Smd resistor alternativ
  • bohaboha
    • Nov 2012
    • 1001
    • sweden
    Hi I have two smd resistors of different value one R100 and the other R220 that I want to replace what alternative value can I have ? they are from two different HD motherboard that I am trying to repai
  • petehall347
    • Jan 2015
    • 4427
    Re: Smd resistor alternativ
    do you have any more clues ?
    • bohaboha
      • Nov 2012
      • 1001
      • sweden
      Hi petehall347. have you read what was the solution for Skodan that you helped to solve ? Read it because it was a very funny problem. what more clues do you want?
      • petehall347
        • Jan 2015
        • 4427
        post me a link to that thread .
        with your resistors it all depends on the circuit etc .
        • bohaboha
          • Nov 2012
          • 1001
          • sweden
          https://www.badcaps.net/forum/showth...light=bohaboha .it's to a hard drive that both don't work if you want a picture of them? but in general which is the closest replacement that you can use because I don't have at home
          • jiroy
            • Jun 2016
            • 2416
            • Lebanon
            If the smd resistors are labeled like this : "R100" , "R220" , then they are 0.1 ohms and 0.22 ohms . Their size is important also , but usually in Hard drives , they're 2 Watts .
            • bohaboha
              • Nov 2012
              • 1001
              • sweden
              thank you very much I am trying to find similar on my HD cards parts but no on 15 almost similar cards therefore now I am looking for Equivalent if you can advise me
              • JNP-3R
                • Mar 2020
                • 10
                Wait, does the resistor say Rxxx on it, or does the board say Rxxx on it? If the labels are on the resistors then they indicate size like jiroy mentioned, but if they're on the board then they're just an internal reference number for the board designer and factory to use and don't tell us much without a boardview or schematic.
                The best way to get a value is to remove the parts and measure them as small SMD resistors are often not labeled. Then a measurement of length and width (usu. in thousandths of an inch, easiest to measure mm and convert, or use calipers) will tell you what package you need to order.
                Edit: dad gum typos...
                All we have is each other. PLUR y'all!
                • jinu_j
                  by jinu_j
                  Hi
                  05-03-2025, 10:51 PM
                • mikey5791
                  by mikey5791
                  Hi to all forum members,
                  12-26-2024, 04:55 AM
                • MidnightRoller
                  Can a resistor lose resistance after hot air?
                  by MidnightRoller
                  I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
                  I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
                  02-02-2022, 11:46 PM
                • artvandalai
                  What resistor ohm will work better to repair this waterpik?
                  by artvandalai
                  The resistor on this waterpik blew. I changed it with the a similar spec 47ohm 2 watt yageo resistor but it still keeps blowing the resistor. Checking with the multimeter the motor, capacitor, diodes, and thermal fuse all checked normal. Will a higher ohm resistor work better? What ohm resistor will work better to repair this waterpik? This video is showing the repair with a 56 ohm resistor https://www.youtube.com/watch?v=_J7_rV7ui1Y
                  01-05-2025, 04:10 PM
                • chth96
                  Is it okay to replace 1/2 watt resistor with 1 watt resistor in AC/DC adapter?
                  by chth96
                  I have purchased an 100-240v AC/5v 2a DC adaptor from aliexpress,and a month ago It smelled burning when I plugin it powerstrip.
                  Since then, This AC/DC adaptor have been out of order.
                  But A few days ago,I replace 0.5 watt resistor with 1 watt resistor(1ohm) in this adapter.
                  After replacing resistor,It succeed to recharge all of android phone.And When I measure voltage on the two pins of USB port,It shows 5.5v
                  And Is there any possibility that it will suddenly explode as well as to be out...
                  12-03-2023, 04:40 AM
