Need help to understand this circuit
  • Fr3shGy
    • Mar 2015
    • 47
    Hi, i am having a hard time understanding this circuit.
    "The optocoupler isolates the primary from the secondary side."
    1. Does that mean that whenever there is an issue, lets say a big short on the primary side, the secondary won't get damaged?
    2. Why does this circuit has 3 optocouplers?
  • petehall347
    • Jan 2015
    • 4430
    • United Kingdom
    Re: Need help to understand this circuit
    follow the lines back to icm801s and look at the datasheet for it then you should see what they do . as an example the top opto goes to fb .
    • Fr3shGy
      • Mar 2015
      • 47
      That one of them is for the feedback circuit makes sense, the second one could be for over current protection, maybe?... but the third one?
      the sample circuit of icm801s only shows 1 optocoupler for the feedback
      • R_J
        • 9579
        PCM803S is for feedback regulation of the power supply when in standby, Burst mode
        PCM802S is the isolator that tells the power supply to go from standby to full ON.
        PCM801S is for feedback/regulation of the power supply when turned ON and operating at full power.
        This is an always on power supply that has no separate standby section, so it operates at low power burst mode when the tv is in standby and does not require much current to operate.
        • Fr3shGy
          • Mar 2015
          • 47
          Thank you for clarification.
          1. If anyone of those PCM's had a problem on the cold side, the IC would always stay in burst mode?
          2. When the IC operates in burst mode, output voltages would always fluctuate?
          • R_J
            • 9579
            depends on the problem and which optocoupler had the problem
            The A13v could fluctuate and could be low, maybe around 9v, The vdr voltage would likely be quite low.
            For example if there was a short on the A13v line, PCM803S could shut down the ic after 36 oscillations (over current detection)
            If PCM802S failed, QM808 would not turn on which supplies the vcc to the pfc controller ic etc.
            If PCM803 failed, the ic may detect an overload and also shut down. It's a complex ic
            What problem are you having with this tv?
            • Fr3shGy
              • Mar 2015
              • 47
              I have a problem, not with that exact board but a fairly similar one (BN44-00786A), just couldn't find the exact schematic.
              Both mosfets went out and took the IC with em. I replaced both FET's the IC and a couple of resistors.
              After that the IC would not switch on not even in burst mode. So i checked the FB line and found out that both optocouplers PC801S and PC802S were shorted.
              Replaced both opto's and now the IC is sitting in burst mode and the Output (A13V) gives me 5,2 - 5,9V fluctuating.
              I then went ahead and lifted all optocouplers output legs up and soldered 3 diodes to the board. After that the IC fully turned on and i got 8.9V stable without switching. Which should suggest that the issue is on the secondary side of the board?
              I am stuck now without a general direction to go.
              • R_J
                • 9579
                You can't install diodes in place of an optocoupler, what made you do that? that will never work. The optocoupler that turns ON the board will need to be turned on, How are you turning ON the power supply?
                The power supply has a PFC circuit, does the pfc controller have vcc voltage? What is the voltage ACROSS the main filter cap in the primary? if it is 165v, pfc is not operating, if it is about 385v the pfc IS working.
                • Fr3shGy
                  • Mar 2015
                  • 47
                  My bad, i got it mixed up. That other thread isn't updated.
                  So the current state is:
                  I replaced the LLC IC, both mosfets, some resistors and both optocouplers
                  -Now i get 5,2 - 5,9V fluctuating at the output.
                  -Main filter cap is sitting at 330V
                  -VCC for the PFC IC is fluctuating 11~13,5V (not turning on)
                  -FB pin sitting at around 0.6V
                  On the secondary side, i checked the bigger electrolytic capacitors and the rectifiers.
                  I noticed that while measuring the resistances on the secondary side, the resistance of every resistor slowly rises, until it hits the correct value.
                  When i measure a diode in diode mode, the value slowly rises, until it hits the correct value.
                  Does that mean something?
                  • прямо
                    Help me understand this linear supply circuit.
                    by прямо
                    Was looking for a simple CV CC linear supply to build and came across this one.
                    https://oshwlab.com/svalentin544/lab...ply-0-38v-0-5a
                    I etched the provided board design and populated it.
                    The output voltage adjustment works.
                    The output current adjustment however, doesn't behave like I expected it to be. If PR2 is going clockwise, the output voltage decrease. Adjusting R5 has no effect.
                    I don't have a load connected to the output at all.
                    ​​​Can someone explain how the current adjustment work?...
                    02-17-2025, 11:09 PM
                  • bauto601
                    KDM 480W PSU upgrade succes! (opinions?)
                    by bauto601
                    Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
                    A "nice" YoungYear unit? - Badcaps
                    The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish....
                    12-26-2023, 03:05 PM
                  • g0v
                    industrial 24Vdc Xenon strobe light troubleshooting
                    by g0v
                    Hello all,
                    Im seeking help to understand this circuit more so that i can Fix it faster.
                    Its from Medc , model: Xb11
                    It contains:
                    1 P channel IRF9530N Mosfet(installed with the black heat sink).
                    1 N channel IRG4BC30K Obsolete IGBT. Near to the mosfet
                    2 TLC555/Q timer IC(the old one contains ts555in its the same function i guess).
                    2 ZTX649 NPN medium power transistors. On the right
                    1 ZTX749 PNP medium power transistor. On the right
                    1 C106M1G SCR (reverse blocking Thyristor)...
                    08-03-2023, 12:33 PM
                  • Tarot Superstars
                    trying to fix a 6V 0.5A T1 (Transformer) AD050120T2 power supply
                    by Tarot Superstars
                    Hi. I am trying to fix a 6V 5A power supply that would was used a lot.
                    I want to fix it partly for learning, and part because I don't want to buy a new one.
                    It has distinctive smell of burning but not seen obvious burned components yet. I'm not sure where the fuse is.
                    I tested the only slightly bulged capactitor (out of circuit) and it measured normal capacitance and ESR.
                    Everything else was tested in circuit with a multimeter.
                    In circuit tests
                    I tested the large diodes underside and they seem fine.
                    I tested...
                    08-14-2023, 12:45 PM
                  • nick122
                    Xbox 360 PSU failure diagnosis
                    by nick122
                    Hi everyone!
                    I recently got a bunch of 360 accessories for a good price, among which was also this PSU. It's a unit is rated for 175W (14.2A). OEM is Liteon.
                    The unit briefly powers on for a few seconds, the green light comes on, and powers back off shortly after the green light changes to red. There is no output voltage, I can't hear the fan running either.
                    Upon opening it up, there is nothing that would indicate why the unit failed. No burn marks, everything looks good visually. Primary cap is 130uf 450v NCC KMG, secondary caps are 1500uf 16v TAICON,...
                    05-21-2023, 06:26 PM
