Found three Koshin caps on the power supply board of my Polk Audio XRT12 XM tuner. Just curious, as I've never heard the brand... not bad, near as I can tell...
Anyone heard of Koshin caps?
Re: Anyone heard of Koshin caps?
Elna use those vents. I have 2x 470@25 Elna RE3 on an old ISA soundcard.Comment
I saw Koshin electrolytics in old Pace DGT-400 satellite receivers (I don't know why they stopped using the LCC-Thomson electrolytics, even though they used a few LCC-Thomson units), except for the early receivers, which originally used LCC-Thomson electrolytics (KM series - apparently general purpose) - can anyone find the LCC-Thomson electrolytic manufacturer's website?
The Koshin website is www.koshin.com.hkMy first choice in quality Japanese electrolytics is Nippon Chemi-Con, which has been in business since 1931... the quality of electronics is dependent on the quality of the electrolytics.Comment
They were also in my ISO PSU. An internet search revealed also in NAD L53 DVD/CD Stereo ReceiverComment
Update: A Pace DGT-400 satellite receiver made in early 1998 had no LCC-Thomson units; most of them were Koshin units. I know that LCC-Thomson (or the Thomson Passive Components division) was purchased by AVX - still wondering what happened to LCC-Thomson.
Koshin was established in 1984.My first choice in quality Japanese electrolytics is Nippon Chemi-Con, which has been in business since 1931... the quality of electronics is dependent on the quality of the electrolytics.Comment
by momakaI know I've been a little scarce lately (like the last 2-3 years), but I'm still here and still doing my thing with fixing PSUs.
https://www.badcaps.net/filedata/fetch?id=359177... -
by eryjusHello,
Channel: General Capacitor Questions & Issues
by Paxman_SwedeHello!
I have studied the board and...-
by captain150I'm trying to repair two old VCRs, they both have bad caps. One has leaky ones, the other would barely run until I subbed in some caps from another power supply I had laying around (though they are the wrong values). This vcr works for an hour or two, but then the power supply starts whining and the picture gets lines in it. I didn't replace all the secondary caps, so another voltage might still be problematic, or the values I used are too far off.
I've been on mouser and digikey but the options are a bit overwhelming. I just need some new ones that will work. They don't need to be top quality,...-
by FoetussGood evening
I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
But I was also suprised about the bigger boys, which are 330µF 25V.
Could it be they used 25V caps because they were cheaper / available at that time?...-
- Loading...
