Transistor for mbd, FDD-6530A-ND
  • quartz
    • Nov 2010
    • 14
    Hi, wondering if anyone knows where to buy or if these two (from a diff motherboard) would be an alternate,
    Niko P45NO2LD, or
    Niko P3055LD
    thanks
  • seanc
    • Nov 2008
    • 1319
    Re: Transistor for mbd, FDD-6530A-ND
    Contact Niko Semiconductors.
    I asked where to purchase mosfets, instead they offered to send me free samples! Excellent customer relations!
    • jetadm123
      • 2169
      Someone in the UK is selling the Niko P3055LD on Ebay.
      http://cgi.ebay.com/P3055LD-Transist...item27b6f0a249
      • japlytic
        • Oct 2005
        • 2086
        Fairchild also produces the FDD6530A (21A, 20V, 0.047 ohms Rds(ON) @ Vgs 2.5V; 0.032 ohms Rds(ON) @ Vgs 4.5V), and one of the suppliers is Digi-Key.
        • magneh
          Behringer Eurolive B205D repair - help identifying transistor
          by magneh
          Hello
          Got this speaker from a friend , defective. Power led comes on and off , in a loop.
          Disassembled, got the board out, and after a bit of measuring I found a low resistance on a 5v6 line. With a bit of current I found a transistor heating up on that line (labeled T1 and 113 as on pic).
          After removing this guy, I got a value of 0.7 in diode mode on that 5v6 line, which before had 0.02 or something like that.
          I tested powering it up without the IC, and the speaker turns on and stays on, and works fine
          Still, I need to replace this transistor....
          06-18-2025, 02:34 AM
        • elsomer
          help to identify transistor msi ms-15ck1
          by elsomer
          hi people, i need some help to identify a transistor(q14) that is missing on the board, so the gpu has no voltage i think that q14 activate the phases for gpu, but i dont have schematic or boardview, but i think its the same transistor than q15 and q16, thanks...
          02-17-2025, 05:30 PM
        • rddube
          Help with blowing transistor NAD T752 receiver
          by rddube
          I guess I need help from the masters to try and find what is frying a 2SC5669 transistor on the left channel of this front center Amp for a NAD T752.
          Was working perfectly and all of a sudden I heard a pop, and then a glow from the amp. Not only did the 2SC5669 burn a leg, but R520 which is a 220 ohm resistor partially burned - it now measures 110 ohms.
          I bought this amp second hand fairly cheap as it was not working, it went into protection mode. I finally traced it down to the same transistor Q510, the one that just popped. It was shorted...
          09-01-2022, 05:19 AM
        • amigo744
          xbox series x u82 5 pin transistor voltages ?
          by amigo744
          hello there,
          xbox series x hdmi u82 transistor 5 pin,
          can anybody tell me voltages of this transistor in standby and power on mode ???
          on which pin of this transistor are the voltages ?
          regards
          08-16-2023, 08:05 AM
          AO4601 AO4601L Transistor (Applications Laptops) Datasheet
          Complementary Enhancement Mode Field Effect Transistor
          The AO4601 and AO4601L use advanced trench technology MOSFETs to provide excellent RDS(ON) and low gate charge. The complementary MOSFETs may be used to form a level shifted high side switch, and for a host of other applications. Standard Product AO4601 is Pb-free (meets ROHS & Sony 259 specifications). AO4601L is a Green Product ordering option. AO4601 and AO4601L...
          11-05-2024, 08:21 AM
