How to get the most bang for your buck?
  • Evil Lurker
    Warranty Voider
    • Feb 2011
    • 454
    I seem to have aquired a fairly decent collection of crap primary caps, ie 200v 330-470uf capxcom, sus'con, fuhjyuu so on and so forth.
    How do I get them to explode in the most violent manner?
  • Jack Crow
    It's a CLASOB!
    • May 2008
    • 823
    Re: How to get the most bang for your buck?
    EL,
    I suppose the idea is to build up pressure in the case.
    Quickly.
    I personally have not tried this method.
    The physics are 'sound', the act may not be.
    Guess you could start with line current.
    120vac at 15 amps might be a good start.
    Or you can use an old style incan lamp as an inrush current limiter.
    I would set off the first few items in a heavy plastic pipe to keep down the frag.
    Eye and ear protection is recomended.
    Do be safe
    Jack Crow in the less than free world.
    "You are, what you do, when it counts"
    The Masso
    "Gravity, the quickest way down"
    Mayor John Almafi
    "You ever drop an egg, and on the floor you see it break?
    You go and get a mop so you can clean up your mistake.
    But did you ever stop to ponder why we know it's true?
    If you drop a broken egg you will not get an egg that's new?"
    MC Hawking
    • mariushm
      • May 2011
      • 3799
      Put them in a sealed plastic bag in the freezer for a few hours.
      Get a broken lcd monitor, solder some wires where you have one of those 800-1000v rated capacitors for the inverter, plug the 220v caps there... power the board.
      Worst case, you'll get a ton of smoke.
        master hoarder
        • May 2008
        • 12170
        I say save them and wire them up in series (with 300 kOhm bleeder/load balancing across each). With 10 caps in this configuration, you can get almost 2 kV across them. Assuming they are all 330uF for simplicity, that gives you about 66 J of energy - that's quite a punch there. You can then use that energy to blow other stuff up, like smaller caps and whatnot. Just need to find/build a HV power supply to charge those caps. It shouldn't be too hard, though.
        Or if you just plain straight want to blow them out, find a cheap computer PSU (without PFC preferably) and attach one wire to hot ground and the other to the positive rail. You should have about 320 VDC. Now wire the cap you want to blow backwards to that voltage and it should blow up almost instantaneously.
        • severach
          • Aug 2007
          • 1055
          Am I the only one disappointed that the correct answer isn't a 50 cal?
          sig files are for morons
          • 999999999
            • Sep 2006
            • 774
            Fill with c4, insert probes, run.
            It would be more time effective to just buy firecrackers.
            • Evil Lurker
              Warranty Voider
              • Feb 2011
              • 454
              Ok I been thinking about it, and it seems the bigger the cap, the smaller the bang. You get a lot of fizzing and smoke but no real kabooms.
              I am thinking a capacitor bank may be the "funnest" use for them. The question is how should I go about charging it up?
              I'm thinking maybe about winding my own transformer. I have some semi decent size filtering toroids of unknown core composition. If I were to take some thin wire say, cat 5e strands and wrap say 10 rounds on one part of the coil and put a 1200v rated night light in series to limit the current flowing thru it, and an approximate number of turns in the equivalent ratio as a secondary winding and hook that up to a bridge rectifier, would it be possible to get a low amp voltage source close to 400v?
                master hoarder
                • May 2008
                • 12170
                Depends on how you set up the capacitor bank (i.e. caps in series or caps in parallel).
                - if in series, you can get a pretty high voltage
                - if in parallel, your maximum voltage cannot exceed the rating on any of the caps
                Note: you get more energy storage if the bank of caps is in series since U = 0.5 x C x V^2 where U is the energy, C is the capacitance, and V is the voltage.
                Note 2: if you choose to connect the capacitors in series, you need to put high-value resistors across the terminals of each cap to balance the voltage across. 100 kOhms and above recommended.
                If you want to use a small core and a thin wire, then the AC sent on the primary coil should be fairly high frequency (in the KHz range).
