10volt x 50uF +105°C Radial Capacitors
  • Channels
    • Jun 2010
    • 14
    Good-Day;
    just a quick question. I am located in Canada and am having a hard time finding 10volt x 50uF +105°C Radial Capacitors; even online I have come up with nothing. I am looking for about 10 to 20 pieces. Any useful suggestions? Thank you.
    All knowledge is good; it's how you use it that makes it bad.
  • Quasar
    • Sep 2010
    • 132
    Re: 10volt x 50uF +105°C Radial Capacitors
    Look for 47uF. That's an industry standard value. 50uF is not.
    Voltage needed? In what equipment is it being used?
    Q
    • smason
      • 1652
      Agreed, 47 is the standard
      http://search.digikey.com/scripts/Dk...name=P11180-ND
      That's a low esr, 105degree cap. What's the application?
      And where in Canada?
      • Channels
        • Jun 2010
        • 14
        Thank you for the replies. The bulk of my use have been on LCD monitors, on the power supply boards. I have run across them on some other boards but do nothing to them. Generally all I have been doing is just swopping caps, value for value, I figure I can't go wrong that way. I thought I read somewhere sometime ago, that you can go higher on the voltage but not uF. Something like 16volt x 50uF? yes - no - maybe?
        (Ontario)
        • Quasar
          • Sep 2010
          • 132
          You can't just swap caps value for value. 20 years ago, yes. Not today because of the changes in technology and methods of powering the units. That applies directly to the section you are working on, the power supply.
          You have to find the specifications for what cap is there, and then choose what to replace it with. Determining the original caps manufacturer, series, ESR, and ripple handling values is the first step.
          Q
          • Channels
            • Jun 2010
            • 14
            I am starting to under stand that now. Before coming across this site, I gathered information on fixes from YouTube, and other sites; most if not all pushed the importance of swopping caps, value for value. Local hobby stores and even Radio Shack was suggested as a good place to find good caps. When I find time, I have been reading and learning as much as I can from good sites like Bad Caps; I have learned a lot but still have a long way to go yet. I am now just starting to understand terms like ESR, Series, and the importance of using high-end caps like Rubycon, Panasonic or Samxon. In time and when funds allow I will invest in a good ESR meter and maybe a desoldering station. So please bear with me as I might ask dumb questions or make silly assumptions but I am trying. Thanks.
            • Quasar
              • Sep 2010
              • 132
              Not a problem. Everyone has to start somewhere. You've picked a great place!
              If you supply the manufacturer, capacitance value, voltage, and series (which is -usually- 2 or 3 letters together near the temp rating) we can start helping you find the proper replacement.
              As much info as possible regarding the item you are repairing, the make and model, and any pictures you can provide of the bad cap(s) and circuit board, is a good start.
              Q
              • dragon3x
                by dragon3x
                power on.
                Here are some examples :
                switching supply area).
                than 6.3 V.)
                03-21-2025, 02:46 PM
              • slybunda
                AA and AAA battery charger capacitors?
                by slybunda
                hey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
                it has inside:
                2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
                2 x 470uf 16v LZ105c branded as G.Luxon
                not heard of these brands are they any good?
                iv attached photos of the charger and the board inside for an idea on the type of...
                12-24-2023, 04:41 AM
                After all of...
                07-13-2024, 08:14 PM
              • Ady2017
                Are there any datasheets available for Elna RJG capacitors?
                by Ady2017
                I have a 2007-era Panasonic VHS combo that is full of of Elna RJG capacitors. I am trying to test the capacitors to diagnose the machine and then select replacement capacitors but I can not find any datasheets for them. I did find a Elna catalogue from 2007-2008 but there is no mention of this capacitor series. Where these specially made for Panasonic and so not made available to the public? Any ideas what to find out what the ESR values should be without the datasheets? They are all between 10V and 50V and 47uF and 1800uF. None are leaking or bulged but I know that they need to be tested to be...
                05-25-2025, 02:19 PM
              • ctroxtell
                Samsung UN70tu7000wxza no standby light, do I have bad capacitors?
                by ctroxtell
                I picked up a 70" Samsung UN70TU7000WXZA. The original owner said they were watching it when the power surged and knocked it out. I pulled the back off the TV and disconnected the main board from the power board, and the LED backlight came on, which I was told meant the power board was good. When everything is plugged in the standby light will not come on, looking at the main board BN94-17775A with a thermal imaging gun I can see one of the chips labeled 3202 is 251 degrees F just sitting idle. I found a replacement board, BN94-16115X; this board has the same symptoms, except it is a different...
                01-03-2025, 08:57 PM
