Need a new roll of solder what to buy?
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: Need a new roll of solder what to buy?
    Originally posted by PCBONEZ
    60/40 is a great choice but I prefer 63/37 unless I can't find it.
    It's melting point is about 7°C lower than 60/40 so it 'gets going' a tad quicker.
    The big difference is 63/37 is a eutectic solder vice 60/40 which is non-eutectic.
    Non-eutectic solders [like 60/40] have that semi-solid state between solid and liquid so if a joint is moved during that stage it can result in cold solder joints.
    Eutectic solders [like 63/37] do not have the semi-solid state and solidify instantly so they are less likely to produce bad joints if you bump the part or work table at just the wrong time.
    That said, it's a really minor difference [couple seconds] and more of a style/preference thing than anything else.
    In the Navy we always got the 63/37 when we could because soldering in 'a room' that's bouncing and vibrating like a speeding flatbed with out of balance tires adds another element of challenge to getting the job done.
    noted. I have used both and I have seen that yeah, 63/37 melts at a lower temp... next time I need solder, now i know what to get next time.
    sigpic
    (Insert witty quote here)
    • ratdude747
      Black Sheep
      • Nov 2008
      • 17136
      well, it turns out that i did run out and bought new solder.
      I went to frys and bought some MG chemicals solder at $25 for a 1lb spool. it was the last spool of 1lb 63/37 no-clean they had on the shelf... in fact, most of the no clean stuff was either out of stock or close to it. (even the RA fluxed stuff was elling well).
      it seems to be stiffer than the kester 44 60/40 i used to use (and still have 1.5' left of).
      it works just as well as the kester if not better... the quality is the same.
      may be worth noting for future reference
      sigpic
      • Agent24
        I see dead caps
        • Oct 2007
        • 5085
        • New Zealand
        Not bad, what diameter? I like something around 0.6-0.7mm for general work.
        -David VanHorn
        • ratdude747
          Black Sheep
          • Nov 2008
          • 17136
          same as before, i think maybe .8mm?
          I'll check when I go to my basement.
          edit- it is 0.032", or 0.8128 mm. I was close!
          sigpic
          • acedogblast
            by acedogblast
            11-02-2024, 05:13 PM
          • corrize
            Best way to solder LVDS connector for beginner (and qfn) ?
            by corrize
            Hello, I'm a beginner for micro soldering. Right now I have some difficult to solder a qfn 20, I guess I put too much solder on the thermal-ground pad, the result is a corner of chip wich don't touch the board (last try).
            I use a wire solder with hot air, I tin the board and chip before with iron and I use good flux.
            I will have to solder a LVDS connector (40 pins, laptop pc), I saw a solder paste in seringe, good quality (it does not scatter).
            See the test :
            https://youtu.be/bNAzC-EvqHs?t=1767
            With hot air from bellow the board, that's...
            03-09-2023, 02:57 AM
          • petemanuk
            BGA solder balls not connecting - help pls
            by petemanuk
            So I though in my spare time I’d set myself up repairing motherboards mainly pin damaged lga1151 sockets types.
            I’m using an achi ir sc pro rework station (gave up on my Achie ir6500 - don’t recommend)
            I’ve managed to get my rework profile somewhere in the correct region (after a lot of trial and error) to get the old sockets off and reflow new ones back on again, the problems I’m getting is not all of the solder balls are re-attaching when re-flow occurs. I know this because when socket is removed pads still look clean and have no solder...
            11-16-2022, 05:21 AM
          • myth77
            UV solder mask - high temp resistent, recomendation?
            by myth77
            Can someone recommend any good UV solder mask? But i need a solder mask that will stand high temperetures. The thing is...sometimes i have a bigger cooper ripped from the board, lets say mosfet pad... i reconstract it with cooper sheet, then i "glue it" with solder mask...then i use UV light...and let it cool a bit. After, i try to clean the cooper of extra solder mask..and till that part all is ok. But, when i use a soldering iron to solder that pad/cooper...the solder mask gets weaker or destroyed and finally the pad is ripped again from the board .
            Is there any solder mask...
            03-28-2022, 04:04 AM
            Multifix 425-01 and 450-01 Rework Flux Datasheet
            REWORK FLUXES Multifix 425-01 and 450-01 are tacky fluxes designed for use in a wide range of electronics assembly and rework processes. They represent a range of activities and residue levels to meet different customer requirements.
            - No Clean Formulations
            - Low residue
            - Range of activity to deal with different component solderability
            - Halide free
            - Suitable for dispensing
            - Compatible with solder coatings and/or No Clean flux cored solder wire product range
            Both products are supplied in syringes or cartridges for application by dispensing....
            10-07-2024, 06:02 AM