                As I gave you the suggestion in my previous post above the other day, I tried a small experiment with a monitor flyback and a computer PSU. I put about 20 turns around the exposed flyback core and hooked that to the unrectified output of the 5vsb of the computer PSU. Result - enough voltage from the flyback to make a small arc between the HV and return pins on the flyback from a 5mm distance. That's above 1 kV there, low current.
                Not where I live. I'd have to go to West Virginia or one of them states that lets you buy that stuff.
                I find it kind of funny (and a bit disturbing) that it's easier to buy a gun around here than it is to buy firecrackers.
                • lti
                  • May 2011
                  • 2547
                  http://www.youtube.com/watch?v=FiaxKYLRi5o
                  I wonder how well 5mm and 6mm diameter caps explode. I have a collection of small caps that have failed. I'll have to blow one up some day.
                  Maybe you could seal the vents on larger caps.
                  • Uranium-235
                    Comrade Glimmer
                    • Aug 2007
                    • 5042
                    • US
                    the best bang for your buck...
                    stick it up a deers ass, THEN apply 300v in the reverse direction
                    • jm1234
                      Reolink RLC-410-5MP - buck convertor
                      by jm1234
                      it's a PoE camera and it stopped working. Using thermal image I identified failing component U22 marked as 16AF which seems to be buck convertor TI https://www.alldatasheet.net/datashe...62569DBVR.html. I took it out and It is inteed shorted on the output. However, after I took it out, the resistance between the output pads (on the board) still shows 190ohm, is that bit low?
                      Another issue is, seems to me I must be missing one of the tiny resistors R810 that should make up the voltage devider for the buck convertor. Honestly I did this months ago, I cannot...
                      07-14-2025, 04:30 AM
                    • SluggerB
                      Best bang for the buck system you could build with native Win7 support?
                      by SluggerB
                      What would be the latest rev of hardware and CPU technology that would natively support Windows 7? I am fine slip streaming in USB3 drivers if the mobo only has those, but I am leary about building a ryzen system that has to rely on unofficial drivers from random message board posts
                      My primary usage is generally office type PC stuff,. but I run a few VM's so I would want to go heavy on the RAM (like 32gb which is heavy to me) but also light on the wallet. I already have a spare HDD so that could be left out of the equation.
                      Any build suggestions?
                      02-08-2021, 02:21 PM
                    • GGEZ
                      16IAH7H minor liquid damage around GPU buck. boardiew and schematic included.
                      by GGEZ
                      Hi. I have a lenovo 16IAH7H (NM-E231) with a small amount of water spilled on the RT8816CGQWGPU buck converter. When powering on, keyboard lights up, fans will spin slowly. CPU and GPU are getting hot. No image. Not via HDMI either.
                      Part number is PU4001. The liquid spillage looked minor so I cleaned it up with some alcohol and cleaned ups some crusty joints with solder and flux.
                      BoardView and schematic is provided. The buck converter diagram is on PAGE 107.
                      I'm inquiring about any troubleshooting tips like probe points to measure and such. I can...
                      08-19-2024, 03:18 PM
                    • pedrolopesbe
                      sapphire 5700xt NB691 buck wrong output
                      by pedrolopesbe
                      Hello there!
                      So, I have this sapphire nitro+ that is a pain as there's no diagrams of this specific model anywhere. Put that together with the fact I'm just learning.
                      This buck converter is giving me 275 mV output when it should give 1.8V, I'm not sure what exactly modulates this converter and I'm going to spend the day learning about converters.
                      Could be a faulty one, but I've already replaced it one time, have just another one left. I don't wanna mess up the other one if this is something damaging the component when I turn the card on.
                      Ah, I don't...
                      01-26-2025, 10:12 AM
                    • ZOrd_Z
                      Bang & Olufsen Beovision Horizon always in standby.
                      by ZOrd_Z
                      I every one!!
                      I have a Bang & Olufsen Beovision Horizon that is always in standby mode ( green light on ).
                      Main board is 715g7132-m0h-000-005k. Corrupted firmware? I have all the ok voltages in psu.
                      Any idea?
                      Thank's...
                      12-12-2024, 11:44 AM
