through hole repair??
  • asand1
    Oregon, USA
    • Oct 2011
    • 123
    I was recapping my evga nforce6200, and damaged a though hole. The thin metal lining is gone. Is there a way to repair it? Should I just junk the board? It was just a spare that had blown Sacon FZs anyway.
  • mockingbird
    • Dec 2008
    • 5484
    Re: through hole repair??
    On multi-layered boards, as in your case, it is rumored that the cap is still connected by the vias which run through the layers even if the pad is ripped from the bottom. I don't know how reliable this is though, because the way I look at it is, even if there are vias, the solder will still have to melt through the later so that the lead makes contact with the via. Most times when I ripped pads off completely on these said boards, the hole was small enough as it is, and my iron is only like 15-30 watts, so I doubt the solder was able to penetrate to the vias.
    On a single-layer board, it's easy. Just scrape away some of the laminate, and run the lead to the exposed area.
    • retiredcaps
      • Apr 2010
      • 9271
      Well I had written something, but mockingbird's explanation is much better.
      --- begin sig file ---
      --- end sig file ---
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        The thin metal lining inside the hole is called a via.
        Repair of those is hit-miss and the outlook isn't good.
        Some vias make connections to the other side of the board and that's it.
        Other vias make connections between layers of the board.
        You really can't tell just by looking at one.
        The usual cause for problems with vias and pads is too wimpy a soldering iron or too low a temp.
        The PCB material doesn't conduct much heat but with too 'cold' a tip you end up 'on the work' -longer- so the PCB material has time to absorb enough heat to melt a little and get soft releasing the pad or via.
        Mann-Made Global Warming.
        - Dr Seuss
        • Agent24
          I see dead caps
          • Oct 2007
          • 5008
          • New Zealand
          I read somewhere (probably here:http://www.qsl.net/n9zia/desolder.html)
          - that the glue holding the copper to the substrate actually loses about 80% of its strength when heated.
          How accurate that is I have no idea.
          -David VanHorn
          • PCBONEZ
            Grumpy Old Fart
            • Aug 2005
            • 10661
            I thought the copper was electroplated on.
            I'm pretty sure it is for the vias themselves.
            I understand that's how they make the connections to the middle layers.
            Quite possible both methods are used depending on what the board is and what they are doing.
            - Dr Seuss
            • Agent24
              I see dead caps
              • Oct 2007
              • 5008
              • New Zealand
              Sorry, should have been more specific, yeah the vias and through holes would be electroplated (I don't know how you'd do it any other way)
              It was just some additional information I thought was relevant to the subject of PCB damage, but should only apply to tracks\pads not the vias themselves.
              -David VanHorn
              • PCBONEZ
                Grumpy Old Fart
                • Aug 2005
                • 10661
                That's not what I meant.
                I thought the whole board was electroplated with copper before the etching.
                You might be right and the copper is glued on or maybe they do either/or depending on the board.
                Or maybe even the preferred method has changed over time.
                - Dr Seuss
                • Agent24
                  I see dead caps
                  • Oct 2007
                  • 5008
                  • New Zealand
                  Oh right. Yeah I wouldn't know for sure what they do now. I always thought it was glued on (that's what I always read) but that was often in books quite old.
                  -David VanHorn
                  • mariushm
                    • May 2011
                    • 3799
                    As far as I know they chemically deposit the copper inside the vias,until the exact diameter of the hole is reached (the holes are drilled slightly larger on purpose)
                    See at about 3:45
                    http://www.youtube.com/watch?v=SXsch...eature=related
                    • Agent24
                      I see dead caps
                      • Oct 2007
                      • 5008
                      • New Zealand
                      Yeah we established that already, but what about the copper already on the board for tracks\pads etc?
                      Do they glue or electroplate that?
                      -David VanHorn
                      • PCBONEZ
                        Grumpy Old Fart
                        • Aug 2005
                        • 10661
                        And the copper layers in between PCB layers on multilayer boards.
                        I had in my head it was electroplated on, but I really don't know.
                        - Dr Seuss
                        • mariushm
                          • May 2011
                          • 3799
                          If it's multilayer, I'm betting glued, as they have to bond the layers with insulation between them. The video I posted shows some sort of machine where they use heat and pressure to bond them together.
