Non-electrolytic capacitor manufacturers
  • Tioleco
    • Apr 2010
    • 46
    • Brazil
    What are the best non-electrolytic capacitor manufacturers?
  • Shodan486
    • Nov 2009
    • 203
    Re: Non-electrolytic capacitor manufacturers
    I guess Fujitsu will be one of them...not really experienced in this area of research, but maybe some of the major japan brands have something to do with this.
    Mobo: MSI K8N Master2-FAR CPU: 2x Opteron 265 OC'd @ 2,25GHz RAM: 2x2GB Crucial DDR400 CL3 ECC/Buff. (ECC OFF), VGA: ASUS HD6950 2GB Reference edition FLASHED TO HD6970 HDD: 80GB ATA133 Seagate ,OnBoard: 2xGLAN, 8-Ch. Realtek audio, USB2.0/Firewire, PCIe Physx card PSU: 850W Corsair AX Case: Cooler Master HAF932 + NZXT 5 Fan Controller.
    • PCBONEZ
      Grumpy Old Fart
      • Aug 2005
      • 10661
      There are a wide variety of completely different kinds of 'non-electrolytic' capacitors.
      Mann-Made Global Warming.
      - Dr Seuss
      • Wizard
        • Mar 2008
        • 2296
        Wax capacitor is one of the non-liquid caps, poly caps as well in several types of plastics. I know in 1980s electronics teacher had us cut apart old wax caps and unroll them to learn what internal structure of old caps are.
        Cheers, Wizard
        • Prolog
          by Prolog
          12-01-2024, 08:27 PM
        • chth96
          by chth96
          12-22-2023, 04:34 AM
        • chth96
          by chth96
          06-02-2024, 07:31 PM
        • chth96
          Is it no harm to replace with capacitor without ripple current rating?
          by chth96
          When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
          Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
          But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
          Rubycon YK DataSheet (b...
          04-19-2024, 05:19 AM
        • chth96
          Should I replace polymer capacitor?
          by chth96
          a few days ago I finally purchased mser-100 v2 and I tested its abillity of measuring ESR value.
          I found that It shows pretty accurate ESR value for electrolytic capacitor,But When I measure polymer capacitor of dreamcast game console,I found that one third of polymer capacitor's ESR value is more than twice the value of ESR meter table.(for example, I measured one polymer capacitor of 6.3v 100uf, It showed ESR value of 7.68)
          Although my dreamcast now turns 20 years old but it still works. I occasionally have played game with it.
          Is this ESR value of polymer capacitor correct?...
          11-18-2022, 04:22 AM
