Looking for replacement MOSFET MMDF2C03HDR2G
  • billy66
    • Mar 2010
    • 124
    I have an IBM monitor and MOSFETs are blown... MMDF2C03HDR2G
    I looked up the parts on both Mouser and Digikey and they are out... I'm horrible at finding parts that will work in stead of the originals. Can anyone help me out finding a replacement?
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Looking for replacement MOSFET MMDF2C03HDR2G
    Use findchips.com
    http://www.findchips.com/avail?part=MMDF2C03HDR2G
    --- begin sig file ---
    --- end sig file ---
    • billy66
      • Mar 2010
      • 124
      WOW! Did not know about that site. Thanks retiredcaps... once again your help is outstanding!
      • Toasty
        • Jul 2007
        • 4171
        Take a look at this as a sub as I don't see anyone with stock:
        http://search.digikey.com/scripts/Dk...=SI4532DYCT-ND
        At 80¢ a pop, it might be worth a try.
        Toast
        veritas odium parit
        • billy66
          • Mar 2010
          • 124
          Thanks Toast, I'll give that a try.
          • DoOm86
            Dual mosfet replacement help
            by DoOm86
            Hello.
            I have a notebook with a shorted mosfet, it's a E6930 GA8125.
            It seems to be a 30V dual asymmetric N-channel AlphaMos.
            Luckily the notebook is working, so I just need to find a good replacement for this mosfet.
            And here is where I need help!
            It's the first time I have to replace this kind of mosfet, I checked on mouse and I found this: (mouser No) = 512-FDPC5030SG.
            I need your help to be sure is a good replacement or there is another with better compatibility, since I can't find the same exact (just from China).
            Thanks!...
            10-31-2023, 12:03 PM
          • jm942
            Hp Lh482p 5 short 3 long short after cpu vcore mosfet replacement
            by jm942
            My laptop went dead and after checking ,the main 19 volt power rail was shorted. After some checks i could identify that a high side vcore mosfet was shorted.
            I replaced the mosfet and now the white powerled is present , fans start spinning but capslock shows the famous 5 long and 3 short code.
            I checked the vcore voltages after replacement and i get for all 1.01 V so means for me that the driver is still working of the replaced shorted mosfet. On the Nvidia i measure around 0.8 V after the mosfets.
            I did voltage injection on the cpu with 0.7V and i have a current...
            07-11-2024, 05:11 AM
          • Jane
            How do you test MOSFET in laptops ?
            by Jane
            I tried to use this method:
            Testing an N-channel MOSFET:
            Step 1: Discharge the Gate (turn off the MOSFET)
            Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
            Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
            Step 2: Charge the Gate (turn on the MOSFET)
            Now, place the red probe on the Gate (G) and the black probe on the
            09-27-2024, 03:31 AM
          • boosti45
            Macbook pro logic board replacement parts quesion
            by boosti45
            i have a 2020 macbook pro 13" A2251 with 820-09149 logic board so i found an issue with chip labeled U6903 according to schem. boardview using flexBV software, so i removed it from the board and the issue im having is that the chip says "07A08FI ELC180​" on top of it but when searching for a replacement chip, i can find tons of identical looking chips that also have "ELC180" printed on them but the first set of digits is never the same so im trying to find out if i need this exact chip with these same numbers as mine and if not which ones are compatible as a replacement?...
            08-21-2024, 05:23 AM
          • samoelec
            Trying to understand how to find best replacement cap for old parts.
            by samoelec
            Disclaimer: This is the first time I step into the realm of analog electronics and my natural language is not English, so please forgive me if I failed to use the correct terms when describing things.
            Recently I purchased a Tektronix TDS1012, a 20 years old product for cheap and I thought it could be a nice opportunity for playing (i.e. recapping) and learn something in the process.
            The power supply board is exactly the same from this post so I'll just steal it for now.
            I'm trying to find replacements for all those Lelon electrolytic caps, but then quickly...
            04-01-2024, 03:39 AM
