22 ohm smt resistors
  • barry wilkins
    • Aug 2009
    • 172
    I need a couple of 22ohm surface mounted resistors for a repair ,these are marked 220 ,or a couple of 1/10 watt tiny ordinary ones .
    Can any body help .
    thanks
    Barry Wilkins
  • steve2
    • Dec 2010
    • 121
    Re: 22 ohm smt resistors
    There are several lots of them on ebay (real cheap), but you really need to measure the size of them to see what wattage they are. http://www.radio-electronics.com/inf...d_resistor.php
    • TinkerTron
      Schematic vs. Reality: Where Are the Resistors on My Sharp Clock Radio? Model FY-70CH
      by TinkerTron
      Hey everyone,
      I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
      Instead, here's what's been bugging me so far:
      The schematic...
      03-06-2025, 02:03 PM
    • hobostove
      Corsair RM1000e - Help identify 5VSB Zener diode
      by hobostove
      Hey there guys. I've got a Corsair power supply that's come across my bench dead. I usually don't mess with power supplies, but it's a slow week so I'm giving it a whirl.
      Taking it apart I heard a screw rattling around inside, and when I got it apart I found a couple blown components near what I think is the 5VSB area.
      There's a 22ohm resistor that's melted and open, but it still has the bands.
      The other part is a zener diode and it's top went to jesus, so I can't read the marking.
      It looks like the diode connects the source and drain of a TNY284...
      03-27-2025, 02:25 PM
    • brightest_z
      Hot Air Blew Away Resistors Near Bios
      by brightest_z
      Hi All - I'm in the midst or reprogramming the bios on my gen1 Surface Laptop Studio and I accidentally blew away 2 resistors nearby the bios. I don't have another board to measure values of the missing resistors and schematics aren't available, bbut the bios is a 6x5mm Winbond WSON8, W25R256JWPQ model. The traces are conductive to Pins 3 and 7 (IO2 & IO3 respectively) so I have reason to believe they are 10k pull up resistors since IO2&3 pins are used for Quad SPI instructions.
      Does anyone with more knowledge, and experience than I, know if this is the case?
      12-11-2024, 08:34 PM
    • jinu_j
      LED driver circuit. Burnt Resistors
      by jinu_j
      Hi Folks
      This has to do with a LED light driver rated for Output - DC36-65V 300mA. This is used to drive a 15W LED panel light.
      Now this does not work so opened up and found 2 resistors burnt to crisp. Sensing a learning moment, i looked around the circuit to figure out that it is built around the OB2538 chip. The circuit to a large extent follows the sample application circuit mentioned in the data sheet. I have traced the actual circuit and the same is also attached for reference.
      But i have some queries on this circuit
      1. The resistors that burnt to crisp...
      08-26-2020, 01:24 AM
    • repair-it
      Pioneer VSX-40 ,Trying to ID these resistors
      by repair-it
      I am trying to determine why these two resistors are the colors that they are. This is a Pioneer amp. The ones I am concerned about are the RED & GREEN colored resistors. I need to replace them and want to be sure to use the properly rated component....
      12-16-2024, 02:08 PM
