Identifying capacitors
    None of these caps are bulging - just curious if anyone knows about them.
    (#1) Capacitor with an "S" on it. No other identifying marks, apart from capacitance and voltage. I think it's Samxon, but there's space to put SAMXON there so why didn't they? The green color is consistent with some Samxon capacitors.
    (#2) Another "S" capacitor but it doesn't seem like a Samxon because it has a non-Samxon vent...
    (#3) Another capacitor is by Daewoo. I thought they made cars...! Maybe they make industrial equipment too.
    (#4) This one LOOKS like a Chemicon. It has the shield. But the shield has a small dot in the centre, which I have not seen before. Also, the series is "SMS", and I can't find any results for that particular series. The closest is "SM".
    From an LCD TV: LG LE-15A15 (15" monitor / TV.)
    Other capacitors in this monitor: Samwha, Samyoung and G-Luxon (plus probably a few more - not checked everywhere yet.)
  • lti
    • May 2011
    • 2557
    Re: Identifying capacitors
    I have an old modem with one of those "S" caps on it. There is a picture of this cap on the same modem here. I posted a picture of the other side of that cap. I was wondering who made it as well.
    • varkatope
      Need help identifying capacitors on an MSI MS6163 ver 1. motherboard
      by varkatope
      Hey there, retro fans.
      I have an MS6163 version 1 board I'm trying to repair which was obviously used as a donor because it's missing a few parts, mostly capacitors. There are few high quality images online that would allow me to read the capacitor values (bad angle, blurry photos). I thiiiink I've figured out most of the values for the missing ones except for one in particular, number C210, which is in the bottom-left of the attached photo. Could someone with this board be so kind as to take a look at theirs and tell me the capacitance and voltage values of all the highlighted missing...
      12-15-2024, 09:48 AM
    • dragon3x
      by dragon3x
      power on.
      Here are some examples :
      switching supply area).
      than 6.3 V.)
      03-21-2025, 02:46 PM
    • slybunda
      AA and AAA battery charger capacitors?
      by slybunda
      hey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
      it has inside:
      2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
      2 x 470uf 16v LZ105c branded as G.Luxon
      not heard of these brands are they any good?
      iv attached photos of the charger and the board inside for an idea on the type of...
      12-24-2023, 04:41 AM
      After all of...
      07-13-2024, 08:14 PM
    • Cama
      Solar Inverter - SMH-II - 2 missing capacitors
      by Cama
      I need help to find the value of 2 missing capacitors ( C102 and C117) on my Easun SMH-II mainboard (solar hybrid inverter). I circled it in red on the close-up picture. The 2 old capacitors are completely missing, so I have no reference. Does anyone have this board and can tell me the value or make an educated guess based on the location ?
      My model is : EASUN SMH-II 7 KW
      Mother Board : P/N 18947-002401250250
      Maybe the EASUN SMH-II 4.2 KW have the same capacitors
      Thank you...
      09-12-2025, 02:50 AM
