Found three Koshin caps on the power supply board of my Polk Audio XRT12 XM tuner. Just curious, as I've never heard the brand... not bad, near as I can tell...
Anyone heard of Koshin caps?
Re: Anyone heard of Koshin caps?
Elna use those vents. I have 2x 470@25 Elna RE3 on an old ISA soundcard.Comment
I saw Koshin electrolytics in old Pace DGT-400 satellite receivers (I don't know why they stopped using the LCC-Thomson electrolytics, even though they used a few LCC-Thomson units), except for the early receivers, which originally used LCC-Thomson electrolytics (KM series - apparently general purpose) - can anyone find the LCC-Thomson electrolytic manufacturer's website?
The Koshin website is www.koshin.com.hkMy first choice in quality Japanese electrolytics is Nippon Chemi-Con, which has been in business since 1931... the quality of electronics is dependent on the quality of the electrolytics.Comment
They were also in my ISO PSU. An internet search revealed also in NAD L53 DVD/CD Stereo ReceiverComment
Update: A Pace DGT-400 satellite receiver made in early 1998 had no LCC-Thomson units; most of them were Koshin units. I know that LCC-Thomson (or the Thomson Passive Components division) was purchased by AVX - still wondering what happened to LCC-Thomson.
Koshin was established in 1984.My first choice in quality Japanese electrolytics is Nippon Chemi-Con, which has been in business since 1931... the quality of electronics is dependent on the quality of the electrolytics.Comment
by momakaI know I've been a little scarce lately (like the last 2-3 years), but I'm still here and still doing my thing with fixing PSUs.
https://www.badcaps.net/filedata/fetch?id=359177... -
by eryjusHello,
by Paxman_SwedeHello!
I have studied the board and...-
by captain150I'm trying to repair two old VCRs, they both have bad caps. One has leaky ones, the other would barely run until I subbed in some caps from another power supply I had laying around (though they are the wrong values). This vcr works for an hour or two, but then the power supply starts whining and the picture gets lines in it. I didn't replace all the secondary caps, so another voltage might still be problematic, or the values I used are too far off.
I've been on mouser and digikey but the options are a bit overwhelming. I just need some new ones that will work. They don't need to be top quality,...-
by budwichDid a "gross" impedance measurement of the inputs on my polk csi40 center channel speaker. It showed about 4ohms. Seemed kind of low. There are two midrange drivers and one twitter ... 2 way system.
All measurements at the drivers seem ok in the 4 - 6 ohm range (the two mid range are in series).
Anyway, in the crossover on the tweeter side, there are two caps in parallel basically leaving an inductor .... "nice simple setup", especially when no schematics around. The question is finding a replacement. One is a TI .47uf met 100vdc while other is a 9.1uf...-
- Loading...
