Looking for SMD resistor values
  • Safrilhg
    Safrilhg
    • Nov 2023
    • 8
    • Indonesia
    Hey everyone, this time the question is very complicated, hope there is an experienced technician.
    The BenQ g922hdal monitor experienced a short in one of the SMD resistors in the power section.
    From the picture I attached, the path leads to the SMD capacitor and to the leg of the LD7560GS IC.
    Can anyone help determine the value of the SMD resistor?
  • vinceroger69
    • Mar 2012
    • 6714
    Re: Looking for SMD resistor values
    This service manual may help https://www.manualslib.com/manual/69...page=44#manual
    • vinceroger69
      • Mar 2012
      • 6714
      https://www.datasheets360.com/pdf/3615894573560026099
      • Safrilhg
        Safrilhg
        • Nov 2023
        • 8
        • Indonesia
        Thanks for help, But according to your guess, what value is suitable for the resistor. If I 220 ohm.
        • vinceroger69
          • Mar 2012
          • 6714
          The service manual and ic data, the cs pin does have a cap and a 220 ohm resistor i would try it if this was a repair i was doing .
          • Safrilhg
            Safrilhg
            • Nov 2023
            • 8
            • Indonesia
            Yeah, iam gonna tested, if the components burn, that's so amazing hahaha.
            • vinceroger69
              • Mar 2012
              • 6714
              can you use a dim bulb tester too see if you still have a short when powering on saves blowing new parts etc
              • Safrilhg
                Safrilhg
                • Nov 2023
                • 8
                • Indonesia
                I will do a physical check on the PCB, but I can confirm that the short circuit occurred due to corrosion.
                And will check the path with a multitester.
                • Kobok
                  Different (lower) resistor values on PCB?
                  by Kobok
                  Dear Alls,
                  For sure it id a stupid question, but help me to understand. I am in a Dell 2007WFP revitalizing project - searching reason why not starting. Some resistors needed to replaced is is obvious. When I have soldered some resistors the measured (with multimeter) values were sometimes rather different written on them. I supposed these are wrong units so I desoldered and made a checking measurement and voilá the values is the same is written on. This happens only in case of a few resistors, most have the same values (+/- 10%) are written on it. "strange" SMD resistors =>103...
                  09-19-2022, 07:30 AM
                • Safrilhg
                  Look for the resistor value in the BenQ G922HDAL monitor's power supply
                  by Safrilhg
                  Hello guys, I had a problem where I didn't know the value of the burnt SMD resistor in the power supply circuit of the BenQ G922HDAL monitor.
                  In one of the parts, there is a burnt SMD resistor which leads to the LD7560GS IC as shown in the picture below.
                  How to determine the appropriate SMD resistor value for this condition? Thank You...
                  11-06-2023, 12:43 PM
                • jinu_j
                  by jinu_j
                  Hi
                  05-03-2025, 10:51 PM
                • madushanka 1234
                  need to find RESISTOR values of mising LA-E831P
                  by madushanka 1234
                  need to find mising parts LA-E831P
                  need to find values of this marked resistors...
                  another shop mixed this marked 5 resistors...
                  please check 3rd photo
                  (rt3661b section/puz1)
                  thank you
                  02-17-2025, 07:26 AM
                • chronic519
                  HP EliteBook 845 G8 (need resistor values by EC chip please)
                  by chronic519
                  Hello, I have an EliteBook 845 G8 motherboard sitting here. Customer knocked of 2 resistors by the EC chip. I cannot find schematics, board view or anything related to ID these 2 resistors.
                  If someone has this board, could you please tell me the values of these 2 resistors?
                  I hate to see this board be unusable due to something so minor....
                  Thanks...
                  02-14-2025, 10:36 AM
