Timer circuit....stop the nagging chime in my car
  • romansroad
    • 123
    The government nag required chime goes several minutes if I don't put on the seatbelt. I'm not blasting down the road, just moving it about in/near the parking lot at 2Mph tops.
    The circuit is proprietary, so modding it can be a pain. I can add an aftermarket module to override various features, but its $300. One can't override/bypass it at the buckle itself without risking damage to the main control unit.
    If I can get to the Vcc of the chime, I imagined I could insert a sort of snooze function inline. I was thinking of using an SCR, with the goal of tapping a hidden button to initiate the timing cycle, which would cut the supply to the chime for greater than the on time of the seat belt alarm.
    Since we're in a running car, the design won't need ultra low draw CMOS or anything. I would appreciate any thoughts on this, and thanks in advance.
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Timer circuit....stop the nagging chime in my car
    I can't help with the electronics stuff, but does the insurance company care about this mod? That is, can they pull out a clause to deny payment because of this mod?
    Just food for thought.
    --- begin sig file ---
    --- end sig file ---
    • PlainBill
      • Feb 2009
      • 7034
      Retiredcaps already pointed out one potential liability issue.
      Locate the wiring diagram for your car. There is a 90% chance that the signal from the seat belt goes to the on board computer, which controls the chime.
      My car only chimes about 3 times, then stops. If I start my car with the seatbelt unfastened, the chime will stop before I have a chance to fasten the belt. Perhaps you need a more user friendly car.
      If the chiming sound of the seat belt warning offends your ears, maybe you should get a job driving school bus. After a week of that, the seat belt chime will sound like Edvard Grieg's 'Morning Mood'.
      Don't you have something more important to do? World peace, a cure for the common cold, an effective cancer vaccine, or even a BS detector for politicians would seem to be more significant.
      PlainBill
      • Toasty
        • Jul 2007
        • 4171
        DANGER Will Robinson!
        You mess with the wiring without knowing -EXACTLY- what you are doing, you could set off the airbag(s).
        $3,000 later, you'll begin to like the chime...
        veritas odium parit
        • romansroad
          • 123
          This is why I asked.....all good points, and as to something better to do...well sure, but what's the fun in only doing that? My wife asks me the same question as I toil over various broken monitors, computers, TV's, vintage radios, timepieces and vintage cars. Even funnier is that my day job is surgery and that sort of repair work is done with the engine running.
          I do appreciate the input, and as I've had this chime for 59K miles, another 50K or so doesn't sound as bad as a facefull of airbag!
          • Krankshaft
            • Jan 2007
            • 2328
            Just desolder the transducer for the chime if it bothers you that much.
            You could also put a transistor or solid state relay on the VCC of the transducer to enable or disable it.
            As for the airbags that's a separate module and all air bag wiring will be shrouded in yellow tubing. Just pull the negative battery cable and wait 10 mins for the SRS computer capacitor to discharge if you're worried.
            • PCBONEZ
              Grumpy Old Fart
              • Aug 2005
              • 10661
              Or you could jumper across the switch in the seat belt [perhaps even in the wiring under the seat] and avoid getting into the dash at all.
              Mann-Made Global Warming.
              - Dr Seuss
              • romansroad
                • 123
                That was the first thing I looked at. After review of the schematic, there is a feedback loop here with what appears to be an R-C network and not just a simple switch.
                The transducer sounds like its at the very soul of the dash....not as bad as a heater core, but close to that pain level. I could do what my Mom used to do and just turn up the radio
                • Pyr0Beast
                  • Feb 2009
                  • 406
                  Get to the local car junkyard and get a seatbelt hook cut from the belt and stick it into switch.
                  Or run the seatbelt on the backside of the seat.
                  Whatever works
                  • DeanWy
                    WD Sentinel DS5100 (NAS) boot issues
                    by DeanWy
                    I have a Western Digital Sentinel DS5100 NAS system which has stopped working. It has dual BIOS. I bought the system second hand with an already broken primary BIOS (it rebooted multiple times until second BIOS was used).
                    It worked until recently. The system was idle in Windows Server 2012 and a BSOD occurred, I think it was 'critical process died'. Thereafter it didn't boot, it just sat there with no video output and fan speed at 100% (there's a proprietary Windows driver by WD which controls the fan, outside of that it always runs at 100%).
                    There...
                    07-30-2024, 04:13 AM
                  • survivalbloke
                    Macbook A1398 - no startup chime, no boot, but have fans and CPU warm
                    by survivalbloke
                    Macbook A1398 - had repeating loop of startup chime with no actual boot. Just startup chime, then restart, start up chime, then restart, etc. I pulled the battery and cleared BIOS. It will now power up, fans on, CPU warming, but no startup chime and no boot. I reflashed the BIOS chip but the same thing happening. Where should I go from here?
                    06-14-2023, 11:45 AM
                  • nervous_capybara
                    Repairing the Hitachi DA-6000 CD player
                    by nervous_capybara
                    Hello everyone !
                    I recently conducted maintenance on a Hitachi DA-6000 CD player for my grandparents : it had two distinct issues.
                    Feel free to share your experience if you ran into other issues.
                    DISCLAIMER : BE VERY CAREFULL WHEN OPERATING ON THIS SYSTEM : THE HIGH VOLTAGE IS VERY CLOSE TO THE VARIOUS TESTING POINTS, PROCEED WITH CAUTION
                    CD tray would not come out of the player
                    I could hear a motor spinning inside the player but the CD tray would not come out.
                    Turned out that the issue was the CD tray belt that aged poorly and began to...
                    11-05-2025, 03:11 AM
                  • zpi
                    A1466 820-00165 Chime and freeze on osc loading, with battery no chime.
                    by zpi
                    Hey guys, so i have here really strange board...
                    These steps needs to be done to get a chime board starts to load osx but freezes with no loading bar:
                    1.Disconnect battery
                    2.P+R+CMD+OPT to pram reset
                    3.After only 2-7 atempts to pram reset i get chime.
                    4.Then i get chime allways, but if i connect battery, then boards stops to chime till i make steps from 1 to 3.
                    Board looked very clean, no liquid damage. Already replaced isl6259 and SMC, good known battery. Still same problem, sometimes turned off board without battery uses 0.03...
                    11-10-2020, 04:42 PM
                  • Amin89
                    Bypass timer apc bx650ci
                    by Amin89
                    How to disable the timer on the APC BX650CI-MS UPS, because it shuts down every 15 minutes even though the battery is still full....
                    10-18-2025, 09:01 AM
