Rubycon part no?
  • drkailey
    • Jul 2011
    • 8
    Rubycon part no?
    1st post, maybe you can help.
    Have an old Canon S200 I like that's draining the battery when not in use (overnight). Read on another forum that replacing the flash cap might work.
    Looking for a p/n (or replacement) for a Ruby 330v 80uF "flash cap" 14x21mm :
    Can't find anything on their site, Digikey, Mouser or Newark.
    Help!
  • jetadm123
    • 2169
    Re: Rubycon part no?
    You're probably looking for the Rubycon FW series, which are made for the photoflash market. Below is a link for the cap:
    http://www.wellgainelectronics.com/n...capacitor.aspx
    Please note that I have not used this company and the link is for info purposes only.
    Chemicon also makes a similar cap, slightly longer, which is available on Ebay:
    http://cgi.ebay.com/1-NIPPON-330V-80...item3cb64ab735
    • drkailey
      • Jul 2011
      • 8
      Thanks, I came across that Well Gain part during my search, mine definately has the lug terminals tho, guess it doesn't matter as long as it's a photo cap of the right value and size.
        master hoarder
        • May 2008
        • 12175
        I don't have any experience with fixing cameras, but I'm not quite sure about the suggestion you got from that other forum (please post links to that page if possible).
        The flash cap is charged through the inverter and the inverter should be controlled by the camera's main logic. Regardless of the state of the flash capacitor, the inverter should be turned off when the camera is off. Therefore, I don't think changing the flash cap would do anything.
        Probably better for someone else to confirm, though.
        • drkailey
          • Jul 2011
          • 8
          Thanks for the help.
          Did quite a bit of searching around but this was all I found:
          http://www.ifixit.com/Answers/View/4...ot+powering+on
          I got a new battery (3.7v lipo) and it seems to charge fine (almost 3.8v) and holds charge indefinately when not in the camera, put it in and it drains overnight.
          • PCBONEZ
            Grumpy Old Fart
            • Aug 2005
            • 10661
            You might have a leaky cap but other than that charging a cap isn't going to drain it.
            Good caps charge to a point and then current stops.
            So you either have a cap with high leakage or some other discharge path has developed.
            Mann-Made Global Warming.
            - Dr Seuss
              master hoarder
              • May 2008
              • 12175
              I still don't think that's the source of the problem, though. It doesn't help that no one has given a follow up on what happened after the suggestion on that website.
              Still, I think the flash charging circuit *should be* off when the camera is off (then again, I'm sure it's not impossible that some circuit designer out there has done just the opposite).
              I guess it might be easier to just change the cap and see if that fixes the problem rather than check components. If you do have time and a multimeter, though, check all of the diodes and ceramic capacitors, especially near the battery input. Better yet, if you can post a picture of the camera's circuit boards (interesting paradox there ) , then we can help you with checking components.
              • drkailey
                • Jul 2011
                • 8
                Again, thanks for the help.
                Ya, interesting digging around and found lots of people with my exact problem but few solutions. Most said to just change the battery.
                I'm gonna try changing that cap for now and I'll report back with the results.
                • b700029
                  Banned
                  • Sep 2010
                  • 640
                  You can measure current drain on the battery with an ammeter, when turned off there should be almost none. I think the problem may be a leaky/shorted transistor leading from the battery to the flash inverter.
                  • drkailey
                    • Jul 2011
                    • 8
                    Didn't actually measure the drain but I'm quite sure the battery and charger are good but the camera drains it overnight.
                    I'll change the cap and if that doesn't work will definately need your help, finding a bad transistor will be a challenge for me.
                    • drkailey
                      • Jul 2011
                      • 8
                      Got a quick reply from Rubycon USA, no wonder I couldn't find a p/n:
                      Hello Terry,
                      330 FW 80 V 14x22 is the correct call out.
                      This is a made to order part. There is no available stock.
                      Rgs,
                      Derek Keefe | Rubycon- Inside Sales
                      4293 Lee Ave | Gurnee IL (USA) 60031 | www.rubycon.com
                      w: (847) 249-3450
                      f: (847) 693-3007
                      rai_sales@rubycon.co.jp
                      Have one with the same value coming from Well Gain, will update when I get it installed...
