What resistor is this?
  • Vizor
    • Nov 2011
    • 215
    its 1/8" and what resistor can i use to replace it.
  • mariushm
    • May 2011
    • 3799
    Re: What resistor is this?
    Use this to determine... or a multimeter. I can't tell from the camera and light you use.
    • trebo
      • 514
      • Wales, UK
      red, green, silver, gold, = 0.25 ohm
      • Vizor
        • Nov 2011
        • 215
        its Purple not red.
        • Vizor
          • Nov 2011
          • 215
          is their a replacement for this at like, radioshack persay?
          Here is what i need it for Power supply board.
          • trebo
            • 514
            • Wales, UK
            its Purple not red.
            violet, green, silver, gold, = 0.75 ohm 5% tollerance
            I am from UK, but your radioshack is like our maplins from what I have read on the forum, (not much good) but I guess you would get it there
            have you tested other components out?
            another failed component possibily caused that failure
            • Vizor
              • Nov 2011
              • 215
              i don't see any 0.75 ohm 5% tollerance at radioshack unless i am blind.\ and i am pretty sure i caused the failure
              • Vizor
                • Nov 2011
                • 215
                what resistors could i put in parallel to get 0.75 ohm 5% 1Watt or 2Watt
                • mariushm
                  • May 2011
                  • 3799
                  I sincerely doubt it's a 0.75 ohm resistor. It's more likely to be red,green, orange or yellow which is 25 x 1k/10k = 25kOhm or 250kOhm, with a +/- 5% tolerance. Look up at the picture, ignore the third column of colors - your bars are 1st digit , 2nd digit, multiplier and tolerance.
                  If you still have doubts, I suggest looking up a resistor with the same color combination on the board , desolder it and go to Radioshack with both. If you can't find similar one just go with the burnt one - maybe it's still good.
                  They should have there a multimeter that can test the resistance and tell you the exact value.
                  Or just ask for 25 kOhm, 250 kOhm and whatever else you think it may be, they're a few cents each. Then match the color bars.
                  • Vizor
                    • Nov 2011
                    • 215
                    Its a 1 watt 0.75 5% violet, green, silver, gold you can see the colors in the picture.
                    • Evil Lurker
                      Warranty Voider
                      • Feb 2011
                      • 454
                      I agree.
                      • Jack Crow
                        It's a CLASOB!
                        • May 2008
                        • 823
                        V,
                        Just for the record, Radio Shack is not exactly useful for parts like this.
                        Ten ohms, sure, one ohm, not too likely.
                        Fractional ohm, most consumer meters can't read it with any degree of luck.
                        In our business sometimes you have to break down and actually buy the correct part from a supply dealer. Or you can piss away hours trying to cludge up something that half works.
                        Boils down to how much your time is worth to you.
                        Dollars or hours.
                        Much luck.
                        Jack Crow
                        "You are, what you do, when it counts"
                        The Masso
                        "Gravity, the quickest way down"
                        Mayor John Almafi
                        "You ever drop an egg, and on the floor you see it break?
                        You go and get a mop so you can clean up your mistake.
                        But did you ever stop to ponder why we know it's true?
                        If you drop a broken egg you will not get an egg that's new?"
                        MC Hawking
                        • Evil Lurker
                          Warranty Voider
                          • Feb 2011
                          • 454
                          I use my ESR meter on low value resistors... works great.
                          • Vizor
                            • Nov 2011
                            • 215
                            heh that resistor is shot. i bought 100 of them off ebay for 5$ http://cgi.ebay.com/ws/eBayISAPI.dll...#ht_500wt_1413
                            pretty good deal considering the main companys want 7-9$ just for shipping alone
                            • Vizor
                              • Nov 2011
                              • 215
                              Okay so i got the resistors changed one in and it blows instantly once power hits the board, could a mosfest or something be causing it to short out instantly?
                              • Agent24
                                I see dead caps
                                • Oct 2007
                                • 4949
                                • New Zealand
                                Quite possibly, or you read the colour code wrong.
                                If you're sure the colour code was right (If you're having doubts, read the thing outside on a sunny day) then it could well be something else is shorted\faulty and is making the resistor blow.
                                -David VanHorn
                                • mikey5791
                                  Need help to replace burned resistor in 350w atx psu
                                  by mikey5791
                                  Hi to all forum members,
                                  Got this faulty 350 watt atx psu dirt cheap from a local online seller as i am keen to use it as a learning tool to repair faulty power supply.
                                  The faulty part is quite obvious from the burn area near the 16pin KA7500 BD pwm. The fuse is still intact with good continuity.
                                  Upon power on ac, there is 5vdc standby power on cathode of diode D14 and about 10vdc on cathode of diode D13.(This should be the aux power to generate the 12v and 5v rail.)
                                  Initially i replace the two burned resistors near my marked red arrow to 200 ohm resistor...
                                  12-26-2024, 04:55 AM
                                • chth96
                                  Is it okay to replace 1/2 watt resistor with 1 watt resistor in AC/DC adapter?
                                  by chth96
                                  I have purchased an 100-240v AC/5v 2a DC adaptor from aliexpress,and a month ago It smelled burning when I plugin it powerstrip.
                                  Since then, This AC/DC adaptor have been out of order.
                                  But A few days ago,I replace 0.5 watt resistor with 1 watt resistor(1ohm) in this adapter.
                                  After replacing resistor,It succeed to recharge all of android phone.And When I measure voltage on the two pins of USB port,It shows 5.5v
                                  And Is there any possibility that it will suddenly explode as well as to be out...
                                  12-03-2023, 04:40 AM
                                • unimatrix93
                                  Which resistor should I remove/replace to decrease current to backlight leds?
                                  by unimatrix93
                                  Dear community, I want to increase the lifespan of my backlight led in my TV by decreasing the current.
                                  However I need some help identifying the resistor I need to replace to achieve this.
                                  Thank you!
                                  11-29-2024, 05:05 AM
                                  Acer Swift SF114-34-P25P + Pack Gold Acer 14'' Notebook 1 Specification for Upgrade or Repair
                                  This specification for the Acer Swift SF114-34-P25P + Pack Gold Acer 14'' Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SF114-34-P25P + Pack Gold Acer 14'' boardview and SF114-34-P25P + Pack Gold Acer 14'' schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
                                  09-07-2024, 03:10 AM
                                  Acer Swift SF114-34-P2H0 + Pack Gold Acer 14'' Notebook 1 Specification for Upgrade or Repair
                                  This specification for the Acer Swift SF114-34-P2H0 + Pack Gold Acer 14'' Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SF114-34-P2H0 + Pack Gold Acer 14'' boardview and SF114-34-P2H0 + Pack Gold Acer 14'' schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
