Mystery zener diode
  • joshnz
    • Feb 2011
    • 969
    • New Zealand
    Mystery zener diode
    It is marked ZL30L I believe it is a 30 volt zener from the circuit it came from.
    it was working till I shorted the output
    Was outputting 28volts if i remember correctly.
    My pc
    CPU : AMD PHENOM II x4 @ 3.5Ghz
    MB : ASUS M4A89TD PRO USB3
    RAM : Kingston ValueRAM 16gb DDR3
    PSU : Cooler Master 850W Silent Pro
    GPU : ATI Radeon HD 6850
  • joshnz
    • Feb 2011
    • 969
    • New Zealand
    Re: Mystery zener diode
    Well I have put in 30volt zener but it is getting HOT so i guess the transister is damaged.
    you can see i put a watt meter in to monitor the zener looks fine.
    My pc
    • Longbow
      • Jun 2011
      • 623
      What type of circuit is this? Is the cathode of the zener grounded, or does it go directly to the wattmeter? Easy enough to test both the zener and the transistor with a multimeter.
      Is it plugged in?
      • joshnz
        • Feb 2011
        • 969
        • New Zealand
        Hi here is the actual circuit with the removed test equipment.
        The 2 transformers are actually one just could not find one in multi sim
        The zener shorted when I shorted the output waiting for replacement transistor to arrive as the old one does not give normal results.
        My pc
        • unimatrix93
          TV backlight zener diode
          by unimatrix93
          Hello everyone, I'm repairing an LG TV backlight and I noticed some strange behavior when I touching the backlight strip with a missing Zener diode.
          So I replaced the leds on the strips and they seemingly working fine, but soon as I touch the strip which has a missing Zener diode the whole backlight turns off for a few seconds and then turns back on.
          Is this caused by the missing diode? If so what kind of zener diode should I use to replace it?.
          The led strips has 9 6V leds.
          02-10-2025, 12:13 PM
        • hobostove
          Corsair RM1000e - Help identify 5VSB Zener diode
          by hobostove
          Hey there guys. I've got a Corsair power supply that's come across my bench dead. I usually don't mess with power supplies, but it's a slow week so I'm giving it a whirl.
          Taking it apart I heard a screw rattling around inside, and when I got it apart I found a couple blown components near what I think is the 5VSB area.
          There's a 22ohm resistor that's melted and open, but it still has the bands.
          The other part is a zener diode and it's top went to jesus, so I can't read the marking.
          It looks like the diode connects the source and drain of a TNY284...
          03-27-2025, 02:25 PM
        • debidoobs
          Yamaha delay D1500, zener diode broken with no marking
          by debidoobs
          im actually trying to save a d1500 delay from yamaha. I found the service manual but schematic is missing and BOM list is a bit unclear as components listed have no reference linked to the pcbs... In my case, one zener diode was broken (114 code on the pcb in attached file) and couldn't be repaired : it was a zener type package. In the BOM list i found 3 reference on this board : 1S555 (can be replaced by 1N4148), RD4.7EB2 (approx 5v rectifier), RD7.5EB3 (approx 7v rectifier)...
          Actually the cathode goes to VCC of sram M5M5118P, without this diode missing, i have...
          04-24-2024, 09:01 AM
        • Dvsr
          On M-Audio AV40 active studio speaker's two zener diodes get really hot.
          by Dvsr
          Hi. I need help from wiser guys. I am amateur in electronics and can't figure this out by myself.
          I bought faulty speakers, M-Audio AV40's. Other speaker has all the electronics in it and the other speaker is just passive one powered by the other speaker's amp. Original problem with the speakers was loud buzzing. I figured out that there is something wrong with the capacitors. I went ahead and replaced every electrolytic capacitor on the PCB. The caps are good quality and have the same values as the original ones.
          After replacing the caps I started testing out the speaker. It seemed...
          09-10-2025, 10:20 AM
        • caspian
          What Zener Diodes on a Linear Power Supply
          by caspian
          Dear members,
          I have a linear variable power supply with unknown brand name that I used for voltage injection.
          Then it failed. I discovered that its transistors (Q1 and Q2) are shorted.
          In addition, I discovered that its zener diodes are defective.
          I can replace the burned transistors.
          But I do not know the model of the zener diodes. the model number is not marked on the zener diodes.
          Therefore, I cannot replace the zener diodes.
          I do not want to test the zener diodes in a test circuit to discover their model or value.
          no schematics are available...
          05-26-2025, 12:38 PM
