SMD resistor tolerances
  • Super_Pseudo
    • Apr 2023
    • None
    No tolerances are listed for SMD resistors, only the value, on pcbs.
    If I had a 1R0 Ω (i.e. 1.0 Ω), would a 1.5 Ω in-circuit reading be bad (+50%)? Or do they not go bad?
    Ty.
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8711
    Re: SMD resistor tolerances
    make sure you zero out your meter first.
    • Super_Pseudo
      • Apr 2023
      • None
      Do you have an answer on smd resistor tolerances?
      • jiroy
        • Jun 2016
        • 2416
        • Lebanon
        First of all , resistors and eventually most of the components should be tested outside board when dealing with resistance .
        That's said , SMD Resistors as an international standard (there will always be some exception and especially from amateur companies if I may say so) , are typically 5% tolerance when they are labeled in 3 digits , and 1% tolerance when labeled 4 digits .. Hope this help you .
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8711
          A resistor won't read higher than its written/banded value (within tolerance) in-circuit when the circuit is off and completely discharged. Again the most likely cause for reading low value resistors (say less than 5 ohms) higher but within about 70% of their stated resistance is due to measurement error. A Kelvin connect is much preferred to do these measurements but most DMMs do not have this functionality.
          Usually SMD resistors like any resistor will go open circuit by a lot when they fail. Having it increase a mere 50% is very uncommon.
          I haven't seen many SMD resistors that are more than 5% tolerance and quite a few of them are 1% or better, unlike typical gold-band ¼W and ⅛W through hole resistors...
          • jinu_j
            by jinu_j
            Hi
            05-03-2025, 10:51 PM
          • mikey5791
            by mikey5791
            Hi to all forum members,
            12-26-2024, 04:55 AM
          • MidnightRoller
            Can a resistor lose resistance after hot air?
            by MidnightRoller
            I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
            I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
            02-02-2022, 11:46 PM
          • artvandalai
            What resistor ohm will work better to repair this waterpik?
            by artvandalai
            The resistor on this waterpik blew. I changed it with the a similar spec 47ohm 2 watt yageo resistor but it still keeps blowing the resistor. Checking with the multimeter the motor, capacitor, diodes, and thermal fuse all checked normal. Will a higher ohm resistor work better? What ohm resistor will work better to repair this waterpik? This video is showing the repair with a 56 ohm resistor https://www.youtube.com/watch?v=_J7_rV7ui1Y
            01-05-2025, 04:10 PM
          • chth96
            Is it okay to replace 1/2 watt resistor with 1 watt resistor in AC/DC adapter?
            by chth96
            I have purchased an 100-240v AC/5v 2a DC adaptor from aliexpress,and a month ago It smelled burning when I plugin it powerstrip.
            Since then, This AC/DC adaptor have been out of order.
            But A few days ago,I replace 0.5 watt resistor with 1 watt resistor(1ohm) in this adapter.
            After replacing resistor,It succeed to recharge all of android phone.And When I measure voltage on the two pins of USB port,It shows 5.5v
            And Is there any possibility that it will suddenly explode as well as to be out...
            12-03-2023, 04:40 AM
