifier
    CMJ,
    Rule of thumb.
    If the case is cracked the part is gone.
    Semiconductors and oxygen make a real poor mix.
    Don't trust it. Don't glue it. Toss it as fast as possible.
    As for testing, I use this gizmo.
    I call it my cheap curve tracer.
    With a scope in X/Y mode, you can use it to do a very quick check of diode junctions and other parts.
    With a diode across the probes the sharper angle where conduction happens the better the junction is.
    http://www.flickr.com/photos/9010884...8650/lightbox/
    Hope this helps.
    Jack Crow in VA
    "You are, what you do, when it counts"
    The Masso
    "Gravity, the quickest way down"
    Mayor John Almafi
    "You ever drop an egg, and on the floor you see it break?
    You go and get a mop so you can clean up your mistake.
    But did you ever stop to ponder why we know it's true?
    If you drop a broken egg you will not get an egg that's new?"
    MC Hawking
    • cmj21973
      • 267
      Originally posted by Jack Crow
      CMJ,
      Rule of thumb.
      It's like a ceramic cup with the internal components encapsuled in epoxy. I was more concerned with heat transfer and the super glue not holding due to temperature.
      I'll order a new one.
      • jetadm123
        • 2169
        Readily available through digikey:
        http://search.digikey.com/scripts/Dk...b104+rectifier
        • Steph.hen
          Bridge rectifier identification part number KPB305G
          by Steph.hen
          Hi all, a newby question about a bridge rectifier I'm trying to identify.
          I'm in the midst of reparing a battery charger in work which went pop, The bridge rectifier has shorted and took out a couple of other components. The rectifier in question has a part number KPB305G, and it looks like it's obsolete. Does any one know what I could replace it with?...
          08-29-2024, 09:52 AM
        • mpn78
          Fujitsu Q556, What capacitor for bridge rectifier?
          by mpn78
          Hello
          My Fujitsu Esprimo Q556 motherboards blew up. At least fuse, bridge rectifier and capacitor got damaged. I have changed fuse and bridge rectifier (DF1508S), but I don't know what capacitor it is (picture). I know that capacitors size is 47nF, but I don't know other specs for it. Can you help me to choose right capacitor for my motherboard?
          There is 240V AC on input side of bridge rectifier and 340V DC as output on capasitors side.
          Thanks....
          04-05-2022, 12:31 PM
        • EasyGoing1
          Reading input and output of bridge rectifier on the same scope?
          by EasyGoing1
          I have a 40 volt AC transformer that I put a bridge rectifier on, and I wanted to see the input signal and the output signal on the same screen on my scope, so I set one channel up with the test lead on one side of the input and the ground lead on the other side of the input, then I used another channel on the scope and clipped the test lead on the positive side of the output then the ground on the negative side of the output.
          When I connected the transformer to power, the wire that was connected between the ground lead on the second channel and the negative side of the bridge rectifier...
          06-26-2022, 12:52 AM
        • Ross Kohler
          Diagnosing South Bridge (FH82H370) on Asus H370-Pro Gaming Motherboard
          by Ross Kohler
          I'm learning about motherboard repair and I believe I've traced the issue down for the South Bridge on the particular motherboard I'm working on. My path of concluding that:
          - There's no sign of any attempt to power on when pushing the power button.
          - No PSON signal is reaching the 24-pin ATX connector.
          - The Super IO chip is receiving the PS_SWITCH signal from the power button and is relaying this signal back to the South Bridge.
          - The Super IO is not receiving the S_SLPS#_R signal back from the South Bridge
          - If I pull the Super IO S_SLPS#_R pin...
          04-16-2024, 09:36 AM
        • bauto601
          KDM 480W PSU upgrade succes! (opinions?)
          by bauto601
          Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
          A "nice" YoungYear unit? - Badcaps
          The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish....
          12-26-2023, 03:05 PM