                      • drkailey
                        • Jul 2011
                        • 8
                        Just a quick update.
                        Got the cap from Well Gain via Hong Kong, unfortunately it's 26mm long instead of the listed 21. They're supposed to see if they have the right one...
                        • RJARRRPCGP
                          • Jul 2004
                          • 6304
                          Looked to me like Rubycon may have refused to help you, because of the cap spec being proprietary to a manufacturer, like some of those UPS ICs.
                          ASRock B550 PG Velocita
                          Ryzen 9 "Vermeer" 5900X
                          Arc A770 16 GB
                          eVGA Supernova G3 750W
                          Alienware AW3423DWF OLED
                          • drkailey
                            • Jul 2011
                            • 8
                            Update:
                            Well I tried. Well Gain doesn't have the right cap and the one I got won't fit. Sent it back and am waiting for a refund...
                            • PCBONEZ
                              Grumpy Old Fart
                              • Aug 2005
                              • 10661
                              http://www.ebay.com/itm/1-NIPPON-330...item3cb64ab735
                              - Dr Seuss
                              • EdoNork
                                • 6
                                Let the camera without the original cap and test if it drains.
                                • edugimeno
                                  Finding the wrong part at a loooong led strip, part works fine, part flickers, all parallel...
                                  by edugimeno
                                  Hi There!
                                  I'm trying to help my friend who owns a restaurant be just bought.
                                  He has a very long LED strip running along all the walls and columns. The strip is attached facing down 2in above the floor, using a wall panel that ends in a metal rail that finishes the panel underneath
                                  It's stuck using, I guess, the 2 sided tape that comes with the strip
                                  The issue is that like 1/2 of the full length, including 1/2 one wall, another entire wall, and one column, flickers after 4 or 5 minutes ON. Particularly it flashes staying OFF most of the time and flashing ON for 1 tenth...
                                  09-05-2024, 09:34 AM
                                • G-Sting
                                  iPad Pro A1876 SHORT Part Identify Help Needed
                                  by G-Sting
                                  So My iPad was not charging and booting up . i went to a local technician and he checked with thermal and this Part marked in 1st Photo is Short.
                                  So then i went on to boardview and downloaded the schematics and identified this part in 2nd Photo. Now i am confused what exactly is the part called ? where should i get this from ?
                                  i contacted my technician and he sent me his BoardVIew screenshot in 3rd Photo. In his Boardview the part is called X2826.... Something
                                  SO My main concern is what part should i order what should i search the name for ?
                                  on Ipad...
                                  05-15-2025, 09:30 AM
                                • Yanleb
                                  Panasonic part number in service manuals
                                  by Yanleb
                                  In the Panasonic service manuals, both in the board schematics and in the part listing, the part numbers that are given are Panasonic part numbers instead of the actual part numbers.
                                  This is especially annoying for small SMD components like diodes and transistors when you only have 1-3 digits printed on the component body.
                                  For an example, look at the attached PDF.
                                  Do you have a way to cross reference the Panasonic part number with the actual part number?
                                  Thanks....
                                  07-03-2023, 08:16 PM
                                • FreakyMex
                                  Trouble to identify part (Lunii screen) for replacement
                                  by FreakyMex
                                  Hello guys. I'm a complete noob in electronics. I'd like to repair my child Lunii's (a "story box"), basically an audio player that allows the childs to choose between several options the places, characters, objects of the story, and then play a story according to the choice of the child. There is a screen that display the selected option before each choice. The Lunii fell and the screen is now broken.
                                  I'd like to repair it (probably just have to change the part, because the lunii still works perfectly fine) but I can't manage to identify the part/order it online. Do you have any...
                                  02-17-2025, 01:16 AM
                                • esinior
                                  Smd code to part number
                                  by esinior
                                  Hi i have a smd part with probably mark "QO 11" or "Q0(zero) 11" on it, and its package is SOT89, i doubt its KTB1260 PNP transistor, but in measuring with diode mode of multimeter it shows number 1.4 between emitter and collector pins and its not open circuit, and .59 from collector to base and .8 from emitter to base , and these numbers doesn't match a pnp transistor, i couldn't find any part number and datasheet for it, does anybody have information for that part number?
                                  I've attached pics of this part
                                  Thanks...
                                  08-20-2024, 02:50 AM
