Mosfet marked f1 vue 0X0603
  • jaaa1976
    • Apr 2018
    • 33
    • United Kingdom
    hi…need this mosfet or equivalent f1 vue 0X0603..where i can find? thx
    • 22035
    Re: f1 vue 0X0603
    PE600BA https://www.badcaps.net/forum/showpo...65&postcount=4
    • jaaa1976
      • Apr 2018
      • 33
      • United Kingdom
      Re: f1 vue 0X0603
      Originally posted by SMDFlea
      PE600BA
      • tofik
        MOSFET equivalent K8A60DA
        by tofik
        Hello guys,
        I have a shorted MOSFET K8A60DA with the following characteristics:
        Type Designator: TK8A60DA
        Marking Code: K8A60DA
        Type of Transistor: MOSFET
        Type of Control Channel: N -Channel
        Maximum Power Dissipation (Pd): 45 W
        Maximum Drain-Source Voltage |Vds|: 600 V
        Maximum Gate-Source Voltage |Vgs|: 30 V
        Maximum Gate-Threshold Voltage |Vgs(th)|: 4 V
        Maximum Drain Current |Id|: 7.5 A
        Maximum Junction Temperature (Tj): 150 °C
        Total Gate Charge (Qg): 20 nC
        Rise Time (tr): 25 nS
        Drain-Source
        07-19-2023, 05:18 AM
      • dreico33
        AON7403 Mosfet Equivalent
        by dreico33
        Hellow guys,
        I am trying to replace an AON7403 Mosfet but i dot not have in my stock the same. So i wonder if there is any equivalent to this Mosfet.
        Thank you very much.
        11-16-2024, 09:28 AM
      • Jane
        How do you test MOSFET in laptops ?
        by Jane
        I tried to use this method:
        Testing an N-channel MOSFET:
        Step 1: Discharge the Gate (turn off the MOSFET)
        Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
        Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
        Step 2: Charge the Gate (turn on the MOSFET)
        Now, place the red probe on the Gate (G) and the black probe on the
        09-27-2024, 03:31 AM
      • mohamed mm
        looking for equivalent mosfet for (IR3598MTRPBF)
        by mohamed mm
        I'm looking for an equivalent dule mosfet for (IR3598MTRPBF - Dual MOSFET Driver, High Side, and Low Side, 4.0V to 13.2V Drive voltage, 20 ns delay, QFN-16)
        it's for motherboard ram voltage.
        I hope someone can help me.
        Thank you.
        11-01-2023, 07:28 AM
      • jackx
        equivalent MOSFET 4C09B
        by jackx
        hello brother
        i need equivalent MOSFET 4C09B
        05-27-2024, 03:41 PM
