Identifying an SOT23-6 with marking JWF9R
  • adamok7
    • Feb 2023
    • 20
    • Kazakhstan
    Need help identifying an SOT23-6 with marking JWF9R
    Does anyone know what this chip is ?
    It can also help if someone can provide the datasheet of this chip.
    Thank you.
  • R_J
    • 9627
    Re: Identifying an SOT23-6 with marking JWF9R
    It looks like it is a JoulWatt Tech JW5052C
    • adamok7
      • Feb 2023
      • 20
      • Kazakhstan
      it is "JoulWatt Tech" chip but unfortunately not JW5052C .
      • adamok7
        • Feb 2023
        • 20
        • Kazakhstan
        another picture of this chip.
        • R_J
          • 9627
          What does the ic do in the circuit? What tells you it is not the JW5052c
          • lotas
            • Jan 2016
            • 4900
            • Russia
            So the markings for JW5052C are different "JWH6X", and he has "JWF9R".
            • R_J
              • 9627
              I know the markings are different, What does the ic do in the circuit? maybe it is a custom part number.
              You can provide him with the correct part number.
              • adamok7
                • Feb 2023
                • 20
                • Kazakhstan
                This is diagram from LED controller board.
                • adamok7
                  • Feb 2023
                  • 20
                  • Kazakhstan
                  Have you any ideas about SOT23-6 that marked JWF9R ?
                  • jiroy
                    • Jun 2016
                    • 2416
                    • Lebanon
                    That's definitely a Joulewatt production , but the problem is , it comes in an evaluation board , so no specific datasheet can be found , other than digging in their evaluation boards and trying to assimilate details .. So , let me explain it one more different way .. It's not for sale as a one component , that's it .
                    You can find evaluation boards in their site , English and Chinese ones as well .
                    • jiroy
                      • Jun 2016
                      • 2416
                      • Lebanon
                      Here's an example of their evaluation boards , and it's built mainly around the "JW1130H , A current monolithic LED driver .. Notice the schematic inside the PDF ..
                      • adamok7
                        • Feb 2023
                        • 20
                        • Kazakhstan
                        jiroy, thank you for your attempt to help me. I see that chip not for sale as a one component.
                        • R_J
                          • 9627
                          What seems to be the problem with U1? Also what is the number on U2 (JWC7, JW1221A)
                          The closest I can find is a Controller for adaptive 100/120hz current ripple removing.
                          It is a JW1251O marked JWE9.
                          I found your other post with additional pictures on monitor, so I guess you already have your answer.
                          • adamok7
                            • Feb 2023
                            • 20
                            • Kazakhstan
                            I agree with "jiroy".
                            Probably chip JWF9R from evaluation board and it doesn't sell.
                            "R_J" - Your option with chip JW1251O is quite simillar to JWF9R.
                            If someone will find datasheet on JW1725O with output numbers and designations I'll be apriciated.
                            It's close enough with JWF9R as well.
                            Thank you.
                            • jiroy
                              • Jun 2016
                              • 2416
                              • Lebanon
                              Welcome Adomok7 ; I know you reached the same conclusions like I did .
                              Thank you.
                              JW1251O is a similar case to yours . No Marking code in its datasheet , because it's obvious it belong to another evaluation board . It's a pattern to this company . At the same time , which do not belong to some xxxxx evaluation boards , are given a marking code eventually ..But I feel you have done your research ...
                              • adamok7
                                • Feb 2023
                                • 20
                                • Kazakhstan
                                Yes, I have done my research.
                                Thank you to all.
                                • acedogblast
                                  by acedogblast
                                  11-02-2024, 05:13 PM
                                • DynaxSC
                                  ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
                                  by DynaxSC
                                  Hi
                                  I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
                                  08-04-2025, 12:20 PM
                                • skdsp
                                  Need help identifying resistor values near BIOS chip on ASUS Zephyrus G14 GA402XV
                                  by skdsp
                                  I purchased a laptop that the previous user had tried to remove and replace a BIOS chip using a soldering iron not knowing that there is a ground pad under the 25R256JWEQ chip. In that process he damaged the BIOS chip and 3 of the resistors near the IO3, CLK, and IO0 pins. I have programmed a spare 25R256JWEQ chip using a CH341A programmer but not sure what values those resistors should be. If anyone has a boardview of this area and can provide those values that would be very useful for me.
                                  Attached is the photo.
                                  Thank you!
                                  09-27-2025, 09:05 PM
                                  by SMDFlea
                                  Bad...
                                  09-02-2021, 04:40 PM
                                • trepachka
                                  Help identifying this chip for Yoga 7 16IRL8
                                  by trepachka
                                  This chip is shorted thru. Based on what I see, it's either a 3.3V or 5V buck converter, just my guess. The markings on the chip state "S2=AB".
                                  A photo of the chip is attached.
                                  Thank you....
                                  06-22-2025, 11:13 PM
