Things you can do with a current source
+ More Options
Posts
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    I've just built myself a 20A current source using a BD139 and two 2N3055s (in the schematic there's only one figured, i use two in parallel for Q2). I feed it with a 9.5Ah SLA battery, just the thing for getting a boatload of amps.
    I built it to use it along with my inductance measuring multimeter to check DC saturation current of inductors for SMPS supplies. But soon i figured there's more things it can be used for.
    • Testing fusing current of wire (for replacing fuses with a piece of wire without tripping the breaker or setting my house on fire)
    • Testing current capability and voltage drop of diodes
    What other uses can you think of?
    A working TV? How boring!
  • kikkoman
    • Jul 2007
    • 691
    Re: Things you can do with a current source
    4-wire resistance testing!
    "Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin slitting throats." - H.L. Mencken
    • Th3_uN1Qu3
      Believe in
      • Jul 2010
      • 6031
      Eh, i don't think it's that accurate... It drifts quite a bit.
      Btw, the circuit is only meant for brief operation, it won't do >10A for more than 20-30 seconds. Up to 10A it's alright, higher and the BD139 gets crispy. If you put a beefier transistor in place of the BD139 then the 1N4148 dies. And you can't use a more heavy duty diode because the whole circuit depends on the high voltage drop of the 1N4148.
      There are more elegant ways of making a current source. But for now, this one serves its purpose.
      • skystormfarms
        Banned
        • Mar 2011
        • 160
        i built a t-former 150a @12v(:
          Texas Instruments bq24745 bq24745RHDR bq24745RHDT Battery Charger IC for Laptop Computers Datasheet
          The bq24745 bq24745RHDR bq24745RHDT is a high-efficiency, synchronous battery charger with an integrated input-current comparator, offering low component count for space-constrained, multi-chemistry battery-charging applications. The input-current, charge-current, and charge-voltage DACs allow very high regulation accuracies that can be easily programmed by the system power-management microcontroller using the SMBus interface. The bq24745 charges two, three, or four series Li+ cells, and is available in a 28-pin, 5-mm x 5 mm QFN package.
          The bq24745 features dynamic power management...
          10-23-2024, 02:50 AM
        • tofik
          MOSFET equivalent K8A60DA
          by tofik
          Hello guys,
          I have a shorted MOSFET K8A60DA with the following characteristics:
          Type Designator: TK8A60DA
          Marking Code: K8A60DA
          Type of Transistor: MOSFET
          Type of Control Channel: N -Channel
          Maximum Power Dissipation (Pd): 45 W
          Maximum Drain-Source Voltage |Vds|: 600 V
          Maximum Gate-Source Voltage |Vgs|: 30 V
          Maximum Gate-Threshold Voltage |Vgs(th)|: 4 V
          Maximum Drain Current |Id|: 7.5 A
          Maximum Junction Temperature (Tj): 150 °C
          Total Gate Charge (Qg): 20 nC
          Rise Time (tr): 25 nS
          Drain-Source
          07-19-2023, 05:18 AM
          Diodes AP21X2SG-13 AP21X2MPG-13 Current Limited Power Switch for Laptop Computer Datasheet
          The AP2182 and AP2192 (AP21X2SG-13 AP21X2MPG-13) are integrated high-side power switches optimized for Universal Serial Bus (USB) and other hot-swap applications. The family of devices complies with USB 2.0 and available with both polarities of Enable input. They offer current and thermal limiting and short circuit protection as well as controlled rise time and under-voltage lockout functionality. A 7ms deglitch capability on the open-drain Flag output prevents false over-current reporting and does not require any external components.
          All AP21X2SG-13 AP21X2MPG-13 devices are available...
          10-23-2024, 03:33 AM
        • DynaxSC
          Extreme High Current & Low Voltage Short Killer ??
          by DynaxSC
          Hi Folks
          I'm looking for a extreme high current short killer solution for a reasonable cost.
          I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
          After taking off the socket, the shorts dissappear again.
          The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
          10-15-2024, 10:13 AM
          Adjustable Boost Power Supply DC-DC Constant Voltage Current Charging Module
          I want to know if I could hook up a solar panels to this boost converter would I have any issues doing and I would have issues what would they be
          https://www.ebay.com/itm/116497313155?var=416785404161
          Here are some of the description from the eBay seller
          The main parameters:
          1. Product name: High-power non-isolated DC boost module power supply.
          2. Product model: 100A2000W.
          3. Input voltage: DC12V-60V.
          4. Input current: 100A (maximum)....
          05-18-2025, 09:45 AM
