CCFL with bulging Rubycon
  • Behemot
    • 4845
    • CZ
    I was working on laptop and than the light upon my head turned off. The CCFL installed there was pretty hot, I dissasembled it and found slightly bulging Rubycon BXA. No wonder looking at the fried board...main problem is probably the PTC C890 which is now popped in half. Semiconductors look fine, but the transformer-looking thing is shorted (diode test indicates 3 ohms between two legs and 0 between others). Is it normal? From what I know about CCFL, it has only inductor no transformer actually...
    I guess the PTC is positive thermistor, the C890 means 890 ohms? Also is there some 125 degrees cap I can use instead of the Rubycon (4,7 uF)? I was also thinking about ceramic caps. Could it work with it? It shouldn't have temperature problems I guess.
  • Behemot
    • 4845
    • CZ
    Re: CCFL with bulging Rubycon
    So I've yahooed for the PTC thermistor and it's overcurrenct protection one with 150 ohms.
    I even succeded in finding one here in the nearest city! Awesome...
    • Th3_uN1Qu3
      Believe in
      • Jul 2010
      • 6031
      You're lucky. I spent months looking for a PTC for my mom's Samsung TV (they use those in the degaussing circuit) till i decided to junk a little 15" monitor and got the PTC out of it. Only to find out that the original one was actually fine, because even an external degauss coil i tried later wouldn't help the miscolored corner on the bottom right of the set. As soon as the coil was taken away from the TV, the colors would go bad again.
      It turned out to be a permanent magnetic field in that spot where the TV is placed, which was corrected by putting a magnet from a 8" woofer on a shelf at the bottom right of the TV.
      A working TV? How boring!
      • ttmi100x
        HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
        by ttmi100x
        Greetings everyone,
        I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
        The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
        Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
        Upon closer inspection...
        07-31-2024, 06:36 PM
      • nmbb
        Can not find Model/Value of Thermistor.
        by nmbb
        Machine: Autoclave.
        Brand/Model: SANYO MLS-3780
        Manual: (Sorry search option not working on this PDF)
        Hello guys, this autoclave running with 2 thermistors already connected TH1 and TH3(on CN1,CN2 sockets). One for the water temperture and second one for chamber temperature. But there is another emtpy socket for optional third thermistor CN2 wich is for TH2 for object temperature. I wanna add the third thermistor TH2 to CN2 socket. But i can't figure what model/brand/value i need to use. In manual document, there is no info about TH1 and TH3 model number...
        06-02-2022, 05:55 PM
      • narf
        Epson EB-U42 projector / Caps with 0.7 ohms ?!
        by narf
        hi all,
        first of all: i'm a (motivated) newbie, so please forgive me any stupid question i may or may not ask
        i'm currently repairing a projector: Epson EB-U42 that doesn't start (no lights, nothing).
        what i've found so far:
        - the PSU does its job and supplies 12V to the mainboard via the connector.
        - shortly thereafter, there is a mosfet (TS420-600B) where i can test 12V on the one side (in the data sheet this side is called Anode), Gate 0V, Kathode shorted to ground
        - not far away, there's the first cap with a resistance of 0.7 ohms....
        07-02-2024, 03:53 PM
      • mikey5791
        Help on Samsung Syncmaster T220 dead ccfl lamp
        by mikey5791
        This monitor previously is my main working monitor which i have been using for 8~9 years. Yesterday, when i switched on my pc from fresh to power on, the monitor is just black no display. I started dismantle to look inside the monitor power board but nothing looks suspicious or burnt. So i took my external ccfl inverter to try to power the monitor ccfl lamps which consisted of 2 lamps on upper part and 2 lamps on the lower part.
        Found out the upper ccfl lamp which is supposed to connect to cn304 on the power board did not light up. Then i installed a used working...
        10-18-2020, 03:17 AM
      • caseyjay_48
        Sony KDL-46BX450 Inverter Troubleshoot Logic
        by caseyjay_48
        I am currently on a troubleshoot of 46” Sony KDL-46BX450 tv. I came back from Washington to Texas on medical emergency and had to leave all my tools up there. All I have is a couple of screwdrivers and a dvm. I wish to ask the community a troubleshooting question. Please forgive stupid questions as meds I am taking produce brain fog.
        I have well maintained Sony KDL-46BX450. It went black one day. After turn-on, I get solid green light and Sony logo in screen center for about 1-2 seconds, then black. No blinking LEDs, no hissing. Flashlight test shows screen characters dimly viewable,...
        09-23-2022, 08:08 PM
