its 1/8" and what resistor can i use to replace it.
What resistor is this?
Re: What resistor is this?
Originally posted by Vizor View Postits Purple not red.
I am from UK, but your radioshack is like our maplins from what I have read on the forum, (not much good) but I guess you would get it there
have you tested other components out?
another failed component possibily caused that failure
I sincerely doubt it's a 0.75 ohm resistor. It's more likely to be red,green, orange or yellow which is 25 x 1k/10k = 25kOhm or 250kOhm, with a +/- 5% tolerance. Look up at the picture, ignore the third column of colors - your bars are 1st digit , 2nd digit, multiplier and tolerance.
If you still have doubts, I suggest looking up a resistor with the same color combination on the board , desolder it and go to Radioshack with both. If you can't find similar one just go with the burnt one - maybe it's still good.
They should have there a multimeter that can test the resistance and tell you the exact value.
Or just ask for 25 kOhm, 250 kOhm and whatever else you think it may be, they're a few cents each. Then match the color bars.
V,
Just for the record, Radio Shack is not exactly useful for parts like this.
Ten ohms, sure, one ohm, not too likely.
Fractional ohm, most consumer meters can't read it with any degree of luck.
In our business sometimes you have to break down and actually buy the correct part from a supply dealer. Or you can piss away hours trying to cludge up something that half works.
Boils down to how much your time is worth to you.
Dollars or hours.
Much luck.
Jack Crow"You are, what you do, when it counts"
The Masso
"Gravity, the quickest way down"
Mayor John Almafi
"You ever drop an egg, and on the floor you see it break?
You go and get a mop so you can clean up your mistake.
But did you ever stop to ponder why we know it's true?
If you drop a broken egg you will not get an egg that's new?"
MC Hawking
heh that resistor is shot. i bought 100 of them off ebay for 5$ http://cgi.ebay.com/ws/eBayISAPI.dll...#ht_500wt_1413
pretty good deal considering the main companys want 7-9$ just for shipping alone
Quite possibly, or you read the colour code wrong.
If you're sure the colour code was right (If you're having doubts, read the thing outside on a sunny day) then it could well be something else is shorted\faulty and is making the resistor blow."Tantalum for the brave, Solid Aluminium for the wise, Wet Electrolytic for the adventurous"
-David VanHorn
