question about diode of an old welding machine
  • Wolf1977
    • Jul 2023
    • 59
    • Greece
    hi in an old welding machine i have the power diodes you can see from the fotos
    these diodes the most of them are damaged
    do anybody know if there is possibiliti to change them ;
    the one side is easu to dissasemply and connected the pins the other side is connected in a material on metalic plate likes as seal
    does anybody has change diode like in mine case ;
  • petehall347
    • Jan 2015
    • 4447
    • United Kingdom
    Re: question about diode of an old welding machine
    stud diodes by the looks of it .they press in . replace all with matching diodes .
    • Wolf1977
      • Jul 2023
      • 59
      • Greece
      so sir to understand better
      The foot of the diode that seems to go to the metal plate in a point like insulation you can see in the picture i have tsese points in circle is not glued with a rod I mean but it is like nailed inside so if I pull the passage up its foot will come out from the inside and the new one corresponding to the old diode I will press it inwards at that point where there will be a hole left to nail correctly I understood ?
      • redwire
        • 3912
        What make and model is the welder? Voltage and current rating. It is 3-phase?
        Looks like https://www.mig-welding.co.uk/forum/...t-diodes.51350
        The rectifier diodes are a "press-fit" into the heatsink. Using hydraulic press, they push in/out of the heatsink plate. But do not crush the other side- so a special tool or die is needed.
        Can you can read the part numbers, writing on the side of the diode?
        They look like Motorola/On-Semi parts like MR254?. My guess 25A each one.
        There would be two different diodes used - common anode, and common cathode.
        • Wolf1977
          • Jul 2023
          • 59
          • Greece
          its one phase sir
          is there for replace do you think ;
          if i know the amperes of cource
          • redwire
            • 3912
            Bosch BD2504 25A 400V is 13mm check size (DO-21 0.5"/13mm).
            Many others here and cheap ones at Aliexpress but most are low voltage ones for car alternator, so watch out for that.
            These (press-fit) diodes are hard to work with. If there is room, stud-mount would be easier. This has a cooling fan?
            • Wolf1977
              • Jul 2023
              • 59
              • Greece
              ok sir my rectifier writes pms 8/02/140
              • redwire
                • 3912
                What make model is the welder? It seems to be a Sealey SuperMIG140?
                This is relevant: https://www.instructables.com/Mig-We...-in-bridge-rec
                They used qty. 2 of 70HFR160 70A 1600V VISHAY and qty. 2 of 70HF160 70A 1600V VISHAY stud-mount.
                • Wolf1977
                  • Jul 2023
                  • 59
                  • Greece
                  thanks a lot sir but because it seems a little bit dificult procees is there case on your opinion to find a new rectifier with the information of the previoudlu informstion ;
                  thanks on advance
                  • petehall347
                    • Jan 2015
                    • 4447
                    • United Kingdom
                    do a search for welder rectifier single phase . see if you can match it
                    • Wolf1977
                      • Jul 2023
                      • 59
                      • Greece
                      i dit it already
                      i cannot found anything match
                      • petehall347
                        • Jan 2015
                        • 4447
                        • United Kingdom
                        try electrotech solutions
                        • redwire
                          • 3912
                          I found some but after asking twice for the welder make and model, I don't think the bulb is bright enough
                          • Wolf1977
                            • Jul 2023
                            • 59
                            • Greece
                            sorry sir
                            the model is electro mic 210
                            • Wolf1977
                              • Jul 2023
                              • 59
                              • Greece
                              in this photo i think seems better the rectifier
                              • redwire
                                • 3912
                                Did you mean "elettro MIG 210" ? It is discontinued but you could ask them for a replacement rectifier.
                                Rectifier assy. is PMS 8/02/140 (140A) which is made by Scomes Italy.
                                Faet also sells a PMS 160 version. But you need 6 diodes, so need to add 2 more.
                                Either you hunt and try find a new one, or go to an electronics repair shop and get them to fix it.
                                P.S. - No picture of the front panel? Are you trying to make this stupid hard? Why does Post #3 scratch out the label and part number. I'm out now.
                                • petehall347
                                  • Jan 2015
                                  • 4447
                                  • United Kingdom
                                  being as its made in italy and that's where good welders are made .. had my mig 30 years cebora 155 and its still working only thing that's ever gone wrong was a low voltage transformer .
                                  am wondering why those diodes didn't last long .maybe crap was used and needs upgrading . or some other fault like a broken fan .
                                  • Wolf1977
                                    • Jul 2023
                                    • 59
                                    • Greece
                                    hi again in your opinion is single or fuel rectifier;
                                    • Dvsr
                                      On M-Audio AV40 active studio speaker's two zener diodes get really hot.
                                      by Dvsr
                                      Hi. I need help from wiser guys. I am amateur in electronics and can't figure this out by myself.
                                      I bought faulty speakers, M-Audio AV40's. Other speaker has all the electronics in it and the other speaker is just passive one powered by the other speaker's amp. Original problem with the speakers was loud buzzing. I figured out that there is something wrong with the capacitors. I went ahead and replaced every electrolytic capacitor on the PCB. The caps are good quality and have the same values as the original ones.
                                      After replacing the caps I started testing out the speaker. It seemed...
                                      09-10-2025, 10:20 AM
                                    • wolf1976
                                      I'm looking for a selective TIG-MMA switch on welding machine
                                      by wolf1976
                                      hi
                                      on the bellow pictures i have include the upper and the bottom area of this switch
                                      the machine had fallen and this switch is break can you suggest me a suitable switch to change it ?
                                      i dont know if this switch is the only problem because the welding is open normal the green led is light but it welds with interruptions
                                      and when i turn it on i measure the voltage and its only 6 volt i dont know if this is right
                                      thanks on advance...
                                      07-08-2024, 01:49 AM
                                    • wolf1976
                                      component identification of welding machine
                                      by wolf1976
                                      hi
                                      in a bit7000 awelco weld machine it has damaged an ic 16 pin that you can see on the bottom fotos
                                      i have take this foto with my mobile on the display of digital microscope
                                      can anybody to understand what component is ?...
                                      03-03-2024, 02:23 PM
                                      ALIENWARE Steam Machine R2 i7-6700T Specification for Upgrade or Repair
                                      This specification for the ALIENWARE Steam Machine R2 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Steam Machine R2 boardview and Steam Machine R2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                      09-12-2024, 03:28 PM
                                    • caspian
                                      What Zener Diodes on a Linear Power Supply
                                      by caspian
                                      Dear members,
                                      I have a linear variable power supply with unknown brand name that I used for voltage injection.
                                      Then it failed. I discovered that its transistors (Q1 and Q2) are shorted.
                                      In addition, I discovered that its zener diodes are defective.
                                      I can replace the burned transistors.
                                      But I do not know the model of the zener diodes. the model number is not marked on the zener diodes.
                                      Therefore, I cannot replace the zener diodes.
                                      I do not want to test the zener diodes in a test circuit to discover their model or value.
                                      no schematics are available...
                                      05-26-2025, 12:38 PM
