current measurement
  • barry wilkins
    • Aug 2009
    • 172
    current measurement
    On my Swift Motorcaravan there is an electronic control panel ,which is made in Italy.
    This reports the two battery voltages and charging or discharging currents.
    I have had the module replaced once under warranty because the display said the current was over 40 Amps.
    The fault is happening again after about eight months ,the display is registering over 40 Amps.
    I know how I would design a circuit to do this ,and would to here from anyone how they would go about designing a circuit to achieve this.
    Barry Wilkins
    • 30972
    Re: current measurement
    maplin used to sell split-charge panels.
    from the description, it sounds like a bad current-shunt or op-amp.
    post foto's - it may be better to improve what you have.
    • barry wilkins
      • Aug 2009
      • 172
      Had an email from Swift they admit there have been a few of these units fail with this fault.
      Inspecting the pcb found a crack across it ,repaired this and am going to refit it.
      • Toasty
        • Jul 2007
        • 4171
        Take pictures, send to them, have them replace it. Or, did you just void the warranty... ?
        veritas odium parit
