RL151s are tough diodes
  • Trinite
    • 143
    I have an old power brick in which the device it was attached to shorted out, taking the power brick with it. Or at least I thought. It was a bad short too, as you can see from the melted tip in the pics. When I opened it up, all the rectifying diodes (RL151) had gotten so hot that they had desoldered themselves from the PCB. The all tested good, so I resoldered them all and tested the unit. Got 12V on the output just as specified. Looks like some seriously tough components, especially compared to some you see today.
  • Wizard
    • Mar 2008
    • 2296
    Re: RL151s are tough diodes
    Reason diodes did not short out is transformer's impedance is high that won't transfer enough current to cause silicon diodes to breakdown and short out.
    Cheers, Wizard
    • Trinite
      • 143
      Well, looking at impedance, looks like the transformer can put out about 3A max, so that is about double the diodes' rated current. You're right, probably not enough to blow them, but still pretty impressive that they held up to high enough temps to desolder them from the PCB (200°C+ I'm guessing).
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        diodes have to be able to survive high temps.otherwise soldering would kill them.now if you want impressive heat survival an original p60 in an alr desktop.glued on heatsink fell off.got hot enough to melt solder and drop out of the board.socket and all.i cleaned it up,soldered the socket back in and it worked just fine!it was given up for dead by a local shop.got it free.
        • Scenic
          o.O
          • Sep 2007
          • 2642
          pretty funky looking cap vent
          • Dvsr
            On M-Audio AV40 active studio speaker's two zener diodes get really hot.
            by Dvsr
            Hi. I need help from wiser guys. I am amateur in electronics and can't figure this out by myself.
            I bought faulty speakers, M-Audio AV40's. Other speaker has all the electronics in it and the other speaker is just passive one powered by the other speaker's amp. Original problem with the speakers was loud buzzing. I figured out that there is something wrong with the capacitors. I went ahead and replaced every electrolytic capacitor on the PCB. The caps are good quality and have the same values as the original ones.
            After replacing the caps I started testing out the speaker. It seemed...
            09-10-2025, 10:20 AM
          • caspian
            What Zener Diodes on a Linear Power Supply
            by caspian
            Dear members,
            I have a linear variable power supply with unknown brand name that I used for voltage injection.
            Then it failed. I discovered that its transistors (Q1 and Q2) are shorted.
            In addition, I discovered that its zener diodes are defective.
            I can replace the burned transistors.
            But I do not know the model of the zener diodes. the model number is not marked on the zener diodes.
            Therefore, I cannot replace the zener diodes.
            I do not want to test the zener diodes in a test circuit to discover their model or value.
            no schematics are available...
            05-26-2025, 12:38 PM
          • tvguy12012012120
            by tvguy12012012120
            02-07-2025, 05:13 PM
          • spleenharvester
            GRT60-145410 brick PSU, how much of a fire hazard is this thing exactly?
            by spleenharvester
            I bought an Alpicool C20 fridge, which is a 60W compressor fridge that runs on 12V or 24V, which can come from either an AC/DC adapter from mains (240V here in UK) or a car battery. The fridge itself is really good quality, so I was surprised to find the power supply (DC14.5V, 4.1A) pretty questionable. Despite being 240V/1.5A the plug was fitted with a 13A fuse - concerning, but not all that uncommon for imported chinese electronics here. But when I felt how light the brick was I immediately said hell no and transferred the proprietary connector to a MeanWell GS90A12-P1M brick (this supply is...
            07-08-2025, 06:02 PM
          • Nikolai Danylchyk
            Lenovo T480s usb-c charging port replacement - Knocked off a couple of diodes.
            by Nikolai Danylchyk
            Hi folks. As the title says, I was doing a port replacement on a Lenovo Thinkpad T480s and in the process of post-solder cleaning, I somehow knocked off 2 or 3 diodes (i think they are diodes) near the main usb-c. I can't seem to find what kind of a diode is that. I know it's ultra tiny and just has a letter "G" on it. Would someone maybe have a proper schematic for the t480s model? I can only find the non-s one and it's quite different to the "s". Would love to figure out what component that is.
            Thanks in advance!...
            05-08-2025, 06:18 AM
