VG Pocket handheld game problem (dead)
  • bluto
    • Oct 2007
    • 560
    One of my younger customers has a Disney Princess hand held video game (VG Pocket VG-9001) that is apparently dead. The LCD back-light and top LED come on when the power button is pressed, but that is all. Nothing on the screen and no sounds. I tried pressing buttons but still no indication of life. The device will not switch off with the power button, the batteries must be removed.
    I was told that the game 'just stopped working one day'. There were no indications of impending failure. The device looks like it hasn't been roughed up too much.
    I took it apart and stated replacing capacitors ('cause that's what we do here!). I checked each one that came off (and the two originals that I put back on) for capacitance and ESR and they all checked out OK, so I don't think it is a cap problem. There were no signs of leakage either.
    I am looking squarely at the crystal as the possible culprit. It says 6.000 on the top which I assume means 6MHz. I am not sure how to test it definitively. I pulled out my scope-meter and touched it to the top of the can (was soldered down and seemed to lead to the dab 'o glue cpu). The results are pictured. I got a 'triangle' looking waveform. There are two pins soldered to the board underneath the can and probing them gave a weirder looking waveform.
    Any thoughts on how to test the crystal better? Any tips for replacing it and hints for finding a matching part on DigiKey?
    (Mind the fact that the ribbon cable to the LCD is unplugged in the picture)
  • bluto
    • Oct 2007
    • 560
    Re: VG Pocket handheld game problem (dead)
    I found about a dozen 6MHz crystals on DigiKey that look like this:
    http://search.digikey.com/scripts/Dk...name=XC1712-ND
    Do I need to worry about load capacitance of the crystal?
    • Radio Fox
      • Jan 2010
      • 281
      I can't see what the timebase setting is set to on your scope. Is it reading the right frequency?
      ________________________________________________
      Invisible airwaves crackle with life
      Bright antennae bristle with the energy
      • bluto
        • Oct 2007
        • 560
        Sorry for the noob-ish question: What time base should I be using? I have not used the scope much since my uncle gave it to me.
        Another question, If I were to replace the crystal, does the orientation matter? Or can it be installed in either direction?
        • shovenose
          Send Doge Memes
          • Aug 2010
          • 6575
          lol, im envious. i wish my uncle gave me oscilloscopes. well he did buy me a ipod video, an ipod touch, a macbook, and an iphone (the only one of which i still have is the iphone...i sold the ipod touch after a year, and i later sold the macbook on craiglist because it ran too hot...
          and the point of my long rant? to say that my iphone sucks at everthing it was made to do: the buetooth never worked, its slow, drops about 3/4 of the calls. and this is the iphone 3g not the 4...
          tbh i still appreciate it like crazy, it is my first "phone"
            • 31094
            crystals go in either way.
            • bluto
              • Oct 2007
              • 560
              Well I messed around a little more. I still am learning how to crawl, but I think I am getting somewhere. I started by hooking the black lead from the scope to the negative battery terminal (apparently important). Then I probed both legs of the crystal and took pictures of both waveforms. The scope was set on a 2ms timebase. The first leg produced a waveform that looked very sinewave-ish. The second was a little less sinewave-ish. Each were stable over time, but did fluctuate a few times (or it could have been the operator ).
              Any ideas on this one? I still don't know what I am looking at exactly. Is this telling me definitively that I have a good crystal, or is it somewhere along the lines of 'definitely maybe'?
              • smason
                • 1652
                I've forgotten how to do the math to determine frequency from a waveform on a scope, but it looks like what I would expect. I'd go out on a limb and say it's working fine.
                • shovenose
                  Send Doge Memes
                  • Aug 2010
                  • 6575
                  Dont these thingw cost like $5? But then again its more fun to fix it. Are u sure a main ic isnt just fried?
                  • kc8adu
                    • Nov 2003
                    • 8832
                    • U.S.A!
                    looks like the clock is running.i would focus on the flash.corrupt or broke loose.its to the right of the cob and has a p on it.the fact that the power button turns the unit on but it gets stuck in a bad state and cannot be turned off tells me its software.
                    • kc8adu
                      • Nov 2003
                      • 8832
                      • U.S.A!
                      and for another test check out u1.
                      appears to be a +3.3 regulator.i suspect its ok as the thing starts up.see if it stays in spec when the thing locks up.
                      • Radio Fox
                        • Jan 2010
                        • 281
                        Looking at those waveforms, you are not reading the crystal frequency, but some other lower frequency.
                        To convert frequency to time period or time period to frequency, you just invert it (T=1/f or f=1/T). So, 1Hz = 1S, 1kHz = 1mS, 1MHz = 1uS 1GHz = 1nS. A frequency of 6MHz will have a time peroid of 0.167uS (= 167nS).
                        You are seeing roughly 2.6 cycles for each 2mS division, so approx 0.77mS which is just 1.3kHz. This could be a reading of the crystal frequency after it has been divided down by one of the chips (6MHz/4096=1.46kHz).
                        Also placing probes directly on the crystal can cause the frequency to change or even stop. You would normally see low value capacitors connected to the crystal. The extra capacitance of the probes could upset the working of the circuit.
