VideoPhone screen not working
  • pentium
    • Mar 2006
    • 2778
    I purchased three AT&T VideoPhone 2500 units and all three worked until (and I assume this is totally unrelated) I pulled the battery on one, then the LCD stop displaying anything other than a black or white screen.
    Because I had two other working phones I swapped parts around until I concluded that the issue lay in the logic board above the screen the camera was attached to. Further testing found that when the phone was powered up a Sony CXD1254AR Camera sync and timing signal generator chip was getting near burning to the touch so either it's shorted out or something is shorting it out.
    From there I can't really conclude what is at fault, or even why the LCD would even need this chip to operate (just for timing?).
    Find Nedry!
    Check the Vending machines!!
  • b700029
    Banned
    • Sep 2010
    • 640
    Re: VideoPhone screen not working
    Yes, that chip could be generating the refresh for the LCD too. What type of LCD is it? This is more likely if the LCD doesn't have its own controller and simply takes pixel data clocked into it, as opposed to more advanced types that interface to a processor via a databus and have their own controller.
    • pentium
      • Mar 2006
      • 2778
      I'm not exactly sure of the type of LCD it has. I can't find anything about it in the manual but for 1992 it's an AWFUL color screen. It has some persistence in it I have not seen since the IBM 5151.
      Find Nedry!
      • Gabriel Lucas
        microsoft surface pro 5 touch screen not working
        by Gabriel Lucas
        Hello everyone, I bought a Microsoft Surface Pro 5 and the touch doesn't work. According to what the previous owner said, the screen stopped working after an update. The screen has no physical damage, and the touch works for 1 second when it turns on and then stops working. I've tried updating the drivers, formatting, and returning to factory defaults, but nothing worked. Can you help me?
        02-18-2025, 09:24 AM
      • smic717394
        MSI Optix MPG27CQ half screen working. Identify burned component
        by smic717394
        I have a MSI Optix MPG27CQ screen to fix, only half screen is working, I found a burned chip on the right buffer board (S270DP01V00_HF_SR) but I can't read the model. Can anybody help?...
        04-08-2025, 05:53 AM
      • smic717394
        by smic717394
        07-25-2024, 10:16 AM
      • almarhum
        To fix laptop screen vertical line by working on its EDP cable
        by almarhum
        Has one here really gone through fixing laptop screen vertical line(s) by repairing/replacing its Embedded DisplayPort (EDP) cable, so would recount and share the complete steps of the process here now?
        As most, if not all, believe the laptop screen vertical line(s) caused by defective Embedded DisplayPort (EDP) cable which slipped and passed through either laptop screen hinge but post here is asking help to elaborate definitively the useful, real knowledge of repairing in the most complete, correct way, esp. can decide/determine whether the cable can still be fixed or must be re...
        05-07-2024, 02:12 PM
      • engineerx
        Help with HP elite X2 1013 G3| Touch screen stop working after windows update !!!
        by engineerx
        Hello everyone
        I have a multiple HP Elite X2 1013 G3, the touch works normally, but after installing Windows 11 and making its updates the touch screen stopped working !!! I think it's related to LCD firmware or bios updates, any suggestions or solutions?
        thank you...
        11-15-2024, 04:32 PM