                          I think electroplating is used just to deposit layers of gold or silver on the pads - it would take a lot of time to deposit the copper tracks at that thickness on the fiber board.
                          There was another Youtube video where they showed every step of pcb manufacturing with a more classical production line, with lots of vats of liquid and chemical etching and less high tech machines but I can't find it now. That explained everything in more detail...
                          • severach
                            • Aug 2007
                            • 1055
                            Fix the board as normal and see if it operates. The power sections are usually quite simple with the front and back being ground and power so there's no need for vias to connect to internal layers.
                            If a trace on either side seems to go somewhere useful then there's probably no internal connection. If neither side seems to go anywhere then there probably is an internal connection. Many caps are in parallel. As long as you didn't damage the via closest to the inductor output then adding more capacitance at an undamaged parallel location would fix the problem.
                            Sometimes the only purpose for the via is to connect the front to the back. If so then extra care must be taken to ensure the soldering maintains this connection.
                            sig files are for morons
                              Sacon FZ revival experiment
                              by momaka
                              So after using capacitor bungs to repair the rubber feet on two laptops, shown here:
                              https://www.badcaps.net/forum/showpo...&postcount=548
                              … and here:
                              https://www.badcaps.net/forum/showpo...&postcount=585
                              … I was inevitably left with some paper rolls and cans from the Sacon FZ capacitors I “sacrificed”.
                              The paper rolls from these Sacon FZ caps looked absolutely bone-dry. The idea then occurred to me: what if I put a few drops of water on there? How (if at all) would that affect these already-failed capacitors?...
                              01-26-2022, 08:43 PM
                            • 13mh13
                              Aluminum SMD caps vs thru hole caps (reliability)
                              by 13mh13
                              The PCB motor for 1987 Technics SLP-120 CD player has slow spin-up issues. Similar to what another tech in the below video reported.
                              https://i.postimg.cc/kGrR6BpZ/image.jpg
                              I replaced the three bi-polar 47uF electros but that made no difference. The orig three bi-polar 47uF electros tested okay on my ESR M-tester.
                              I have not tested/replaced those alum. SMD electro PCB caps.
                              Are Al smd caps are more prone to failure (or degradation) than regular thru-hole electros?
                              All the thru hole electros I removed / replaced on this CDP (and most...
                              04-05-2024, 07:41 PM
                              no-name Radeon 9600 XT recap and cooler
                              by momaka
                              I've been seeing a lot of cheap-looking (but not always so cheap) no-name AGP video cards on eBay for a while. They started popping up quite a bit when the market for AGP cards became more alive all of a sudden due to interest in “retro” PCs. One thing that struck me about these cheapo cards is that they almost always seem to come with garbage caps - including the abominable Sacon FZ. That aside, though, I've been wondering about the rest of the quality (or lack of?) on these cards. So I decided to satisfy my curiosity yet again.
                              This one was actually suggested to me by ChaosLegionnaire....
                              11-06-2020, 07:54 PM
                            • LearningToRepair
                              How to correctly desolder through hole IC?
                              by LearningToRepair
                              Hi!
                              I tried to desolder through I had IC that I wanted to replace but failed. And now I came here to learn what's the correct way for doing this. I tried to use soldering wick but the capillary force kept solder in the hole. With soldering wick I only managed to remove the part of solder that was outside the hole. But the solder that was inside the hole never got out. And of course when I moved on to next pin the solder in previous hole hardened again so no matter how many times I did all the pins there was still solder in holes.
                              Question 1: what would have been correct...
                              07-19-2020, 04:01 PM
                            • NWArkGuy
                              Samsung UN65TU8000 - Panel Issue [ hole in ribbon cable ]
                              by NWArkGuy
                              Well, I will be the first to admit that I screwed up...
                              In attempting to replace the backlight in a UN65TU8000, I made a hole through one of the ribbon cables between the board that runs along the bottom of the back of the TV and the panel. This lead to a between a 1/4 to 1/2 inch vertical stripe running the full height of the image.
                              I don't have the experience; personally, to solder a bridging wire for the paths that were cut. So, I have been on the hunt for other Samsung TV's of similar size.
                              I have 2 that I have found and have in my possession. ...
                              10-12-2023, 10:13 PM