                        btw...does your scopemeter have cursors or markers? If so, you can use these to get a direct frequency reading. Line up a vertical cursor, or marker with any part of the waveform, then adjust the second cursor, or marker to line up with the next occurence of the same part of the waveform.
                        • ratdude747
                          Black Sheep
                          • Nov 2008
                          • 17136
                          you know these toys are throwaway junk... they figure by the time it dies, the kid will have gotten bored with it or a new and better version will steer kids away from he old one.
                          good luck fixing it... more proof why quality is hard to find these days...
                          sigpic
                          (Insert witty quote here)
                          • bluto
                            • Oct 2007
                            • 560
                            Understand. It is just that the customer was attached to this one. I may have to buy another one so I thought I would give it a shot to try fixing it. Seemed like it should be repairable. And it looks like a cleanly made board. The only thing that I don't understand is the 'dab of glue' cpu. Is that when the manufacturer draws a custom part right on the board and covers it with a glue-like substance? I guess it is cheaper than fabbing a fully packaged chip? Possibly due to its application-specific nature?
                            I am amazed that throwaway junk technology has come this far. 12 games in one, color LCD screen, etc. beats the crap out of the hand held 'simon' game that I had as a kid.
                            • bluto
                              • Oct 2007
                              • 560
                              Checked a few things. I get 3.6v out of the regulator. The other IC (u6) is the audio amp. I get 3.3v going in. I pulled the data sheet on the flash chip. It is a Macronix MX29LV320ABTC-90G - 32M-BIT. On weird thing, the manufacturer logo was mechanically scratched off the top of the package (visible in the picture). Would this tend to indicate that this was a 'factory second' aka 'picked up off the factory floor' batch of flash chips? It would help keep the cost down...
                              • Badcappy
                                Banned
                                • Aug 2007
                                • 52
                                It's called COB (Chip-On-Board), essentially a bare die that's wirebonded directly to the board and covered with epoxy. It's quite common in high volume, low cost applications.
                                My guess is a corrupted flash. Somewhat unusual, since that is NOR flash and should be more robust than the NAND parts that are more common these days. Using chips that failed QC in some minor way is not uncommon for a cheap non-mission-critical device like this. Even though it's Disney, who knows what OEM they use.
                                I doubt you'll find firmware for it anywhere, so unless you want to dump the flash and embark on a possibly interesting reverse-engineering project, consider it scrap. Maybe the LCD and caps are still good...
                                • kc8adu
                                  • Nov 2003
                                  • 8832
                                  • U.S.A!
                                  i would expect many very cheap items like this to contain low grade or even recycled parts.flash chips get binned and the top grade go into name brand and critical apps.lesser bins get derated and tested.like at a lower speed.the real dregs go to counterfiet flash drive and crappy trinket makers.like this toy.
                                  if i sold salvage i would destroy the logo too.
                                  • bluto
                                    • Oct 2007
                                    • 560
                                    Makes sense. I guess I will consider this one toast. And thanks for the great insight. Even when I can't fix something, I still learn amazing things from all of you that will help fix the next item!
                                    • shovenose
                                      Send Doge Memes
                                      • Aug 2010
                                      • 6575
                                      Im surprised about the 4megabyte flash chip
                                      • smason
                                        • 1652
                                        Thanks. Having a good frequency counter has made me lazy, and stupid
                                          ACER Aspire Revo R3600 + 3D Game Pad Aspire 230 Specification for Upgrade or Repair
                                          This specification for the ACER Aspire Revo R3600 + 3D Game Pad can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Revo R3600 + 3D Game Pad boardview and Aspire Revo R3600 + 3D Game Pad schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                          09-12-2024, 03:28 PM
                                          ACER Aspire Revo R3600 + 3D Game Pad Aspire N270 Specification for Upgrade or Repair
                                          HP EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green EliteDesk 800 i5-7500 Specification for Upgrade or Repair
                                          This specification for the HP EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green boardview and EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively...
                                          09-12-2024, 02:00 PM
                                        • double_DD
                                          How can I be sure that my EC chip is dead?
                                          by double_DD
                                          As the title suggests, how can I be sure that my EC chip is really dead?
                                          I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                                          Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                                          03-12-2025, 07:47 AM
                                        • totoagung2
                                          by totoagung2
                                          Totoagung2: Situs Slot Gacor Paling Gampang Jackpot di Indonesia 2024
                                          Hadirnya situs slot gacor gampang jackpot Totoagung2 yang menyediakan banyak sekali permainan slot terpopuler terkini yang hadir setiap tahun nya. Tentunya di Indonesia sendiri yang menjadi salah satu negara yang favorit bagi provider game slot. Banyak sekali pengembang permainan melihat negara tanah air Indonesia untuk menjadikan dan mencoba berbagai kesempatan bisnis judi online yakni games judi slot Totoagung2 terbaik dan terpercaya no 1. Hal itu juga dibuktikan dengan sangat banyaknya provider mesin slot...
                                          01-01-2024, 02:43 PM
